Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
I am having a problem with mold growing on the blower wheel blades of my mini-split. What should I use on this plastic blower wheel to remove it.
    Master:
    Sergeant:
  • 449 Answers
Solution of bleach and water with power turned of
Posted on Sep 08, 2010
Mitsubishi electric Mr Slim wall unit heat and air. strange smell coming out when air is on, we cleaned filters, but do not know where the heat exchange is or the the fan to clean them
Ductless split systems are know for creating a mildew looking "stuff" on the blower wheel. Try to open/move the louvers on the front of the indoor unit. By opening the "osculation blade"/louvers, you can see the blower wheel, normally blue in color. See if it has some mildew growing on it. If so, I found that a tooth brush and about 2 hrs labor does some good. I've found some aerosol spray, called mildew removal. Works great at covering up/controlling the smell. It's also possible that the unit is pulling air from the condensation drain line. These lines can for algae, and give us a sour yuck smell. To clean, use a wet vacuum, and clean from the outlet of the drain line. Hope this helps!
Aug 21, 2017 | Mitsubishi Heating & Cooling
How to replace the blower in a Senville SENA-24HF Mini Split Wall unit?
You have to pump down the a/c and remove the indoor unit. If not
The bottom of front side of front panel there are 3 screws. Unscrew and remove the front panel. Then unscrew PCB board. Then Unscrew the coil, and slightly keep upward and replace the blower.
Sep 08, 2015 | Senville 24000 BTU Energy Star Ductless...
My carrier split ac trip after some time and green light blinking contsly
If this is a ductless split call a tech! The ductless split systems can be a troublesome unit to diagnose. A few things to try. Clean air filters and ensure coil behind is clean. And build up or debris on blower wheel (indoor fan blades) will cause unit to fault. Turn off power at breaker or disconnect and clean (with water hose and medium pressure) the outdoor coil. Be sure you will not damage outdoor coils fins with too much water pressure. Turn power on. If this simple service don't do it again, call a tech! Be sure to ask if they have someone who is experienced with mini split systems and be patient. Even the best technician will need to call carrier for tech support.
Jun 04, 2015 | Carrier Heating & Cooling
How can I fix a vibrating sound on a ecox mini split A.C
IT depends on how old the unit is and the conditions in your area but in split systems the motor is connected to a blower that produces the air flow. This blower is cylindrical in shape with a number of bars that produce the air flow. Over time this blower builds up with debris from the air in you building ( cooking fat--smoke -moisture- etc and is like what collects on the filter. This is what unbalances the blower and has to be removed first. Look up under the opening where the air comes out of and you will see the blower and you will be able to see if it has a build up on the blades. There are ac cleaning products on the market that you can spray in while the unit is operation but be prepared to have to catch the dirty air and bits that will come out. If you have no experience it may be best to get an ac mechanic to come and clean the unit for you.
Jul 17, 2013 | Heating & Cooling
Fujitsu mini split clicking noise from air handler sounds like plastic gears grinding. Doesn't do it all the time
something is evidently in the blower assembly or squirrel cage. If you can get to it, turn the unit off and inspect the blower assembly. you will probably find something easy to remove.
Apr 12, 2011 | Fujitsu Heating & Cooling
Indoor blower unit getting loaded with mold...Y. and how do i stop it.
Mold spores are probably coming from surrounding surfaces... The simple fix is BLEACH...but washing the unit(with the power off) will not fix the problem if you dont kill the mold spores on surrounding surfaces... [simple: the blower circulates AIR,,, MOLD SPORES TRAVEL THROUGH THE UNIT AND LAND ALL OVER IT...] find the source, kill the source... and maybe go see the Doctor, the mold may be in your lungs too...
Aug 17, 2009 | LG LS-L1210CL Mini Split Air Conditioner
BLOWER NOISE
Could be a loose blower wheel. It has slipped and touching the sides of the blower housing.
Turn off the power to the nit.
Remove the 2 bolts holding the blower in place.
Make yourself a wiring schematic.
Remove the wires.
Be careful not to touch the capacitor.
Remove the blower housing.
Clean the blower blades.
Spin the wheel to see where it is hitting.
Loosen the set screw on the motor shaft and adjust your blower wheel.
Mar 10, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
How to clean the blower wheel/housing
Yes you can.
Steps for allure 2/qs2 3/qs3
blade located to the left (squirrel cage)
1.remove filters
2.remove both screws retaining metal plate underneath filters
Now you have room to remove the blade completely for washing.
The blade is only held on by pressure (no tools needed)
When re-installing, make sure the plastic lever on the blade is securely located in any hole on the motor face.
For allure 1
Blade located dead center of the hood
Steps
1.Remove filters
2.Remove pin
3.Remove blade (only held on the pressure) you may have to pull hard
4.When re-installing: make sure the flat side of the hole in the center of the blade is alined the flat side of the shaft of the motor.
Jan 30, 2009 | Broan-NuTone Allure II QS230SS Kitchen...
Broken barrel fan
I am not familiar with the Blueway brand but have never seen an air conditioner on which you could not replace the fan.
Is this a split system or a window unit? If a window unit it may not be worth the trouble.
Jan 29, 2009 | Heating & Cooling
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
625 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
