Question about HP OfficeJet 6110 All-In-One InkJet Printer
Remove and check cartridge - HP OfficeJet 6110 All-In-One InkJet Printer
    Problem Solver:
  • 17 Answers
This printer should tell you through the computer the ink levels, but the best way I know is to just keep checking the quality of your print jobs. To remove the cartridge though, just pull up the front of the printer and lift up and out on the cartridge.
Posted on Sep 07, 2010
HP printer all-in-one model2410xphotosnart keeps giving me the message to remove and check print cartridges which I have done and both are full. Will not stop blinking and when trying to print makes...
Welcome to Fixya
This means the the printer cannot determine which cartridge is causing the error. Make sure that you are using original HP cartridges.
Please see troubleshooting procedure below:
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts. Click here to see how.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  3. If replacing cartridges fails to correct the problem, click the link at the top of this page to contact HP.
Thank you for using Fixya!
Apr 03, 2011 | HP Office Equipment & Supplies
My F4280 has blinking on light and blinking cartridge lights and the letter "E" in the Start Copy window, cannot scan or make copies but printer part works. Message in desktop says "Scanner Failure" but...
The product uses various combinations of flashing lights to indicate its current status.
  1. Turn off the product.
  2. Disconnect the power cord from the electrical outlet.
  3. Wait 60 seconds.
  4. Reconnect the power cord to the electrical outlet.
  5. Turn on the product
Issue
The Check cartridge light is blinking. Cause one
The cartridge door is open.
Solution one
Make sure that the cartridge door has been completely closed. Cause two
The cartridge is missing or not seated correctly.
Solution two
Insert the cartridge by sliding it forward into the slot correctly. Cause three
The tape was not removed from the cartridge.
Solution three
Make sure that the plastic tape has been removed before inserting the cartridge into its slot. Cause four
The cartridge is not intended for use in this product.
Issue
Solution one
Solution two
Solution three
Issue
Solution one
Solution two
Solution three
Issue
Solution one
Solution two
Solution three
Aug 06, 2010 | Office Equipment & Supplies
Remove and check cartridge message is on. I've
remove the cartridges, turn the printer off, and on again then install them again, and you are done
Apr 17, 2010 | HP PSC 2210 All-In-One InkJet Printer
Won't print: "remove and check color cartridge"
remove your new color cartridge and make sure you have removed the safety tape on the botton of the cartridge.
Mar 07, 2010 | HP PSC 2110 Color Printer
Printer will not print. it read remove and check cartridge.what to check for?
Check for empty cartridge. Check for cartridge NOT properly seated.
Wipe the electrical contacts of the cartridge with swab and 99% isoprophyl alcohol and reseat.
Oct 06, 2009 | HP PSC 2175 All-In-One InkJet Printer
Dial says to remove cartridges and check. Have replaced cartridge
After cleaning cartridges and replacing refilled black ink, I removed blck ink and replaced with HP 58 photo ink. this aborted the "check cartridges freeze". I still cannot align cartridges after removing #58 and replacing with new HP 57. the operation starts but will not complete.
Any suggestions on how to align cartridges?
dunbarj730
May 02, 2009 | HP PSC 2210 All-In-One InkJet Printer
My hp photosmart 2575 says 'ink cartridge problem, remove and check cartridge on right. Refer to printer documentation
open the front cover the cartriges will come in the centre position where you can remove the cartridges check which cartridge is on your right side remove and clean the brown dotted circuit on both the printer and cartridge with the tissue paper .insert it back in the proper position and then check if the same problem then remove and replace the cartride printer will work properly.thanks
Aug 14, 2008 | HP Office Equipment & Supplies
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
    OR
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    Remove and ck right cartridge
    Once remove both the cartridges from the all-in-one and then clean the copper contacts of the cartridges and then put only black cartridge and check for the message displayed on the all-in-one if it even reads check right cartridge then the issue is with the all-in-one hardware. If it reads insert right or color cartridge then the issue seems to be with the cartridge.
    Remove the cartridges from the all-in-one and power cycle the all-in-one and then reset.
    Now insert the cartridge and check for the result. If the issue still persists then check the expiry date on the cartridge and once replace the cartridge and check for the result.
    May 27, 2008 | HP Officejet 7210 All-In-One InkJet...
    HP OfficeJet 6110 All-In-One InkJet Printer Logo
    89 people viewed this question
    Seeker5211
    Seeker5211
