Question about Kenmore Elite Oasis 27052 Top Load Washer
Keeps stopping and code F1 appears - Kenmore Elite Oasis 27052 Top Load Washer
  • 15,935 Answers
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 07, 2010
F1 error appears just right after I turned the machine.. I had to stop and tstart 3-4 times before it gets on to cycle. Then at 23 minutes F! error error comes back and I had to do the same thing (stop and...
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
Aug 28, 2011 | Kenmore Washing Machines
Have a Whirlpool Cabrio top loader washing machine, keep getting code F1 during beginning of cycle. Got code uL for the first time today. What do these codes mean.
Have a Whirlpool Cabrio top loader washing machine, keep getting UL code when spin on high speed and the machine bangs all over the place.. Model num wtw6300sw0 Type 581
Aug 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
After 10 minute power failure the Code E1 F1 keeps appearing on display and will not allow me to clear or reset
the error code means that there has been a eprom error. Follow the directions below, if this fails to clear the errror code you will need to replace the control board.
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Note: Applies to all F1-E... codes except F1-E3.
If you have any further questins please feel free to ask.
Nov 17, 2010 | Kenmore 95822 / 95824 / 95829 Electric...
The f1 code on the Maytag Bravos top loading washer keeps going off and stopping the machine
Please contact Maytag to inquire about the code F1. They should check the system and that that code is a courtesy repair and should be scheduled for a someone to come out to fix it. FREE
It is possible that the F1 code was caused by your laundry habits (detergent), but I think that is unlikely. Too many of these machines have problems with the F1 error code. There is a known problem with the Oasis / Cabrio / Bravos machines.
Aug 19, 2010 | Maytag Bravos MTW6600T Top Load Washer
My washer beeps and says "F1", I press STOP and START. "F1" appears again and I press STOP and START and then works. WHat does this mean?
The "F1" error code on the Whirlpool cabrio is quite common, and generally has to do with the control board. Replacing the control panel may resolve this issue. However, I believe Whirlpool is aware of the F1 issue with the Cabrio, and is fixing some machines for free. Please call 1-800-253-1301 for more details and see if you are eligible for a free repair.
Thank you !!
Aug 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Fisher& paykel F1 Fault code
F1 means u have a leak on the machine somewhere. they leak from , lid, drain hose , lid activatiors, the leak has flood sensor to come on. to stop the F1 code u have to repair leak. please reply 4 more help.
Apr 25, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
KitchenAid KESS907 Electric Range E1 F1 Error Code
F1 E1, replace Electronic Range Control.
In other words, the controller board has failed.
Jan 29, 2009 | KitchenAid KDRS807SSS Dual Fuel (Electric...
My older jenn air double wall oven
shooter, F1 is usually the touchpad failure. You can try disconnecting the touchpad ribbon from the control and cleaning the ends with an eraser. See if the F1 stops. Catriver.
May 24, 2007 | Jenn-Air JJW8230D Electric Double Oven
Kenmore Elite Oasis 27052 Top Load Washer Logo
19 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
