Question about Samsung BIXOLON® SRP-770II Thermal Label Printer
Printer Drivers Are Installed But Printer Is Not Printing
Double side printing HP LaserJet M1120 MFP
Hi Franziska,
HP has not yet released Driver software for your MAC LION however there is a solution for this.
In order to print 2 sided ( duplex printing ) you need to install drivers and it is possible by doing Apple Update.
The link below will give you more details information of how to install the drivers.
MAC LION Driver Update
Once you have done the Update and installed the drivers, you will find the Printer name in Printers list.
Click on Printer Utility and under Layout you will find options to choose 2 sided printing
Regards,
Sean
Apr 19, 2013 | HP LaserJet M1120 MFP All-In-One Printer
My Lexmark x 1240 stopped printing in color
Issues in color printer are many. The most common one is the non-printing of color prints. This issue might be due to corrupted or incompatible drivers in your printer. When the driver installed in a color printer is corrupted or not installed correctly it might lead to issues. So in order to solve this issue you need to install or replace the corrupted driver with a new powerful driver; or reinstall the driver since the issue might be due to wrong installation of drivers.
Jun 22, 2011 | Office Equipment & Supplies
We installed the HP designjet on a pc windows vista and we can print everything we want to, the printer is also installed on a mac osx 10.6 snow leopard but there we have some problems for printing our...
HP Design Jet 1050C Plus is supported by MAC OS 10.6. If you are having problems with printing, it is recommended that you may update the drivers of your printer. Click here to download the latest drivers.
Good Luck!
Hope this helps!
CreativeTECH
Dec 15, 2010 | HP DesignJet 1050c plus InkJet Printer
I have an HP laserjet 1010. i got the paper jam
If you are getting correct test page without errors, simply unplug your printer's USB Connection from PC. uninstall Printer drivers and software. restart PC.. Re-Install New Copy of Drivers and Software.. THEN PLUG THE PRINTER USB CABLE TO PC.. try printing after proper driver is installed..
May 30, 2010 | HP LaserJet 1010 Printer
Printer not printing text
When printing a web page which has only 5 lines of text, the printer prints the 5 lines and scrolls the page empty. But, I wanted the printer to stop printing after it has printed the available 5 lines. Also, it should not print the header and footer automatically.
Dec 04, 2009 | HP DeskJet 3740 InkJet Printer
Brother printer wont print
Did you try replacing the cartridges? The accident might have damaged them.
Oct 12, 2009 | Brother MFC 420CN All-In-One InkJet...
The epson printer driver dealing with cd printing is not installed
# Select Print from the File menu.
If you see the message The Epson Printer Driver dealing with CD printing is not installed, click OK.
# Click Tray, select Tray 2, then click OK.
Note: If Tray 2 is not selected, the CD design will print in the wrong position.
# Click Manual Print.
# Make sure Epson Stylus Photo R(your model) is selected.
# Under Paper, select the following settings:
* Source: Manual
* Size: A4
# Click Properties.
# Select CD/DVD or CD/DVD Premium Surface for the Media Type setting.
# Click OK, then click OK again to print.
Oct 18, 2008 | Epson RX595 Photo All-In-One Printer
Printer will not print even though it is attached to the computer.lexmark x1240
Most likely you don't have drivers installed on your computer for the printer. If you have the CD that came with your printer, the drivers and software should be in there. If not, you can look up drivers on Lexmark's website or somewhere else on the internet and download the software/drivers and install it on your computer. After installing the drivers, reboot if necessary and try printing something. It should be printing by then.
Sep 28, 2008 | Lexmark Office Equipment & Supplies
Printing from 2 different pc, drivers installed on the server, get different quality
I think that quality settings is different for each user. If your printer have network card, pleas install printer with TCP/IP port in every PC, not from server, more job, but less problems.
Sep 15, 2006 | Konica Minolta magicolor 5430 DL Laser...
Samsung BIXOLON® SRP-770II Thermal Label Printer Logo
223 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
