Question about Samsung 18.8 Cu. Ft. Bottom-Mount Refrigerator - Black
The generator isn't running and everything has melted and gone off.
  • Samsung Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 12, 2010
Generator had been running for 3 hours with a/c and refrigerator and lights (on concession trailer)when we experienced a loss
the unit has gone into over load
The total power requirement has exceed the output of the generator
for example if the generator is a 2.500 kw or kva then it will generate well at 1.8 kva or kw but it will not run forever at 2.5 kva -kw
When a ac is running the power requirement will be constant on the generator and with the fridge as well then the load will be at the maximum out put of the unit.
when the fridge starts again the extra load will exceed the max out put of the generator and it will slow down ( lights dimming ) and eventually go into overload mode
have an accredited electrician calculate your maximum load requirement for an external power supply and then get a unit that is at least 15.. kva kw better that required
generally fridges use 1000watts , ac conditions will draw over 3000watts and any thing else adds up . I am guessing that your generator is only 2500 unit
Apr 12, 2015 | Northstar Electrical Supplies
What is the probable cause for headlight switch connection to melt down
Heat generated by too much amp draw on the switch or a switch internals have gone bad with age/use and is making bad connections.
Jul 30, 2014 | 1993 Dodge Dakota
Coleman 3500 with subaru engine no power to outlets
Hello there.
I'm assuming that engine runs fine. if there's no power output then the AVR or carbon brushes are dead. remove the back cover of the alternator very carefully and look at the center to find the rotor rings and check if the plastic brush holder hasn't melt or heat deformed and make sure the brushes make good contact against the rotor rings. if everything's fine then the AVR is dead. The AVR is a crescent shaped plastic container similar to this one.
http://www.ebay.com/itm/Automatic-Voltage-Regulator-AVR-For-5KW-5-5KW-Single-Phase-Gasoline-Generator-/221461125389
replace it with any similar found on Ebay, just make sure that connectors and cables are similar in shape and number. Regards
Jul 06, 2014 | Husky 3650 Watt Generator with Subaru...
Dyna TFLC9000 generator itself smokes, not engine
Not a good sign. Smells really bad too I bet. If under load and smoking it may be overloaded. If free running and smoking, it has shorted out and will just melt down destroying everything. You may be able to save most of the generator if you get it fixed before it goes into full self destruct.
Oct 07, 2012 | Electrical Supplies
Generator is leaking fuel
On most Coleman generators, there is a rubber seal that literally evaporates if left in time. Most people don't even see it because it has gone. You must check if any seals are missing. Make sure that the gas regulator is screwed as tight as it can go because if it isn't, it will leak like a sib. Last problem could be the open and shut valve is stuck which is another thing that happens when it sits over time without using it. You need to start it up and hold the choke and that will stop the leak and let it run for a couple of minutes and let go of the choke. It should open and close the valve with no problems after that.
Aug 27, 2011 | Coleman Powermate Premium Plus 6250W...
I acidentally frmatted my flash drive and now everything is gone! HELP! ):
It isn't gone, you just erased the part that tells the computer where to look for the files.
Go here....
http://en.wikipedia.org/wiki/PhotoRec
It's pretty easy when you get the hang of using it.
TickMagnet
Aug 18, 2011 | Computers & Internet
The battery in my JD lawn tractor was dead; it started and mowed several times with a jump start but eventually only the tractor would run while the mower would not engage. With a new battery installed,...
I suspect that the alternator/generator has gone bad, preventing the battery from chargine, or generating enough voltage to keep the electric pto on your mower engaged.
I think that it is located on the engine beneath the flywheel.
I hope this helps you.
Aug 03, 2011 | John Deere Garden
I have a kenmore refrigerator side by side. my problem is that my freezer is not freezing the top where the ice is. everything was melting and defrosting inside the freezer except the lower part. i need to...
If lower section of the freezer is working but upper not the most likely problem is going be the fan in the freezer isn't running. Do you hear that fan running? if fan is not running it also wont circulate air into the fresh food(ref) compartment. If it isn't running you can possibly jump start it by removing back and flinging the fan blade with your finger to get it going till you can get replacement
Good luck,i hope this helps
Gene
Aug 01, 2011 | Refrigerators
The circuit board on my 98 silverado keeps melting on the turn signal/brake light bulb. It's the left rear, I have replaced it 3 times is there a short causing this?
I would chase the black ground wire to the frame first. It usually melts because the ground isn't tight, is corroded or high resistance. The ground wire and circuit board will generate a lot of heat when there is high resistance, and the circuit board will melt first. Check right at the connector going to the circuit board, quite often there are signs of poor connection or even the terminals melted there.
Apr 13, 2011 | Chevrolet C1500 Cars & Trucks
Motor runs fin but smoke major pouring out of generator end and circuit breaker will not stay on
If you were drawing major power from generator, you may have fried capacitor or voltage regulator. Both of these parts tend to make smoke when they fail. Stator winding can fail also but rare. Remove end cap to generator. Look for melted strings that bind coils together or melted wires. This would indicate failed stator. If stator looks ok, look for capacitors that look swollen or leaking that my be easily replaced. Caps have a value printed on them and reading should be within 5%. If caps are good, look at half moon shaped regulator. Failed regulator will have melted potting compound. Good luck
Nov 10, 2010 | Honda Electrical Supplies
Samsung 18.8 Cu. Ft. Bottom-Mount Refrigerator - Black Logo
43 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
