Question about Broksonic CTGV-5463TCT TV
Need menu control
I need to access the menu option screen without using a remote control.
trying to put the tv on channel 3 cause i don't have a remote. I can't find the menu on the tv
  • Anonymous Apr 28, 2009
    NEED TO USE THE MENU, BUT DONT HAVE THE REMOTE...TRYED PUSHING THE BUTTON ON THE FRONT...NO LUCK
  • Broksonic Master
  • 520 Answers
On some tv's holding down one or two of the buttons on the front of the tv for a few seconds will bring up the menu. If it comes up you can probably navigate in the menu with the buttons on the front of the tv.
Posted on May 13, 2008
I don't have a remote control for my RCA TV and it's on channel 2. It needs to be on channel 3 so that It's compatible with my cable box. How do I change the channel without a remote to channel 3. It
U should have a menu button on your tv.If so try to find the channel setup option if you find this you should b able to manually go through your channels to add & delete the channels you want.If not you will have to go out a buy a universal remote.Make sure that it is compatibl to your tv.They should be a list on the back of the remotes pack stating all the brands that the remote is compatible with.I think you should be able to get one for unde 5 dollars.in the pack it should have an instruction manual.some tvs u can set up very easily & some you might have to keep putting in different codes until it works.Hole this could be some help to you.Good luck.
Apr 19, 2013 | Televison & Video
I lost my remote and can't put my tv on channel 3 so I can watch cable tv
If there is no menu button on your TV's front panel, you can't select this option without its remote control.
Aug 26, 2012 | One For All URC4220 Remote Control
How do I set my TV channel to 3 without the remote?
Hi John,
If channel 3 is skipping by the unit when pressing the channel button key at the front panel, it might be accidentally deleted on the channel selection. If you don't have a remote control, there's no way to add it on the selection. All you have to do is to re-scan the channel by entering to Set-up Menu. Press the Menu button key repeatedly at the front panel to show the "On Screen Menu". Select " EZ Program" to automatically finds and store the channels available at your area. Once the scan is finished, you can now watch all the channels available including channel 3.
Please let me know if you need further assistance.
Kind Regards,
Jdvillanueva
Nov 24, 2011 | Zenith C27A25 27" TV
I have a Sony Trinitron model KV27S35, but no remote. How do I program the tv without the remote?
The SETUP button on the case accesses the menu.
Press Channel +   to select Language.
Press Volume -    - now the tv will be reset to factory condition.
Press Channel + to start the AUTO PROGRAM and wait for it to finish.
Press Channel -  to exit it.
That is all. If you need more then all the menu options can be accessed thru the key on the tv.
Aug 17, 2010 | Zenith ZN110 Remote Control
How to reset the parental control code - I forgot the code and want to reset with a new one
This is what I found in the instruction manual on this and I posted it here for you. Try using 3355 for the code and everything else listed here. If that doesn't work, try the very last tip which tells you how to do a factory reset and repeat the first step using the 3355 as the code.
Here's the instructions from manual:
Parental Control
Parental Control allows you to block certain channels or programs so children cannot view
programs that are not age appropriate.
To enter the Parental Control menu, you need an
access code. The first time you enter, use access
code 3355. See "Setting an Access Code" on
page 33 for information on creating a new access
code.
You can set the following options to block
content:
• Channel Lock — Blocks selected channels
• Movie Rating — Blocks movies based on their rating (G, PG, PG-13, R, NC-17, and X)
• TV Ratings — Blocks TV shows based on their rating
• Block Options — Turns on or off all your parental control settings
NOTE: You can use Clear All to unblock the channels and programs that you have set.
NOTE: If the Block Control in the Parental Control menu is enabled, all the sub screens in POP (POP1,
POP3 and POP12) mode will be blank
Setting an Access Code m
After you enter the Parental Control menu for the first time, you can set your own four-digit access
code. If for any reason you lose or forget your access code, you can use the default code.
1 In the Parental Control menu, select Change Code.
2 Using the number pad on the remote control, enter a new access code.
3 Select Exit.
Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset
Jul 28, 2010 | Dell W4201C 42 in. Plasma HDTV
Any way to access on-screen menu on Sharp 13F-M50 without remote
try ebay with the model number; I had the same thing with a sharp set I own---only way to access the menu and do things is with an original remote--if this was helpful please vote for me.
Aug 08, 2009 | Sharp 13VT-K100 13 in. Combo
When i hook up cable and turn on the tv all i get is a blue screen on ch 3. and it wont turn from ch 3 whats up with that...?
You have to setup the tv with using the menu. The tv will need to ''autodetect'' the available channel before it can leave you access other channel. Otherwise you may generally ''force'' a channel by using the remote and entering the channel you wish to liste. (dont you lose the remote!!!) Then in case of major problem if you cant access and navigate in the menu without it, go buy the cheapest universal remote! Take the time and you'll find the trick!
Aug 05, 2009 | Broksonic CTGV-5463TCT TV
No Remote - Need to access Menu
We had the same problem - this worked for us:
1. Unplug TV
2. Press Channel up and Volume up at same time, while plugging TV back in (two person job - it will pull up a service screen)
3. Press Channel up and Chanel down at same time. (Access to menu screen)
4. Use Volume up and Volume down to switch between menu options. We finally found the EZ set up screen.
Somehow in the process we muted the TV and are now working on getting the sound back. :)
Good luck to you!
Apr 28, 2008 | Sharp 25N-M100 25" TV
Accessing Menu Sharp TV
its very easy on the t.v and press on channel up or down on your tv. u will get the screen
Aug 25, 2007 | Sharp 25L-S100 25" TV
RCA T19064 - HOW TO GET TO MENU
i have the same set i used a rca universal remote rcr311w i think its the oem one i bought two of them at walmart i don,t know if they still carry them
Sep 09, 2006 | RCA T13208 13 in. TV/VCR Combo
Broksonic CTGV-5463TCT TV Logo
300 people viewed this question
Top Broksonic Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Broksonic Televison and Video Expert? Answer questions, earn points and help others
