Question about Ovens
After self cleaning my ge profile electric range the light for locked never goes out and can't open the door please advise
  • pfols Sep 07, 2010
    I've tried all of your suggestions and the locked signal continues to stay on.
  • 1,711 Answers
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished.
If the lock does not open after the oven has cooled down, you can try....
1. Unplugging the range or shut off the circuit breaker for 5 minutes.
2. Plug the range back in or turn on the circuit breaker.
3. Set the clock and try moving the door lock lever or opening the door.
4. Set the self-clean cycle again and only allow it to work for 15 minutes.
5. Cancel the self-clean cycle and allow the oven to cool. 6. Gently try moving the door lock lever or opening the door.
Good luck
Posted on Sep 07, 2010
  • espressonist
    espressonist Sep 07, 2010
    Probably your problem is with the self-clean solenoid, is the green coil in back just above the tab that you lifted to get the door to unlock.
    This or the micro-switch that is in the middle of the slide bar are the two most common problems.
    1) Solenoid could be bad, (open coil)
    2) micro-switch could be bad
    3) micro-switch could be out of adjustment so switch isn't getting activated to activate solenoid to release lock when the lock lever is moved.
    With the door unlock, when you move the handle to lock, it should activate the micro-switch with only a small amount of movement, then same when going from lock to unlock.
    If you look at the slide-bar that runs from front to back you will see two square notch openings cut in the bottom of the slide-bar right near the micro-switch contact arm. When in the full unlock or lock position the contact arm should be down in one of the two openings leaving the switch in an open state so solenoid is not activated. As soon as you move the lock handle you should see the contact arm ride up out of the notch and activate the switch in turn sending power to the solenoid which lifts the tab in back out of the way of the tabs that stick up on the slide-bar to lock it.
    If you have tried too hard to open the door when it was still locked or was having problems there is a good chance you have bent the slide-bar that goes from front to back. If you take this bar out and lay it on a flat surface, it should be flat and level along it's whole length, towards the back end of the bar where it necks down, it can bend and it will look like it is suppose to be made this way but it's not. It has to be flat.
I was able to clear the locked door message, and get over working following steps above, but cannot get the lock mechanism to release, and therefore cannot close the door
Check out these steps at the following link... http://www.geappliances.com/search/fast/infobase/10004586.htm
Range - "LOC DOOR" flashes in the display
If "LOC DOOR" is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
Motorized Switch
    1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
    2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
    3. While you hold the door jamb switch in this position, complete the following steps.
    4. Press the Clean pad, wait 10 seconds.
    5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
    6. Wait 10 seconds for the display to clear.
    7. The door should unlock and there should not be a need for service.
Manual Switch
    1. Press the Clean pad.
    2. Close the door.
    3. Slide the latch to lock the door.
    4. Hit the cancel button immediately.
    5. Unlock the door.
Motorized Switch
Manual Switch
    2. Close the door.
    5. Unlock the door.
Nov 24, 2010 | GE Profile JTP18 Electric Single Oven
How do we unlock the oven door! Accidentally pushed a button in front. We have no manual or SS#. Oven was in house when we bought it. We unplugged it to turn off and was able to open the door. Please...
IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com
The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock. IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can un-lock (safety feature).
Good luck with this!!
Aug 18, 2010 | GE Profile JTP18 Electric Single Oven
My frigidaire gas range has a F90 on it when I tried the self cleaning oven feature
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 16, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
After self-clean cycle oven door won't unlock
your lach might have given out on self clean. change it
Feb 12, 2010 | GE Profile JTP18 Electric Single Oven
How to self clean
Depending on the condition of the oven, it could take up to 4 hours.
A couple things to remember is: (1) Make sure you do not turn the light on inside the oven. The clean cycle should disable it. (2) Lock the door if it does not lock itself. (3) Do not open the door during the clean cycle.
Remember the self cleaning temperature is extremely high. Do not allow children in the area while doing it.
Here is a link for your stove:
GE JTP18 Manual
Directions are on page 23.
Dec 13, 2008 | GE Profile JTP18 Electric Single Oven
GE Electric Double Oven Door Will Not Unlock
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Nov 05, 2008 | GE Profile JTP56 Electric Double Oven
Locked latch on the self cleaning oven
try wiggling the door latch to get it open if not try the cleaning process, if that works, and see if the door comes unlatched and the light goes off. if not the lock light switch is stuck and it will need to be taken apart and cleaned
Oct 13, 2008 | GE JKP15 Electric Single Oven
Our GE Profile JTP18 keeps flashing "door lock" since we ran a self clean
most of the time a simple fix.... http://www.geappliances.com/search/fast/infobase/10004586.htm
you have to trick the door lock mech into cycling through the cleaning process (takes about 20 seconds)
Print Range - “LOCKED DOOR” flashes in the display
If “LOCKED DOOR” is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
Motorized Switch
Manual Switch
    2. Close the door.
    5. Unlock the door.
If the above does not correct the situation, a service technician will need to check your cooking product. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Sep 14, 2007 | GE Profile JTP18 Electric Single Oven
Ovens Logo
104 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
