Question about HP 12c Calculator
Keyboard HP 12c
I can not work with "Zero" symbol and "+" symbol. Do you know how to fix it?
I have been running the normal test to find something wrong, but every thing seems to be fine.
    Sergeant:
  • 291 Answers
Under the rubber membrane ,touching the individual symbols (in this case zero & plus[+] there is a carbon coating (black stuff) that shorts out the two metal connectors on the board, when u press down on the keys
Open hp12c and lift up membrane away from body and see if the metal contacts[on the body] are warned, damaged or that the " black stuff " is on the membrane.
u can try a fix...........take a small piece of aluminum foil and glue it to the underside of rubber membrane where the "stuff" was.
Don't put a thick piece because the metal foil should bounce back with the membrane as u press down on the key.
Hope that helps.
I tried this once.........a small dab[ hey!!,, when I say a dab....i mean a dab....of glue. Sharpen a pencil & rub the tip across a EMERY board so that the carbon "black stuff" from the pencil falls on top of the glue. Let it set & try for 2 hrs or more.
HOPE THAT HELPS!!!
Posted on May 14, 2008
Shift key and symbols dont match
You can change the keyboard layout to match the one you have.
In your start box, select run and type "intl.cpl" (without quotes).
Under the formats tab, change the format. try the ones with English (" ") and then click apply.
To see the format selected,open the On-screen keyboard ( type "osk.exe" in run) and hold shift to view the symbols.
Try different formats until you find something that matches the phisical keyboard layout.
Jul 18, 2014 | Acer Extensa 5235 5635 Laptop Motherboard...
Sticking/Under responsive zero key on an HP12c!! Is it trash?
It could be some dirt or grit in the keyboard, which a blast or two of compressed air might clear out. It could be a worn dome on the inside of the keyboard.
If you want to have it repaired, there's FixThatCalc, though they're currently not taking new orders. There also have been several threads on opening and cleaning Voyager series keyboards at the Museum of HP Calculators. Here's one article on opening a Voyager.
Apr 19, 2012 | HP 12c Calculator
I cannot get the regular symbols to work. the question mark, money symbol, percent ...etc. I also cant get capital letters unless caplocks is on. please help. its as if the shift keys are not working...i...
dv6985SE
No OS stated, is this windows or linux or freedos.?
This PC came with VISTA in the USA< is it still vista? or slammed with some other alien OS. (not using HP install media)
windows WHAT, must we beg ?
Testing 1,2,3, simple as falling off a log. really.
ok try something more useful
find any usb keyboard,real and plug it in (barrow one?)
does that work?. if yes, good, if not the OS is corrupted.
(know that corruption has endless possibles) ask.
try a real keyboard, all USB work on your LAPTOP
if that fails, then your OS is corrupted,
if that works, the USB key board, then your internal keyboard is bad, time for a new one, for sure.
Be Backed up first your DATA backed up 1st !
then
RECOVERY HP WAYS:
power on button
then quickly hammer the F11 key,
this is the HP magic F11 recovery key.
then do a full recover.
if you PC was slammed with MS disks , F11 is now dead forever.
the book books is free, we are not HP here.
HP.com is HP.
your sevice manual is at HP. hot at fixya .
http://h10032.www1.hp.com/ctg/Manual/c01295877
posted 100s of times, here, and 1million times at HP.
search much?
Nov 21, 2017 | HP Pavillion DV6985SE Notebook
My HP 15C calculator recently developed a problem with the number pad being unresponsive. Calculator appears to pass the self test, however, the key pad test does not work at all. Suggestions for repair?
If the keyboard test fails the calculator should be sent for repairs. One shop in Pennsylvania repairs most models, except the newer ones. The URL is www.fixthatcalc.com. Best of luck!
Dec 28, 2009 | HP 12c Calculator
Symbols
You hit a keystroke combination. You'll have to press the Fn key in the lower left side of your keyboard and one of the special function keys (in a HP, I think it's something like F11 or F12--look at the symbols on the keyboard. Anyway, that combo locks the special characters on. Just hit it again to get back to normal typing.
Sep 22, 2009 | HP Pavilion dv6000z Notebook
How can i tell the difference b/w hp12c and hp12p. i bought a hp12p from ebay(it's a stupid decision, I know!) and when i solving for IRR, i felt its running quite slow. I think the guy sold me the hp12P...
I couldn't find any reference to a HP calculator model 12p.
There is a HP 12c financial calculator and a 12c Platinum financial calculator.
Check both models (for images, specifications, functions, user guides, etc.) :
HP 12c Financial Calculator
HP 12c Platinum Financial Calculator
Aug 06, 2009 | HP 12c Calculator
Keyboard 10 key, digits aren't working, just the symbols
it is sure that keyboard has not any problem, check the foloowing:-
application configuration
setup configuration
virus
shift key pressed
Nov 03, 2008 | HP Compaq nc6000 Notebook
HP 12c cALCULATOR
It is not calculating because your decimal point and the digit separator (that's the comma which automatically displays for every group of 3 digits) got messed up. To clear, turn the calculator OFF, then press and hold down the dot (that is the decimal point symbol) key while you press the ON key..
t
Sep 04, 2008 | HP 12c Calculator
HP 12C
gtabblt.gif Description gtabblt.gif Resetting the calculator using the keyboard gtabblt.gif Resetting to drain the capacitor gtabblt.gif Other solutions gtabseps.gif Description Sometimes a calculator will lock up or will not respond correctly. The calculator may require a reset for a variety of reasons. These resets will erase the memory on the calculator and restore the calculator’s defaults. For this reason, it is important to back up any critical data. Resetting the calculator using the keyboard The easiest reset is done from the keyboard. To reset the calculator, follow the procedures below in the order presented.
  1. Press ON to turn off the calculator.
  2. Press and hold [ - ] .
  3. Press and release ON .
  4. Release [ - ] .
  5. The screen will display “ Pr Error
  6. The calculator will reset to the default settings, and the memory will be erased.
If the above reset did not restore the calculator to normal, continue to the next section.
HP 12c Calculator Logo
286 people viewed this question
Ben Johnson
