Fortress safe wont open as batteries are dead and i have mislade the key there is a code where the lock is h8704457.bought it from ideal world but they dont stock it anymore. please help passport inside safe
  • 384 Answers
SOURCE: accidently locked door of safe keys inside and I
Call the manufacture.
Posted on Jun 12, 2009
Obertelli
  • 3006 Answers
SOURCE: Thought I knew the 4
Without wishing to state the obvious, I feel that I must do so. A safe is called a safe for a very good reason. If it was easy to get inside without the correct key or combination then by definition it would be unsafe.
If you have lost the combination and the key doesn't work then you can either try every combination until you get lucky or you must consider calling out a locksmith who will usually open the safe destructively (often by drilling out the lock) or even by using an angle grinder on the hinges.
Posted on Sep 17, 2010
MSG-CPC
  • 1325 Answers
SOURCE: I have a Brinks Home
i assume you tried contacting http://www.brinks.com/
what have they said, if you let them know about this ?
Posted on Oct 17, 2010
  • 167 Answers
SOURCE: Battery is dead need to
Are you looking for help with a Fax Machine or a Safe?????
Please provide more information.
Posted on Nov 22, 2010
  • 11800 Answers
SOURCE: I moved 6 months ago
This Pro Safe has been specifically design to prevent what you are trying to do - access its contents when the key is inaccessible and the code cannot be inputted - since this is exactly what happens when it's stolen.
The only way to open this top of the line item is to pick the lock - a complicated job that only a skilled (and expensive) professional can do. You will have to call the best locksmith you can find in your area - you'll need to provide some papers to prove you're the owner.
Posted on Apr 16, 2011
My batteries are dead and can't find the keys so how do I open my safe
If you can't find the key you may need a lock smith
Oct 28, 2014 | Home Security
Secustar Safe is locked
Don't you have a over ride key?
look on this link for what I mean.
2006 Competitive safes Cash Box Digital Lock Depository Safe...
Jun 11, 2014 | Locks & Locksmithing
I MISTAKENLY LOCKED UP MY SAFE KEY INSIDE THE LOCK AND THE BATTERY IS TOTALLY DEAD ,PLEASE I NEED HELP
you would need to hot wire the batteries for the code to work but if the batteries have gone flat then it needs to be re-programmed again ,only one soloution here and thats to open it with a radial cutter
Nov 20, 2011 | Locks & Locksmithing
I cannot open my Noble safe with the code I had. It seems that my code is gone and I don't find the key to open the safe. What can I do ? songa
I cannot open my Noble safe. I havent used it for 1 year, it has no battery and cant open it with my key. I cant remember the code, but i wont be able ti use it with no batteries.
What can i do
Feb 23, 2011 | Safe International Digital Electronic Safe...
How to unlock a cathedral electronic safe ea25
After opening the electronic safe (with the pre-set factory code of 159B) locate the small red button on the
inside of the door near the hinge.
2. Press the red button and then release it, you will hear a beep. DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW SECURITY CODE HAS BEEN ENTERED CORRECTLY.
3. With the door open, enter your own personal security code, which can be 3- 8 digits long, and confirm your new code by pressing the letter “B” on the electronic touch pad. Before you close the door, try the new security code to make sure the lock release the knob so you can turn it and retract the live action locking bolts.
If the code fails, go through steps 1-3 again. If the code works successfully, then you should lock the safe. When you open the safe in the future enter the security code you have set followed by the letter “B” and turn the knob.
If the incorrect security code is entered 3 times you will have an automatic lockout for 20 seconds before you can try your code again. If the incorrect security code is entered 3 additional times there will be a 5- minute lockout before the code can be tried again.
BATTERY REPLACEMENT
This safe uses 4- AA batteries. Under normal use, batteries will last about 1 year. When the battery is low, a red light will come on warning you that the battery is low. To test the batteries, enter your security code. If the batteries are low the red light located in the middle of the top of the keypad will start to flash.
To replace the batteries, open the safe door with your security code and turn the knob. Push the batteries cover plate, which is located on the back of the door, and replace the old batteries.
YOU MUST PROGRAME YOUR SECURITY CODE AFTER YOU REPLACE THE BATTERIES. SEE STEPS 1- 3 UNDER “ENTERING YOUR SECURITY CODE”.
TROUBLE KEY
A “Trouble key” has been provided in case you forget or lose your security code. Remove the small central panel from the front of the faceplate. Insert the key and turn it counter clockwise. Then turn the knob on the door towards the right. This will manually open your safe. If you lose your key, you may purchase a replacement key by referencing the serial number located under the central panel by the lock.
MAINTENANCE FOR KEY AND ELECTRONIC SAFE
If the door of the safe starts to rub on the door frame, open the door per the instructions above. By the door hinges you will find a threaded stem. Use an Allen wrench to tighten the threaded stem. This will help realign the door and give you trouble free access to the contents of your safe.
Nov 01, 2009 | Home Security
I have a digital electronic safe home protection. I have lost my keys and the battery is dead I have had thi safe for nearly 2 years
1) look again for the key
2) call a lock smith
3) drill the lock
these safes arent expensive , cheaper to drill the lock and replace that a lock smith , but get a quote
Oct 09, 2009 | Safe International Digital Electronic Safe...
I have lost my pin and backup keys + battery dead!
i got the same problem i lost my key and cant open now
any idea what to do
May 28, 2009 | Safe International Digital Electronic Safe...
Sentry safe S3877 have key and know combination but battery dead
Use paperclip to push in pin size hole below keyboard and then slide panel to right. Battery box is right there. Replace batteries and then was already to accept code.
Apr 08, 2009 | Sentry Fireproof Safe
211 people viewed this question
k24674
jasbo
jasbo
