Question about Maytag Refrigerators
About every three days or so I find a puddle of water on the floor in front of my Maytag Fridge. I also notice a thin layer of ice on the bottom of the freezer compartment
  • 1 more comment
  • ritchieginge Sep 07, 2010
    Thanks I will try this and get back to you.
    One more question - where exactly is the hole you mention...is it in the freezer compartment? (Hey, I am an 80 year old lady and need things as simple as I can get them LOL) Thanx
    HaHa - (you don't know me - I could mess up a free lunch!!) Thanks again, this should help!!
  • 11,800 Answers
At the back of the fridge there's a hole thru which the water that condensates on the back panel should drain away every time the fridge goes to it defrost period. If the hole is blocked the water will sill thru the front door and make a puddle at the bottom of the freezer and freeze there.
Take out everything out of the fridge, defrost it thoroughly, unclog the hole with a long zip tie or something else - pour some hot water thru it to be sure it properly cleaned,clean the rest of the fridge (especially at the back) and start it over - now your problem will be gone
Posted on Sep 07, 2010
  • Azrael SRL Sep 07, 2010
    There should be a hole in both compartments so check them both - but since the water puddles in the freezer, the hole that is clogged is in there.
    The hole is on the back wall , just at the bottom, a channel moulded in the wall leads to it, you can't miss it.
I( find a puddle of water on floor at front left hand corner on freezer side..I took the freezer drawer out and found ice build up under it ,could this cause my problem.. this happened about every 24 hours...
The problem with your refrigertor is that the defrost drain is plugged up. After you get the ice buildup out of the freezer section you will have to locate the drain system. It is in the back of the freezer at the very bottom.It needs to be cleaned out. Hope this at least leads you in the right direction.
May 27, 2011 | Maytag MSD2756G Side by Side Refrigerator
I have water leaking under freezer side of door. I turned the ice maker off, turned off the water to the fridge, cleaned out the ice behind the panels, and put it all back together. Every couple of days I...
Hi, The drain hole is plugged with debris or ice...
Just had to thaw my own out tonight, it was doing the same thing... Take the bottom draw out and maybe the bottom shelf and then you will see the ice buidup in the back and on the floor... Thaw it out and make sure the drain hole is open... then you will be okay again...
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 25, 2011 | Maytag MSD2651 HE Side by Side...
Maytag side by side fridge freezer leaking water
Your drain plug within the evap area of the freezer is frozen, turn frig off, let sit for day or two with doors open. Once all ice has melted then take rear freezer evap cover off and pour water into try and make sure it drains, if not then unplug drain. This is usually caused by a defrost heater bad or unit not going into defrost when it's supposed to, may be main board.
Sep 30, 2009 | Maytag Sovereign 60 Side by Side...
Maytag Plus MSD2556AEW - frozen puddle on freezer floor
Here I am going to give you a lot of information. Because of the leaking your defrost condensate drain is most likely the reason. All on the page below may not be for your situation and some refrigerators do this over a period of time and the the water has no were to go but the freezer during defrost. Click on link below, Thanks, Sea Breeze
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Aug 17, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water on floor from freezer side of Maytag side by side unit.
Yes I just had that happen to me. An appliance guy came over for my stove and I asked him if he could tell me why I wake up everyday to a puddle. He told me to take the baskets out unscrew the three screws and pull the panel off, then pour some hot water in it and use a turkey baster to blast the drain hole with. It worked. Sears repair man couldn't even figure that out when it was under warranty. Took me 15 minutes. Good Luck
Connie Marie
Aug 12, 2009 | Maytag MZD2766GES Side by Side...
Defrosts/refreezes
IF YOU TAKE THE BACK PANEL OFF INSIDE THE FREEZER YOU WILL FIND A PIECE OF METAL UNDER THE EVAPORATOR COILS IN MIDDLE OF THIS METAL PAN IS A HOLE THAT LEADS THE WATER TO THE BOTTOM OF THE REF FOR EVAPORATION THE HOLE IN THE PAN IS PROBABLY PLUGGED TAKE THE ICE OUT AND CLEAR THER HOLE
Aug 11, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Small puddle of water under fridge
if you have a thin sheet of ice in the bootom of the freezer your drain is clogged,use a hair dryer to lossen the ice sheet and get it out of the way,heat up the drain hole and pull the frig. out from the wall,use a hanger or something you can usr to clear the drain tube,last get a hot half cup water with alittle beach and pour it down the drain,your done,let me know how you do-ike
Nov 28, 2008 | Maytag MSD2756GES Side by Side...
Water leaking underneath refrigerator/water freezing in bottom of freezer
I'm dealing with the same problem right now with the same refrigerator. The cold water tank (for the front dispenser) has a hole in it that leaks every time someone dispenses water from the front door. You will find the water tank behind the top slide-out drawer in the fridge. The leaked water flows down one of the water tubes through a hole in the bottom of the fridge and onto the floor. I'll bet you have the same problem. Good Luck.
Jun 14, 2008 | Maytag MSD2758G Side by Side Refrigerator
Leaking fridge
my maytag had cloged defrost drain cleaned drain all ok
Oct 28, 2007 | Refrigerators
Refrigerators Logo
234 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
