Question about Samsung HL-S5686W 56" HDTV
We replaced the lamp about 6 months ago..but now it cuts off randomly..the red light and one green light will flash? Lamp replacement was when all 3 lights were flashing. Suggestion?
    Sergeant:
  • 171 Answers
Is the picture quality good if it is then the lamp is ok try to reset the lamp timer if you haven't all ready. I think that the problem is coming from the ballast board this is the power source to the lamp, with time this part starts to ware out and starts to get weak. that is the reason your lamp does not stay on
Posted on Sep 07, 2010
Tv turned off by itself, red light came on. when i turned it back on if had a flashing green light the turned solid green, there was sound but no picture, it turned off again within 2 minutes of turning it...
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
Aug 31, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
When you turn of the TV the POWER indicator flashes green for several minutes. The TV never comes on. After the several minutes of the POWER indicator flashing green, it stops, I hear a click and the...
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
May 11, 2011 | Panasonic PT-52LCX66 Projection Television
LG RU-60SZ30 when turning the tv on the power lite changes from red to flashing amber, flashes 6 to 7 times then turns back to solid red. The tv never actually starts. Before this the tv would randomly...
I have read another solution which may indicate the light engine has failed and will likely need replacing. The cost is quite expensive. $1500 range and apparently the part is no longer available from LG. Best you might do is get an estimate to repair just to be sure.
Dec 04, 2010 | LG RU-60SZ30 60" Rear Projection...
My PT52LCX66 randomly "turns off", the green light flashes for about 20-30 seconds, and it comes back on again.
We had the same problem with our PT52LCX16. After reading some comments from others with the same problem, we put the old lamp that we replaced only 3-1/2 months ago back in as a test, and have not had the problem since. Apparently we bought a defective lamp.
Oct 25, 2010 | Panasonic PT-52LCX66 Projection Television
I replaced the lamo 6 months ago, but thepicture just went off. The green light flashes then the red light fla
If you turn the set on and the green light blinks then the red light blinks and no other sound comes from the back of the set and you cannot hear any fan turning, you probably have a bad Temperature Fuse. It would be locate either under the lamp assy or on the side of the lamp housing. It would be necessary to remove the Optical Block to get access to it.
I hope this helps,
Skyassoc
Feb 07, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
KDF-50a12U Powers off then standby light blinks 3 times
Please recheck Lamp Cover and make sure it is fixed in its space securely as 3 times red blink shows lamp cover error.
There is small safety switch in TV cabinet under lamp cover that has to be pushed by lamp cover if it is fixed in its position properly. That switch is not being pressed by lamp cover and causing this error.
Thanks.
Oct 19, 2009 | Sony BRAVIA KDL-40V3000 Television
Sony kf50wef610-television-replaced lamp about 4 months ago- now will not turn on - green light flashes 6 times- red light flashes 5 times once- then flashes 6 times with 4 second pause between --I am...
I believe the 5 flash error is for the lamp thermostat. It is located (I believe) on the right side of the lamp housing if you were looking from front. It is very small black square with white and gray wires covered in black sheeth. The only way to replace it is from the rear. you probobly need to do a thorough cleaning in there and thats why you've had the lamp, and thermo fail. Remember not to touch the lens of the lamp when working on it.
Jun 20, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Panasonic TY-LA1000 has good lamp, but black screen. light is blinking green, then solid green, then after some time goes red?
We have a PT-50LC14. We replaced the lamp 6 months ago with a TY-LA1000 bulb we bought from a company online (not directly from Panasonic) and it worked for 6 months. Then the TV started turning off on it's own...sometimes it would not come back on for an hour or so. We called the lamp company and we luckily had 1 day left on our 6 month warranty!! They sent us a replacement bulb and the TV would never power on. It would try to power up, but the bulb would never ignite. The power light would flash and then the lamp light would flash every 5 seconds. I had a friend that has the same type of TV and she ordered her bulb directly from Panasonic. I borrowed her lamp and it powered right up. We then called the online company and they sent us yet another replacement bulb, and I tried it today and it works. It seems like these TVs are very particular about the type of bulb used. Next time, we will be ordering ours directly from Panasonic and just paying the extra $100. We have been without our big screen for 2 very long months! I had called a local tv repair shop, called Panasonic directly, and read through countless internet forums, and I thought we were going to have to replace the ballast or get a ballast repair kit and start messing with the circuit board.
Jan 11, 2009 | Panasonic TY-LA1000 Projector Lamp for...
My Sony Wega 60 LCD (model # KDF_60XS955)
below the lamp is a thermal fuse that has opened
Sony Part Number: 191002393
https://www.vancebaldwin.com has them in stock
thanks
scott
May 30, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Samsung HL-S5686W 56" HDTV Logo
135 people viewed this question
Jerry Greenberg
Jerry Greenberg
