Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
My electronic keyboard stacked W/D is stuck in the Pause mode, filled with wash and water. I don't know how to get it into the Resume mode. I push the Pause/resume mode, it shows 10 and never progresses. Thanks
    Problem Solver:
  • 5 Answers
First try unpluging machine for 5 minutes then re-plug-in and this might reset the computer.
Posted on Sep 13, 2010
My hoover 800rl top load washing machine does not progress beyond the fill cycle. once the water has reached the set level the start/ pause light goes from solid to flashing and nothing progresses form...
Check owner's manual. The light issue should be covered. Is it possible the tub is over filled? If so the level indicator switch is not working right. I'd unplug for overnight to see if the electronics will reset. Service Technician may be needed.
Feb 13, 2015 | Hoover Washing Machines
Fills, goes 4 minutes and fills, pauses, then fills, pauses then fills, over and over
Sounds like its syphoning out the water. If it was overfilling, you would have water everywhere, the machine would eventually flood. Check the drain hose. Make sure the end is higher than the water level in the machine and that there are no extensions running outside which have an end lower than the water level in the machine, it will start syphoning, usually after the first pump out.
Jan 01, 2015 | Washing Machines
We pulled our stacked washer out from the wall to service the cold water hose filter on the back of the unit. when we pushed it back into it's location the washer won't start, won't fill...
I know you don't want to hear this, but either you did something to the hose filter or you didn't get it plugged back in correctly.
If you banged the water inlet valve in moving it back, it might be damaged.
Suggest you unplug everything and start over.
Sep 04, 2011 | Frigidaire FEX831F Top Load Stacked Washer...
Can restart my front load washer after I pushed pause. It is full of water but I can't resume washing - I just get a buzzing sound.
Hello, Welcome to FixYa. I can't seem to access any previous post dialog that may have taken place but I'd like to help if you can fill me in on whats taken place to this point. Also if you could provide the make and model number that will help avoid any generalizing with you machine. I'll wait for you reply to see whats been done or suggested and checked to this point. Regards, Macmarkus :)
Apr 05, 2011 | Washing Machines
Rental...no manuel...first time using washer. pushed regular, large, cold, pause resume. When it finished filling with water it beeps 3x than stops for a couple minutes then beeps 3x etc. It is filled...
Your problem is with the pause/resume button. This button allows you to add/remove items before the cycle is complete. If you press this button and there is water in the machine it will beep for a period of time (3 mins) and then empty the machine automatically so you can open the door. After opening the door the cycle can be restarted again by pressing the pause/resume button again.
Nov 07, 2009 | Washing Machines
Intermittent water flow interupted by solenoids pulsing
I've got the same problem. If I pause the cycle, wait about 10 seconds, and then resume, the water starts normally. I suspect the Cold Water Inlet Solenoid is sticking, probably due to water sediment in the solenoid causing it to stick. I'll try cleaning it and then replace if that doesn't help and let you know what happens.
Sep 22, 2009 | Fisher and Paykel GWL11 Top Load Washer
Frigidaire gallery stack wash/dryer
Sounds like it could either be a bad solenoid in the fill valve or a bad pressure switch...both issues are easily repairable.
Jul 28, 2008 | Frigidaire GLEH1642DS Front Load Stacked...
Pause mode stuck
Is the door firmly closed? Open the door and close it firmly. If the pause button is really stuck, you will need to repair/replace the board.
Oct 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
100 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
