Question about Amana DRS2660B Side by Side Refrigerator
MOTOR NOISE AFTER ICE CUBES DROP - LASTS 2 OR SO MIN UTES The noice is not always the same - sometimes steady hum as if small plane is going over - lasts a few minutes. Sometimes noise is loud for a minute or so then slowly fades away. Cubes are fine and fridge stays cold.
  • Amana Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Posted on Sep 12, 2010
WHY DOES MY ICE MAKER ONLY MAKES ICE SOMETIME
Are the cubes normal - the right size, not hollow? Once frozen and the harvest cycle begins, does it take longer than a couple minutes for the cubes to drop? After the ice drops does it fill with water each time?
If everything checks OK the last thing is very important. The rate at which an ice maker produces cubes depends on the temperature of the freezer - the colder it is the quicker the cycle. Try nudging the controls up a bit and wait 24 hours.
May 31, 2014 | Frigidaire 20.6 cu. ft. Top Freezer...
High pitch/humming noise from Frigidaire Refrig.
You have to isolate this problem. It could be one of three things. The compressor, the condenser fan motor or the water valve that feeds the ice maker and wtaer dispenser. Also if the high pitch sound is compared to that of a bird then it is definitely the condenser motor. To isolate the problem take the back cover off. LISTEN FOR THE HIGH PITCHED/HUMMING NOISE! Use a flash light and see if you can tell where it is coming from while it is doing the noise. Dont try this unless you know what your doing. Stop the condenser fan blade with the end of a hard object, but stop it gradually. Dont try this cause you might brake/bend the blade. But if you did and the noise stop then you figured out your problem. If not ythen disconnect the water valve. It has to doulble harness wires attached to it. if problem still exisit then it has to come from the compressor. Unless you have a warranty then theres nothing no one can do except change it. $300-400 job easily.
Mar 27, 2010 | Frigidaire FRS26RLECS Side by Side...
OUR ADMIRAL ICE MAKER HASNT DROPPED ICE IN ABOUT 2-4 HRS. WE ALWAYS ADJUST THE ARM MANUALLY WHEN NEEDED AS THERE SOMETIMES IS SOME ICE CUBE BUILD UP. THAT DOSENT SEEM TO BE THE PROBLEM NOW. THE TRAY IS...
They sometimes get frosted up and don't want to work the motor properly...if you can get the face of it off, take a hair dryer and heat it up until the frost melts off...don't spin the fan motor if you have one on that unit. Then put it bad on and see if that will help if it doesn't you may have to replace the whole unit. They run around $190 if you do it yourself...not too hard of a job.
Oct 29, 2009 | Admiral AAV7000A
My ice cube tray is full...not dropping...and no clicking noise..
Hi first pls donot fill the ice tray full to its brim.... always fill it with less water because the volume increases when set... its easier to twist and remove the ice cubes
Aug 11, 2009 | True 598-TR1FRI1S Freezer Roll in One...
Periodically throughout the day there is a loud motor noise.
you may have a fan problem or ice maker open freezer switch on the frame freezer side press it you will know were the noise comming from
Apr 06, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Under counter ice maker water pickup problem
Most likely your plastic curtain is not keeping the water in the sump area. ( I'm assuming it makes round cubes)? Look under the sump for any dripping if its a pretty steady drip replace your water curtain and the holder that's with it.
If you have a cutting grid type ice machine this is all together different and I need to tell you separately about that.
Jan 01, 2009 | KitchenAid KUIS18NNT 18" Automatic Ice...
Ice maker for Model HSS25GFPJWW
Probably, but sometimes frost builds up in them and makes them unable to turn. They are gear reduction motors so you may not be able to turn it by hand, but if you take the ice container out, hold the door open, the door switch closed and press the ice dispenser and try to turn it whichever direction it's trying to go, you may be able to free it up. If that doesn't work you'll most likely need a new auger motor.
Jul 21, 2008 | Hotpoint HSS25GFP Side by Side...
Noises
Hi , small fan motor inside the infeller was touch to the build up of ice., it need to manual defrost to lesser the ice inside .
Jan 16, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
No water for ice maker
make sure wire is in down position this is like the on and wire up is off
Jul 14, 2007 | GALAXY Microsystems 25.4 cu. ft....
Amana DRS2660B Side by Side Refrigerator Logo
150 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
