Question about Seagate Barracuda 7200.10 500 GB SATA Hard Drive
Hard Disk Not working - Seagate Barracuda 7200.10 500 GB SATA Hard Drive
  • Seagate Master
  • 27,725 Answers
Try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
replace them they are probably old and faulty ?
good luck
Posted on Sep 07, 2010
Hard disk tiking when power up.
Some times you don't know if your hard drive is working or not. Your external hard disk might drop on the ground, or your desktop/laptop hard drive might not be booting. Which ever the case maybe, here is how to find out the condition of your hard disk:
Put your ear close to your hard disk, if you hear your hard disk make a crackling noise, be prepared to buy another hard disk because such hard disk is damaged and cannot be fixed. Also note that it is difficult to recover files from such hard drive.
But if you don't hear a crackling sound, use your hand(s) to feel the drive, if it vibrates, it means the hard disk is in good condition.
What damages external hard drive most times is if you don't eject (safely remove) it from your computer, when it drops on the ground or hits any hard object etc
If your external hard disk stops working, firstly, check if the hard disk inside the case is in good condition by checking for crackling sounds and vibration. Once you observe that the hard disk is in good condition, this means the hard drive case is defective/the cause of the problem. Get another drive case and your drive will work again without loosing any file/data on it.
For desktop/laptop hard drive maintenance, make sure you always shut down your computer properly, don't remove the CPU's power cord while the computer is turned on. To be on a safer side, always use UPS (uninterrupted power supply) for your desktop computer.
Also, when using your laptop, makes sure its fixed at a position. Avoid any shake as the hard disk might shift from its normal position in the process.
Good luck.
Jan 11, 2011 | Hitachi HTS542520K9SA00 200 GB SATA Hard...
Tip
How to detect if your hard-drive is working or not/hard disk maintenance.
Good luck.
on Oct 21, 2010 | Computers & Internet
I have a laptop which it does'nt detect the hard drive what is the problem?
The problem could be one of these -
The hard disk needs reseating to make proper electrical connection.
or
The hard disk is faulty.
or
The BIOS has not detected the hard disk.
or
The hard disk controller is faulty
To determine the fault -
Reseat the hard disk and boot up the laptop.
Check the BIOS configuration - does it detect the hard disk. The BIOS may have a hard disk diagnostic, if so then run the diagnostic.
For a further hard disk test - remove the hard disk and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If the hard disk is OK then this computer will detect it as an external hard drive and you can open the folders and files.
If not then the hard disk is confirmed faulty.
To get the Gateway working, install a new hard drive and install Windows, the laptop's device drivers and your programs.
Sep 05, 2010 | Gateway 450ROG Notebook
Not detecting hard disk
first thing to do is to remove and reconnect the hard disk to the system. devices like hard disk not detected often is just a result of loose connections. if this will not work, may be a good idea to test another hard disk with your computer or test the hard disk on another computer to isolate if the hard disk will need to be replaced.
Sep 04, 2010 | Computers & Internet
How i can partation my hard disk
look for a third part software or look here:
http://windows.microsoft.com/en-us/windows-vista/Create-and-format-a-hard-disk-partition
May 14, 2010 | HP Pavilion dv6000z Notebook
Hardrive not detected
You may have a hardware fault.
Try re-seating the hard drive.
Then check the BIOS to see if the hard disk is detected.
If the hard disk is not detected then either the hard disk is faulty or the disk controller on the motherboard is faulty.
To further test the hard disk, remove the hard disk and connect it to an USB hard disk adapter and plug it into a working computer's USB port. If this computer cannot see it as an external hard drive nor can you open the various folders and files, then the hard drive is faulty.
Then you need to replace the faulty hard drive, install Windows on the new hard drive, together with the laptop's device drivers and your programs to get a working laptop again.
Feb 25, 2010 | Asrock 775i65G Motherboard
Hard disk
just remove the fllopy and connet the hard disk secondary it will be work
Feb 13, 2009 | Computers & Internet
Drivers
hi..there...maybe you mean the update firmware for your hard disk... but i think only the expart can update the firmware of hard disk 'cause it high risk and can make your hard disk doesn't work anymore.
so same like other if your hard disk works normally it doesn't any driver at all even you us XP or Vista operating system....
Feb 02, 2009 | Toshiba (HDD2D15) 80 GB Hard Drive
Lenovo T61error 2100: HDD0(hard disk drive)
To all users with: lenovo T61error 2100: HDD0(hard disk drive),
Possible cause:
  1. Corrupted hard disk logical sectror/hard disk logical error (bad format).
  2. Hard disk connector not well in place.
  3. Hard disk broken, physical fault.
Solutions:
  1. Format hard disk and reinstall system using a Windows setup CD.
  2. If that does not work the Hard disk must be removed to check thge connector, and to test the hard disk on a different computer.
  3. If the hard disk is bad , it must be replaced, and windows reinstalled repeating step one.
Nov 25, 2008 | Lenovo ThinkPad T61 Notebook
Mother board or CpU Doesnt work. technician said I have a ghost inside my CPU!
verify your bios settings with regards to what the pc is expecting in way of hard drive.
Do you have the luxury of another hard drive that you can try on this pc ? - this will 'suggest' where the problem rests.
Make sure the lead is fully located on the back of hard drive.
If possible - change the lead for a 'known working' lead (Maybe from the computer that your hard drive was recognized in)
Aug 15, 2008 | Seagate (ST307504FPA1E3-RK) Motherboard
Open Questions:
bricked hard drive? Would folling this lead to a full hard drive format or just unbricking a drive like people sat it does?? Also any other ways that might help would be great to know, heres what i'm talking about! "Fixing The Drive NOTE: Commands for you to type are in red boldface. Pay attention to upper & lower case - it is important. Turn on power to the RS232-to-TTL adapter and the hard drive. After a few seconds, Press CTRL+z. You should then see a prompt like this: F3 T> If not, swap TX & RX wires. Access Level 2 (type /2): F3 T>/2 (enter) F3 2> Then spin down the (disconnected) motor: F3 2>Z (enter) Spin Down Complete Elapsed Time 0.147 msecs F3 2> Very carefully, remove the cardstock that you placed between the PCB and the drive head contacts. Carefully replace and tighten the 3 loose screws. I suggest using a small piece of masking tape to help you hold the screws while you put them back in place. Then start the motor: F3 2>U (enter) Spin Up Complete Elapsed Time 7.093 secs F3 2> Next go to Level 1 (type /1): F3 2>/1 (enter) And do a S.M.A.R.T. erase (create S.M.A.R.T. sector): F3 1>N1 (enter) Cycle power to the drive, then do partition regeneration: F3 T>m0,2,2,0,0,0,0,22 (enter) After 15-30 seconds, you should see something like: Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 14, Max Certify Rewrite Retries = 00C8 User Partition Format 10% complete, Zone 00, Pass 00, LBA 00004339, ErrCode 00000080, Elapsed Time 0 mins 05 secs User Partition Format Successful - Elapsed Time 0 mins 05 secs Do not turn off drive until you see this message. Once seen, drive can be turned off. Power down everything, place drive back into your computer, and confirm that it's working." Thanks.
Apr 12, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Seagate Barracuda 7200.10 500 GB SATA Hard Drive Logo
21 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
