I loose my drive disc - Office Equipment & Supplies
    President:
  • 2,712 Answers
Can you give me the make and model of your printer please?
Posted on May 13, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    This thread has gone 14 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
OPERATING SYSTEM NOT FOUND
Hello
As per my experience about your problem it sometimes occur when the power supply connector of your hard has loose connection or the sata cable connector loose. Try to check in the bios set up if the hard disc is in there. And check the connector are tightly connected to there pins and see to it that all the pins are connected to the connector of your motherboard and hard disc are connected properly.
Hope this solve your problem.
Jul 26, 2011 | Samsung HM321HI Samsung 25 320GB 5400RPM...
Laptop wont start up just says a disc read error has occured, press Ctrl+Alt+Del to restart but when I do this I just keep getting the same message
Two possibilities are involved. 1) The hare drive is not responding correctly. This could result from a loose cable (needs to be connected to the motherboard and the drive) or a damaged drive (either from damage to the disc or lost boot information).
2) A non-boot disc is being accessed in the boot sequence. This could be a CD/DVD in the optical drive, a floppy disc in that drive (older laptops) or a USB connected drive (either a thumb drive or a regular external disc).
The second issue is easy to solve, disconnect/remove any other media. Then try to boot. Alternatively, on most Windows machines, you can press F12 to choose the boot sequence. However, you need to press the button between the POST (power on self test) and the loading of Windows. For me, this can take several attempts.
For the first, the options depend on your skill/willingness to open the computer. One option is to use a Live CD (a bootable disc) to see the status of the hard drive. Use the F12 sequence if needed to boot from the disc. (The live cd could be a Windows Recovery/Install disc.)
To save files from the disc, you can either use a UNIX Live CD and an other drive (an external optical R/W drive or hard drive) or remove the disc completely and connect it to another computer. For this second option, use an IDE/SATA/USB dongle, a laptop hard drive enclosure or hard drive dock. The dock will work with a SATA drive; disc enclosures need to be selected to match the drive type (IDE or SATA). When you do the disc removal, you will see if the cables are loose. Be careful with static while opening the computer.
Then replace the drive with a new one, reformat and reinstall the OS or use the recovery disc to attempt to fix the boot problem.
I hope this helps.
Nov 26, 2010 | Computers & Internet
Can i have a diagram of the inside of this hard drive as a bit came loose inside so ive opened it to find where this piece goes the number of the drive is MHV2060BH it is a silver bent thing that came...
Please tell me this is a joke.........
You cannot open a hard drive or you will make your drive unusable. Hard drives are assembled in clean rooms (cleaner than surgery rooms) and then sealed. Any particle of dust inside the HDA can destroy the surface of the discs, because the discs spin at a very high speed (at least 5,400 rpm but usually 7200 rpm nowadays). This would not only lead to data loss, but also the physical destruction of the disc surface.
So, there is no serviceable part inside the HDA – at least for the regular technician. Only data recovery companies with clean rooms can open and replace components inside the HDA.
Aug 04, 2010 | Fujitsu MHV2060BH 60 GB SATA II Hard Drive
Keep gettig disc read error when i turn the computer on. ran both recovery discs still wont work.
If you see disc error when booting, most likely it is either a hard drive failure or a loose interface connection between the hard drive and the motherboard.
Feb 13, 2010 | Toshiba Satellite X205-S9349 Notebook
The disc reader will not spin any discs. What to
If you have never opened the console then it can be 3 things
1 Connection to the DVD drive has came loose
2 The laser Lens is bad
3 1 of the 2 motors in the drive could be bad.
If the disc will not spin then it would me a loose power connection to the dvd drive, or the motor that spins the disc is bad. All parts in the dvd drive can be changed. But never change the whole drive without takeing the board out of the old drive and put in the new drive. If you do then all it will be is a expensive paper weight. Because there is a security number in the motherboard that must match the one injected in the DVD drive. I repair these problems often with 99% success.
Jan 25, 2010 | Microsoft Xbox 360 Console
Disc door will not open
The magnetic weight thats mounted on top of the dvd drive on the inside has came loose and jamming the door. Also it wont read the discs if this happens. I repair drive issues in PS3 and 360's with 99% success
Jan 22, 2010 | Microsoft Xbox 360 Console
My hp pavilion dv6000 disc drive isnt working. It runs but can't read the disc. Help please!
there is an issue with the motherboard of this model, just install another drive just to eliminate the possibility of the drive being the problem, if the second drive does not work then you need to contact hp ASAP, before you completely loose the motherboard
Oct 03, 2009 | HP Pavilion dv6000z Notebook
Coins placed in the disc slot of the Wii.
I would not advise using the drive if there are any loose objects inside. Doing so would void your warranty, cause damage to the wii, and possibly even bodily injury. If the disc should come into contact with the loose object while spinning at high speed, the disc could shatter and the shards may actually break through the drive casing.
A loose object, if it catches something traveling at high velocity, can easily damage the casing and the wii remember
The only practical solution is to remove the drive from the wii and obtain a replacement. It would be prohibitive to try to fish out the loose object, since you might damage the internal components in doing so. you will need to call Nintendo ( 1-800-255-3700) and see if they can fix it or guide you through taking the disk drive out
I don't think they will slide out if you turn the MBP on edge. I would take it to the Apple store and be prepared for a nice bill. I hear kids also do this in the disk player in the car to get it fixed It won't be cheap, I 'm afraid,
At the very least the drive will need to be removed, I fear. It may actually have to be replaced. A few hundred dollars, I would guess.
Good luck
May 06, 2009 | Nintendo Wii Console
Xbox Disc Tray Loose
If you are comfortable with taking apart your system, I would advise taking the case off and then finding the dvd-drive, removing the case on that and simply tightening the screws on the tray. Don't tighten them too much, but make sure they are snug. Then test to see if it still wobbles and it should be fixed. If you are not comfortable with taking apart your system you will need to find a repair shop that can do it for you.
Please rate, thanks!
Mar 31, 2009 | Microsoft Xbox 360 Halo 3 Special Edition...
23 people viewed this question
jasbo
jasbo
