Question about Whirlpool Dishwashers
Quietpartner III the clean light is flashing and the dishwasher won't start.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 07, 2010
The CLEAN light is flashing on my Kenmore QuietGuard3 , but it won't clean anything. It starts a cycle for a few minutes, stops and starts flashing clean again. Any suggestions?
You will have to reset the dishwasher. First try and turn off the mains power and back on after a short time. If the clean light flashing starts again then you go through the hard reset procedure.
press NORMAL WASH then HEATED DRY buttons one after the other until all the lights on the board lit up (3X's). The dishwasher will enter into a cycle; Press Cancel. This should stop the flashing.
If you are supplying dishwasher from hot water inlet then make sure the inlet water temperature stays within the recommended range of 145 deg F.
Apr 21, 2013 | Dishwashers
Whirlpool dishwasher model Gu2548XTPS7, clean light flashes 7 times and won't start.
Check, if you have water in the machine, if yes, your control board could at fault
Mar 20, 2013 | Dishwashers
I have a whirlpool adp6600 dishwasher. the green light just keeps flashing (i think it's 7 times in a row each sequence) and the cycle won't start. have tried turning it off at the wall, clean
Dishwasher is in fault mode hold start/pause button for a few seconds this will reset the unit run your cycle again if dishwasher faults again call you local service man.good luck
Aug 02, 2012 | Whirlpool Dishwashers
I have a Quiet Partner III, when I press start it doe not come on. The clean light flashes when the door is open, but when I close it and try to start it nothing happens
The clean light is blinking due to an error in heating the water. I have put together some instructions on resetting the control so you can use the dishwasher and what to look for as far as cause.
Follow the link and let me know if it helps.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 10, 2010 | Whirlpool Dishwashers
Whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Dishwasher acts up
sounds like you have a bad chopper. put a cup upright on the top rack. turn the dishwasher on let it wash for about 2 minutes. open the door and see if the cup has water in it. let me know. what brand is this?
Jun 15, 2009 | Dishwashers
Dishwasher doesn't clean the top rack whwn we riun it.
sounds like the jets are cloged you can try a small wire to try and unglog the jets that or you water does not have enoph pressuer hope this helps
Feb 12, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool dishwasher quietpartner 2-soap residue
check that the sump screens are clear in the tank,also check that the wash arm holes arent obstructed.
Dec 30, 2007 | Dishwashers
Dishwashers Logo
243 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
