Question about Maytag Atlantis MDE7400AY Electric Dryer
Mde3706ayw Dryer will run for about 10 minutes and then turn off. I have to wait about 30 minutes. I have tested or replaced the thermal fuses. The dryer will run continuously when set on no heat so I don’t think it’s the motor. Could it be a problem with the timer switch? Thanks, Clinton
  • Maytag Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
DRYER NOT HEATING. Heat Element test good. No visible breaks. Tested the Thermal fuse it was bad so we replaced it. The dryer worked about 5 minutes. So we tested everything again and the Thermal Fuse and...
Somehow you are not getting enough air through the dryer to maintain a temperature below the thermal high temp cutout temp. or there is a control problem for the heating element so it may stay on the 5 minutes but like an oven the thermostat turns the element on and off. I hope you understand. There may be a relay that turns the element on and off, but the contacts have "frozen" or welded themselves together. If so that's your problem. Or there is another device with a similar problem. Unplug, trace the 220vac wires to controls and the heating element. Double check wiring. the Safety devices may be 110vac rated and 220vac is going through so won't hold the power flow. Hope this helps.
Mar 12, 2015 | Samsung DV209AEW Front Load Electric Dryer
Tip
Whirlpool Dryer Various Test Procedures - Part 2
TEST #4 Heater
This test is performed when either of the following situations occur: Dryer does not heat Heat will not shut off
This test checks the components making up the heating circuit. The following items are part of this system:
Harness/connection, Heater relay, Thermal cut-off, Thermal fuse, High limit thermostat, Gas burner assembly,
Centrifugal switch, Exhaust thermistor, Machine control electronics, Gas supply. Dryer does not heat:
1. Unplug dryer or disconnect power.
2. Remove the back panel to access the thermal components.
3. Perform TEST #4b. If the thermal fuse is OK, go to step 4.
4. Perform TEST #4c. If the thermal cut-off is OK, go to step 5.
5. Locate the high limit thermostat. Measure the continuity through it by connecting the meter probes on the
red wire and blue wire terminals. If there is an open circuit, replace the high limit thermostat and thermal cutoff.
Otherwise, go to step 6.
6. Perform TEST #4d. If this is OK, replace the machine control electronics.
Heat will not shut off:
2. Access the machine control electronics, remove the P14 connector, then measure the resistance between P14-3 (red-white wire) and P14-6 (red-white wire) at the connector. If 5–15 k ohms are measured, replace the machine control electronics. If the resistance is greater than 20 k ohms, replace the exhaust thermistor.
TEST #4a Exhaust Thermistor
The machine control electronics monitors the exhaust temperature using the exhaust thermistor, and cycles the heater relay on and off to maintain the desired temperature. Begin with an empty dryer and a clean lint screen.
1. Plug in dryer or reconnect power.
2. Start the Timed Dry cycle.
3. If after 60 seconds, F-22 or F-23 flashes in the display and the dryer shuts off, the thermistor or wire harness is either open or shorted. Unplug dryer or disconnect power. Check wire connections at the machine control electronics and thermistor. If wire connections are OK, check exhaust thermistor resistance per step 5.
4. If F-22 or F-23 does not flash in the display, the connections to the thermistor are good. Therefore, check the exhaust temperature value at any or all of the temperature levels in question, using the Timed Dry cycle, and the following process: Hold a glass bulb thermometer capable of reading from 90° to 180°F (32° to 82°C)
in the center of the exhaust outlet. The correct exhaust temperatures are as follows:
TEMP
SETTING HEAT TURNS
OFF* HEAT TURNS
ON High 155° ± 5°F
(68°± 3°C) 10–15°F
(6–8°C)
below the
heat turn off
temperature Medium 140° ± 5°F
(60°± 3°C) 10–15°F
(6–8°C)
below the
heat turn off
temperature Low 125° ± 5°F
(52°± 3°C) 10–15°F
(6–8°C)
below the
heat turn off
temperature Extra Low 105° ± 5°F
(41°± 3°C) 10–15°F
(6–8°C)
below the
heat turn off
temperature The measured overshoot using the glass
bulb thermometer in the exhaust outlet can
be 30°F (17°C) higher.
5. If the exhaust temperature is not within specified limits, or you have come here from step 3, remove the P14 connector, then measure the resistance between P14-3 (red-white wire) and P14-6 (redwhite wire) at the connector. If the resistance is OK, check P14-3 and P14-6 to machine ground. If resistance is greater than 0 (zero), replace wiring harness. NOTE: All thermistor resistance measurements must be made while dryer is
disconnected from power. The following table gives temperatures and ranges for the associated thermistor resistance values.
Temp
F C
Res
kΩ
Temp
F C
Res
kΩ
50° (10°) 19.0 -22.0 80° (27°) 8.5-10.5 60° (16°) 14.8-16.8 90° (32°) 6.8-8.8 70° (21°) 11.5-13.5 100° (38°) 5.0-7.0 If the thermistor resistance does not agree with table, replace the exhaust thermistor. If the thermistor resistance checks agree with the measurements in the table, replace the machine control electronics.
TEST #4b Thermal Fuse
The thermal fuse is wired in series with the dryer drive motor.
2. Access the thermal fuse by first removing the back panel.
3. Using an ohmmeter, check the continuity across the thermal fuse. If the ohmmeter indicates an open circuit,
replace the failed thermal fuse.
TEST #4c Thermal Cut-Off
If the dryer does not produce heat, check the status of the thermal cut-off.
2. Access the thermal cut-off by first removing the back panel. .
3. Using an ohmmeter, check the continuity across the thermal cut-off. If the ohmmeter indicates an open circuit,
replace the failed thermal cut-off and high limit thermostat. In addition, check for blocked or improper exhaust
system.
TEST #4d Gas Valve
2. Access the gas valve by removing the front panel and drum assembly.
3. Use an ohmmeter to determine if a gas valve coil has failed. Remove harness plugs. Measure resistance across terminals.
on Apr 11, 2009 | Whirlpool LER4634J Electric Dryer
Dryer element where is located
Your Thermal Fuse probably blew, get a Digital Volt Meter from Harbor Freight $5.00, locate the Thermal Fuse and check the OHM's to verify it s the fuse, replace it needed.
Sep 15, 2014 | Kenmore Elite HE4 Electric Dryer
Frigidaire Affinity AEQ6700FSO electric dryer does not heat, then shuts off within 10 minutes.
Hello Scott Joseph Brandt - Since you have already replaced the thermal limiter check your breaker or fuses. Some dryers are run by two separate fuses, one for power and one for heat-ours is. If it is not the power source more than likely the issue lies with your heating coil.
Feb 05, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Dryer will not start, no power
Do you have power at the electrical plug?? If you have 110 volts then sounds like you have a thermal fuse that is blown. Easy repair that should cost between $10 and $20 and should take about 30-40 minutes. This is the most common reason a dryer won't start if it does have power. Make sure to unplug dryer from wall before working on it.
http://www.partselect.com/dryer+open-cabinet+repair.htm
http://www.partselect.com/dryer+test-thermal-fuse+repair.htm
Feb 05, 2011 | Maytag Neptune MDG5500AW Gas Dryer
There is power to the dryer and there is no fuse on the circuit board is there a fuse any were else please help
There is a "white" thermal fuse in your dryer that may be stopping it from running. Unplug the dryer before you make repairs. How to open a dryer cabinet: http://www.partselect.com/dryer+open-cabinet+repair.htm How to test and replace a thermal fuse: http://www.partselect.com/dryer+test-thermal-fuse+repair.htm This repair is a very easy fix. Cost is usually between $10 and $20 on the internet for the part. You will need model number to get the part. Usually takes just about 10 - 15 minutes to replace. Takes more time to take dryer apart than it does to remove the one screw and two electrical spade connections. Very easy here!!
Feb 05, 2011 | Dryers
Dryer keeps shutting off
If it's shutting off while it's running, it's probably the thermal overload fuse tripping and cutting off the power. This could be caused by a number of things, so if you can post back with the following information, I can assist you further more easily.
1. Your brand and model of dryer
2. Does the dryer turn back on quickly or do you have to wait about 15-30 minutes?
3. Is it making any unusual noises?
Thank you.
Oct 19, 2010 | Bosch Dryers
Not enough heat
have you changed the heating coils
Nov 14, 2008 | Kenmore 74602 Gas Dryer
Dryer makes squeaking noise ,then dryer shuts off. mdl.#CYG4000AWW
Hello, sounds like the rear drum rollers are in need of replacement which is causing the motor to get hot and cut out on the thermal cut out. It can be tricky to service if you not handy. Good Luck
Oct 19, 2008 | Magic Chef CYG4000AWW Gas Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
79 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
