Cell Phones Logo
Posted on Sep 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Siemens Gigaset A2: No ringer, paging, earphone sound, no clicks. Display is correct. Other subscribers can hear me. Reset of headset and base don't solve the problem. AC adapter - voltage OK
Anonymous
Level 2:
Guru:
  • Expert 277 Answers
  • Posted on Sep 07, 2010
Anonymous
Expert
Level 2:
Guru:
Answers
277
Questions
Helped
42039
Points
778
MAy be your phone's speaker is not working so show it to any mobile repair shop / Siemens customer care centre
No ring on gigaset phone
1st step check in supply units - 110/230V AC to 9.5V AC adapter for base station.dd
2nd step check in ringer volume (ring tone) if the rank is zero (0) ringer is off and afterward change to wish-able ringer volume 1-5.
I had switched off my Gigaset C200 for one week and when I switched it on again so still flashes "base 1" on the phone's display. I tried manually connect to the base with PIN 0000 but still...
YOU SHOULD HARD RESET THE UNIT
When restoring factory settings:
u Handsets are de-registered
- When resetting via the menu:
all Gigaset handsets
- When resetting using the key on the
base station: also all handsets of
other GAP capable devices
u Individual settings are reset
u All lists are deleted
u The system PIN is reset to the original
code 0000
u Eco Mode+ is deactivated
Only the date and time are retained.
Resetting the base station via the
menu
₪ Settings ₪ Base ₪ Base Reset
§Menu§
§OK§
Press the display key to confirm
SIEMENS Gigaset C380 User Giude Restoring The Base Station To The Factory...
1helpful
2answers
Hello, I've a siemens gigaset 4000L (not the comfort one). Since yesterday it can't make any sound anymore. It's not in the quiet mode and all the other functions work fine. Problem is that...
Hello Diederik,
Just had a look at my Gigaset C2, where I can just follow the menu, same on my Gigaset A2. Have you got a screen display with menu options?
Kind regards,
Diederik Hagenbeek
11helpful
My Siemens gigaset A 490 cordless phone is showing Register HS what i have to do pl advise
To register the Gigaset handset, you need to have the handset near the base. Press and hold the Register/Paging button on the base for 3+ seconds (it's hidden by the handset when on the base). A shorter press of the button will activate the Paging feature. Then within 60 seconds of pressing the Register button on the base, press Menu and select Settings. Press OK and go to Handset. Press OK and then select Register HS. Enter the base PIN (default is 0000) and then press OK. (Use the up/down arrows to navigate the menus.) You will see Registering flash on the display of the handset for approximately 1 minute while the registration is processed.
The manual for the Gigaset A490 is available here: http://gigaset.com/medias/sys_master/A31008-M2200-R301-2-3S19_en-fr-es_USA_CAN.pdf . If you need it in another language (or country), start here: http://gigaset.com/hq/en/product/GIGASETA490.html?tab=manuals .
I hope this helps.
1helpful
Our Siemens gigaset A2 keeps flashing at us and doesn't work.
First pull the battery fron the handset, pres the register button (Page) for a long time, eg 10 sec, then register the handset through the menu, setings, handset, register
2helpful
Siemens gigaset a200: no ringer, paging, earphone
Hello could some please help me with my Siemens Gigast A200, it has no display on the Base phone.
2answers
Siemens Gigaset A260 cordless phone fail to register
We've tried to register the Siemens A260 handset to the base but it continues to flash "Base".. and does not work.
1helpful
4answers
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
