Question about HP LaserJet 2430n Printer
What is service error 49.4C02? HP Laser Jet 2430n
  • 1,218 Answers
Printer error code "49.4c02" is one of them. It occurs when there is corrupted data. This may confuse the printer, and it stops functioning. In other cases, the data is corrupted while being transferred to the printer. Some printer models are naturally prone to this error because of their driver, while others can display this error while printing a specific font. fix printer error 49.4c02
Posted on Sep 18, 2010
    Problem Solver:
  • 17 Answers
Try this error code site
http://www.printertechs.com/tech/err...odes-index.php
Sounds like an application is acting up or software on the server
Posted on Sep 07, 2010
HP COLOR LASER JET 2605 PRINTER 49 ERROR MSG DISPLAY SOLUTION
49 errors are most commonly caused when the printer receives a print job with commands it does not recognize. You can try updating the firmware as this will often resolve the error. Go to HP's website to find the most recent firmware, however this model is fairly old and likely the firmware update will be fairly old.
Sep 25, 2014 | HP Laserjet 2605dn Workgroup Laser Printer
Laser jet 3055 scanner error 6
Generally, Error 6 is a failure of one of the PCA boards and the unit requires service.
Apr 20, 2010 | HP LaserJet 3055 All-In-One Printer
HP Laser Jet 3055 printer-52 scanner error?
Remove the top cover. The laser / unit is a black box.
Try www.partsurfer.hp.com
to purchase one.
Jan 15, 2010 | Office Equipment & Supplies
HP Laser jet 4350 dtn printer gets 59.40 error. I
Print Cartridge Motor Error.
Try removing then re-installing the cartridge. If that does not work then you will need to try a different toner cartridge as the toner cartridge is "locked up". These are the most common solutions. If none of these work then you have a cartridge drive problem and will need to contact a service center.
Jan 05, 2010 | HP LaserJet 4350dtn Printer
49,4c02 error to continue turn off then on
I would try clearing your print que as it could be a corrupt print job and disconnecting your network cable and reboot the printer, make sure you have the latest firmware. hope this helps
Nov 24, 2009 | HP LaserJet 4700 Printer
HP Color laser jet 4700n 49.3048 service error
The problem is usually caused by printing a PDF file with fonts/page size/ page formating errors which will cause the printer to display the 49.3048 error. The only way to use the printer is to POR or recycle the power and delete the print job from the server or spooling device and cancel it on the printer before the offending command is issued to the printer again. You can try updating the firmware to the latest version 46.140.5 from the HP website. MIke L.
Oct 12, 2009 | HP Color LaserJet CP4005dn Network Printer
HP 2430n Service Error 494C02
Hi atrowbridge:
The error code 494c02 is a firmware issue and needs to be updated. You can go to www.hp.com for the latest firmware updates for your printer.
pdouglasss
Jan 09, 2009 | HP LaserJet 2430n Printer
Replacing paper pickup roller
on both sides of pickup rollers there are white bushings rotate the white bushings towards you
Remove the left-side bushing by sliding the bushing to the left.
Slide the roller and shaft toward the left until they clear the hole in the right-side bushing, and
then lift the right end of the shaft.
Slide the roller and shaft toward the right and lift the roller and shaft together out of the printer.
install your new roller then reverse this process to reinstall
Oct 21, 2008 | HP LaserJet 2430n Printer
Problem with my HP laserjet printer
It seems like the cartridge sensor is loose. Turn off the printer, unplug it and take the toner off. Wait a few minutes (it can be very hot) then try to find the sensor (in the area where the toner goes and see if it is loose (if so, try to adjust it).
Good luck
Jun 24, 2008 | HP LaserJet 2430 Printer
HP LaserJet 2430n Printer Logo
2,958 people viewed this question
Seeker5211
Seeker5211
