Question about Soleus CFM-25 Dehumidifier
Blower motor need's replaced wont turn blower fan unless hand pushed
    Master:
    Sergeant:
  • 449 Answers
Check the No have someone come out to check the start capacitor not for novices you can get hurt
Posted on Sep 08, 2010
Why does blower wheel stop on Frigidaire dehumdifier?
Good Afternoon Desi,
I understand that the blower wheel is not spinning on your Frigidaire dehumidifier, model# FAD504DUD. I also see that the compressor will stay on unless the dehumidifier is unplugged. I suggest you contact the manufacturer for further assistance. They can possibly clarify why the compressor stays on and why the blower fan is not working. If not, they should at least be able to point you in the right direction of having your dehumidifier working. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire FAD504DUD White Energy Star 50...
Fan Runs On and Off
the problem is dry bushes on the fan shaft. It is best to replace the fan motor unless you have a good appliance electrician who can pull the motor apart ad knows how to lubricate the bushes.
Jun 09, 2013 | Haier HD308 Dehumidifier
Error code 67
Error code 67 is an airflow problem. Either clogged filter or bad blower motor. Unplug unit remove bucket and feel for filter in front behind cover it drops down. Clean filter with water and reinsert. Plug unit in turn to "on", fan should begin to run, after 3-5 minutes compressor should start. If fan does not start it is bad and should be replaced.
Jul 07, 2012 | LG LHD65EBL Dehumidifier
The dehumidifier's fan does not turn and makes a humming noise
first,make sure the fan blade hasn't gotten stuck on the shroud and cannot turn,then shut off machine and by-hand rotate fan and see if it spins to a stop after several rotations,if it stops quickly there is a bearing problem with the motor,this is normal after many years of service,then replace the motor
Jan 26, 2010 | Dehumidifiers
After about 5 minutes the unit stops working. No sound or even a fan noise. I just cleaned the filter to see if that helps, but it didn't.
Is the fan running and stopping before the unit completely quits?
If the fan quits the compressor won't run very long.
I would start with the fan motor or capacitor.
Shut the power off to the unit, spin the blower wheel to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
r.
Aug 21, 2009 | Dehumidifiers
Blower fan is seized Kenmore 54501 Dehumidifier?
If the blower motor is siezed up, then you need to replace the motor.
You can have new bearings put in it, but by the time you get thru it will cost you about the same as a new motor and you won't have any warranty on the old motor, you will have at least a one year warranty on the new one.
Aug 09, 2009 | Kenmore 54501 Dehumidifier
Bad fan motor on DH504ELY5?
problem fixed with the fan motor not running.
heres how i did it for anyone who experiences the same problem
1.) open back of unit(6 screws and pop tabs)
2.) with back cover open youll have access to compressor and fan-locate the blower assembly and remove the nut on it i used a 3/8 wrench from dollartree and rotated the blower fan while turning-its plastic be careful and remember righty tighty lefty loosey)
3.) with fan assembly off youll see the motor with 2 phillips head screws-taking these screws out with a power screwdriver allows the bearing assembly closest to the fan assembly,shaft,armeture and motor assembly to come out leaving rear bearing assembly attached to chassis
4.) once the motor assembly is completely out gently rest it against the fan hole and cut the silver tape being careful to ONLY cut the silver tape and the first white tape strip.
5.) youll see 3 wires and some insulator sleeves covering them leave everything alone except the ORANGE wire this wire attaches to the thermal fuse than to the windings
CAREFULLY heat up your soldering iron and remove the orange to thermal fuse connection than carefully thermal fuse to windings its a bit of a pain but can be done with patience
6.) remove original thermal fuse noting EXACTLY where original is placed on windings-it will have a small tape strip on it. replace it with one of EXACT OR NEAR THERMAL RATINGS a good choice is radioshack 270-1322. this thermal fuse is ratyed 10 amps max. but remember thermal fuses go by degree of heat and not by amp rating unless the amperage is in excess to melt the thermal material inside-my original fuse was 2 amps and 130 degrees celcius new fuse was 129degrees but plus minus 2 degrees so its a good choice and costs under 2 dollars
7.) place a heatsink clip or needlenose pliers between thermal fuse and solder connections BEFORE YOU SOLDER IT IN PLACE this prevents your 700 degree f iron from melting the fuse(remember its thermal not amperage were talking about here)
solder orange to thermal fuse with plastic extension than flat end to winding wire exactly opposite of how removed
8.) tape fuse in ORIGINAL LOCATION AS OLD FUSE i used scotch tape,place the thermal white protector piece on orange to fuse wire and push everything back down in original places-there should be no contact with any other wires etc. it will cause a fire
9.) once fuse is in place push tape you cut earlier back on and put 2 or 3 small scotch tape pieces of good length to secure the innards, lube the rear bearing of motor using vasoline- a few dollups will do it do the same for front slide motor winding assembly holding it in place than replace armeture with front bearing attaches as they came out secure the 2 screws back in place, put fan blade assembly back on(its keyed) secure nut and reassemble back
if you did everything correctly it will work like new just remember this time CLEAN YOUR FILTER SCREEN REGULARILY lol its critical for proper fan cooling
that should do it:)
Aug 20, 2008 | Goldstar DH504EL Dehumidifier
Fan does not come on
I've seen abunch of these. The fan motor has a fuse wound into the windings. It cannot be replaced you need a new fan motor. The motors seem to run hot normally, leading to a short lifespan.
 I suggest buying a better brand unit.
Oct 23, 2007 | Comfort-Aire BHD-651 Dehumidifier
No water collection
compressor may be starved for freon or blockage in freon line...tech must troubleshoot.
Jun 08, 2007 | LG LD65EL Dehumidifier
Soleus CFM-25 Dehumidifier Logo
47 people viewed this question
Top Soleus Dehumidifiers Experts
jeff5may32
john h
AZBen
AZBen
Are you a Soleus Dehumidifier Expert? Answer questions, earn points and help others
