Question about Aurora Electronics AURORA - Aurora paper shredder au-as501mx
I have an Aurura model A S 860 C paper shredder. It only runs in reverse.? Help
    New Friend:
I unplugged it, took out some paper, wiped it down since there was alot of white dust and used my son's air spray can and sprayed both top and bottom of the teeth and away it went again with no more issues so far. If this doesn't work, then I will also do Bernard's fix.
Posted on Jan 23, 2014
  • dlstrayer
    dlstrayer Jan 23, 2014
SOURCE: shredder
Check for stuck paper and remove if any. Then check if motor is ok with a multimeter and also main switch.
Posted on May 21, 2007
SOURCE: Shredder suddenly runs only in reverse
I had the same thing happen to me today - I had just shredded a ton of stuff, emptied the bin 4 times - after emptying the bin the last time, all of a sudden it would only go in reverse. I pulled out my instruction manual and it says the motor might overheat and to let it cool down and try again. I let it cool down for about 1 hour, cleaned out the gears and dusted off the sensor and it started working even better than it did before.
Posted on Jan 30, 2008
SOURCE: Paper Shredder blades do not turn, even though motor is running
the gear inside the shredder must be broken. This is the wheel that connects the motor to the blades. its much cheaper to buy a new one that try to repair this.
Posted on Jun 18, 2008
  • 35 Answers
SOURCE: I HAVE A MODEL SPL-1506X PAPER SHREDDER, YOU HEAR
The optics are OK!
There is a small electromagnetic sensor on the cuttershaft which senses the input load.
I could be maladjusted or defective.
Posted on Feb 23, 2009
SOURCE: Royal 15mx only works in reverse after clearing jammed paper
I have the same problem... The shredder will work in reverse only. Nothing at all happens while in the automatic position. I checked the back side of the circuit board for anything out of the ordinary. There was a hot spot on the back just opposite a zener diode and a resistor. Considering how these arn't expensive shredders, I just bought a new one.
Posted on Jan 27, 2010
My shredder worked fine but now when I turn on it does not stop running and does not shred paper ?
Most shredders will have a shred and a reverse setting. Is it running in reverse? Has the bin been emptied? With the power off, you can remove the bin and manually pull excess shredded paper jammed in the cutting heads -watch out, sharp metal . Once cleared run single sheets for the first minute to help clear rollers.
Jan 05, 2015 | Shredder Office Equipment & Supplies
How to lubricate a Black & Decker Model BD-s600 paper shredder
    • 1 Turn the paper shredder off and unplug it.
    • 2 Clean out the paper shredder. Make sure the blades are free of paper bits and debris. Remove pieces of paper that are jammed around the blades.
    • 3 Spray the shredder oil through the blade opening or throat of the shredder. Spray it in a stream.
    • 4 Plug the shredder back in and switch the reverse button on. Then run it for 10 to 30 seconds in reverse to allow the blades to be saturated with shredder oil.
    • 5 Put the shredder in forward motion and let it run again to disperse the oil thoroughly to all areas of the cutting blades.
    • 6 Feed a couple pieces of paper through the blades to be shredded and absorb any extra shredding oil.
Read more: How to Lubricate Paper Shredders ' eHow.com http://www.ehow.com/how_5761042_lubricate-paper-shredders.html#ixzz1kDQGrxZ8
Jan 22, 2012 | Office Equipment & Supplies
The shredder was paper jammed
Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds.
Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled.
Follow instructions to oil your shredder;
To keep your shredder in top condition, the cutting blades need to be oiled every so often (for frequency, please refer to your owner's manual). We recommend using Powershred® Lubricant or a vegetable-based oil (such as corn or canola) in a non-aerosol container with an extension nozzle.
Caution: Never use flammable synthetic oil, petroleum-based, or aerosol lubricants to oil the cutting blades. Some agents may combust, causing serious injury. NEVER USE WD40.
1. Depress and hold the reverse button down.
2. Put the tip of the oil bottle in the paper entry and make one or two sweeps the length of the entry while squeezing the oil bottle.
3. Move the power switch to Auto (I) position, or depress the manual forward button (depending on model of shredder) and allow the blades to run at least three seconds.
4. Move the power switch to Reverse (R) position and allow it to run for at least three seconds.
5. Repeat steps three and four above at least three time.
Regards.
Apr 20, 2011 | Geha Primo 1400 Shredder
Shredder will run in reverse mode but not in forward/auto. Has not been jammed or overheated.
Unplug the shredder. CAREFULLY clean out the shredding teeth and paper pathway. On some models you can loosen one end and open the paper path for better access. Ther is an acuator arm for a switch at one edge of the paper path and that will get clogged with paper and the arm cannot move to tell shrdder paper paper is in, ready to go. A blaast or two of canned air in the direction of the arm will help too.
The reverse action is ususlly initiated manually and is not affected by switch operation.
Let me know
Jan 15, 2011 | Techko SH2106PA Shredder
When you put paper in it starts to shred for about 1/4 inch then goes to reverse. No jams that I can see. Can run forward and reverse without paper with no problem. Sensor problem?
No mention of make or model however this holds true for all shredders.... especially if its a "cross-cut" shredder; put some shredder oil onto the cutting shafts where you insert the paper this will help get rid of some of the build-up that occurs due to the shredding process...also give the "eyes" in the middle of the "throat" a clan with a soft cloth( unplug the machine first or it will start to run and take your cloth in.) Occasionaly shrd a sheet of paper with some shredder oil poured directly onto the paper..this will help lubricate the cutting blades. Lastly...only shred up to about 70% of the rated cpacity..this will result in fewer jams an longer machine life.
Oct 19, 2010 | OfficeMax 0M96431 Shredder
Shredder jammed
For any jammed shredder..try the following.. pull backwards on the paper while you switch the machine into reverse. Try not to tear the paper as if there is nothing to hold onto then you can't help the motor.
If this dosn't work then you will have to take the top cover off(after unplugging of course.) and the try to force the paper backwards out of the machine by turnings the cutting blades or gears in the reverse direction.
Jun 04, 2010 | Royal 150MX Cross-Cut Shredder
Royal 85x crosscut shredder stopped working
Some shredders aren't designed to shred anything more than paper. Credit cards, staples, paper clips and the like could have jammed it up. Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 25, 2010 | Royal 85X Shredder
It will not grab the paper; need to press forwared
May 24, 2010 | Quartet gbc Shredmaster 6550X...
Our Aurora AS1712X paper shredder is jammed in a couple of places with paper so badly that we cannot free the jam and the tooth wheels cannot turn freely. Is there an easy way to clear the jam?
May 20, 2010 | Aurora Electronics AS882C (Cross-Cut)...
378 people viewed this question
Top Aurora Electronics Office Equipment & Supplies Experts
k24674
skiffy99
skiffy99
Level 1 Expert
Dabu42
Level 1 Expert
Are you an Aurora Electronics Office Equipment and Supply Expert? Answer questions, earn points and help others
