Question about Nuova Simonelli Mac 2000 Espresso Machine
No pressure on a Mac cup espresso machine. Water comes out with no pod, place pod in and very littel to no water comes out. Cleaned head several times.
  • Nuova Simonelli Master
  • 1,711 Answers
First you should check if the presure pump is working, with pressure gauge must go up 9 bars, also by the sound you can confirm that is working.
If pressure pump work fine then you will need to desasemble group solenoid valves which they will propably coggled either from scale or dry coffee or both. This proccess is a common sense and if you are able mechanicaly to desasemble parts you can do it your self. Just remove parts by part check if it coggled and the clean it and go to next part folloing the pipework from pressure pump up to grouphead.
A very usfull tool is to take photos of the parts removed so you will have a backup if you forget anything.
Normaly the above proccess must be performed not only if you have a coggled but also for the better quality of coffee.
Good luck
Posted on Sep 07, 2010
I keep getting small cups of coffee.
I have one of these coffee makers also and having the same issue. The machine is getting limed up. Run some vinegar through it. What I found also a little trick is to turn the machine on, place a cup underneath like you were brewing a cup and press the brew button. Let the remaining water come through and the next time you will get a full cup. But this does not solve the issue. Liming seems to be the issue with these makers.
May 14, 2016 | Keurig Coffee Makers & Espresso Machines
Why won't it brew?
Have you cleaned the two little holes in the head?
Mine quit working and I used a paperclip, straightened out, inserted into each hole then ran a cup through, inserted paperclip again, ran another cup of water through, then it worked like new again. These little holes get filled with coffee grounds as they punch through the top of the pod, this is where the water comes out to make your coffee. I now clean these two holes every 3 months or so. Keeps it working beautifully!
Nov 25, 2015 | Keurig K10 K-cup Mini Plus Coffeemaker...
Verismo 580 leaks clear water in spout behind pod spout
Be sure you put the silver lever (embossed with the word Verismo) down before pressing the coffee button. (The small cup illustrated on the top right.
Mar 02, 2014 | Starbucks Single Serve Brewer, Verismo 580
Water does not seem to be getting to the heating area
I'm not sure if your saying it does not brew a cup of coffee at all or it is brewing but only cold water comes out. If it is just sitting there making a whinning noise and not delivering water it may just be dirty. To clean it you need to fill the resivior with a 50% white viniger and 50% water mixture. Run a brew cycle and let it sit for an hour. Then run several cycles through until it is out, refill the resivior with water only, run it completely through and continue with the water only until there is no more viniger smell or tatse. You will need to clean the brewer needle heads as well. Lift the handle to access the coffee pod compartment, remove the pod basket and use a paper clip to clean out the hole in the puncture needle. With the lever still raised, use the paper clip to clean out the three holes in the upper needle head. Replace the pod basket, close the handle and run a couple brew cycles through without a coffee pod.
Nov 24, 2010 | Keurig B100 Coffee Maker
My machine has worked beautifully for several years, but suddenly, I have issues with the group head. When trying to pull my espresso, I get leakage around the rim of the group head. Sometimes coffee...
I have had the same issue, this is just the group head gasket that needs to be replaced. I got all the parts and I am going to try and replace it myself
Jun 09, 2010 | Pasquini Livia 90 Espresso Machine
Will not dispense the water into the cup when the button is pushed
I have had this issue. First, check to make sure water tank is filled and correctly in place? Try descaling it; a kit came with coffee maker. (It just removes hard water build up, it may be blocking your water flow.) If that is not the issue, pull the tray where the used pods are dropped -Is it wet? Like the coffee is pouring into this tray rather than in your cup? If so, I have removed round silver plastic piece from around coffee spout,(gentle -do not crack it) then removed and washed the black spout, I even used a toothpick once, to remove the stubborn coffee ground, Once it was cleaned - it worked perfect. If you run water from the faucet into spout it should flow smoothly. I warn you though, not sure what this does to any warranty, but don't mess with my morning coffee! If the POD tray is not wet, I would tell you not that most likely your machine is not clogged by grounds, so you may not want to take snout apart. I hope this helps.
May 02, 2010 | Nespresso Essenza C100 Espresso...
I have the Keurig Gourmet Deluxe Home Brewing System #B60 When the pod is in place with the cover down the water won't come out while brewing. It will not make a brewed cup of coffee. If I remove the pod...
Check that pod has a punctured hole on BOTH ends.. If the bottom or to wear not punctured this will happen with most Keurigs.
Replace the pod holder if defective.
May 18, 2017 | Keurig Coffee Makers & Espresso Machines
Cuisinart EM 200U expresso machine instructions
Slide water chamber out and put filtered water in it - i would make only 1 cup at a time, so fill only to the minimum fill line. Most tap water will overpower the taste of the espresso. Use grounds, not pods - podded espresso will come out too weak. I would suggest using the double filter cup instead of the single - doubles can be ordered from Cuisinart website.
Here's a link to the manual:
http://www.cuisinart.com/share/man/579_man.pdf
-Tha Mp3 Doctor
Nov 15, 2008 | Cuisinart EM-200 Espresso Machine
Pressure but no water
Make sure your filter is clean, take the filter and head it to light. If it is clean then you can see a little hole in the midle.
Aug 09, 2008 | Breville ESP8XL Espresso Machine
Nuova Simonelli Mac 2000 Espresso Machine Logo
Top Nuova Simonelli Coffee Makers & Espresso Machines Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Nuova Simonelli Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
