Question about Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White
Model # FFU1464DW2. How many cubic ft. is this? Thanks
How many cubic feet is model #EV190NXWN00?
The 19 in the model is the cubic ft capacity of that freezer.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Apr 16, 2016 | Whirlpool Freezers
How do I work out the storage capacity in liters for my fridge Frigidaire FPC523TEW1?
Hello Howard;
My name is Peter. I am a retired field service refrigeration technician.
Near the top side wall inside your freezer there is a label that gives you the exact cubic feet. Your model number has a rounded off cubic of 23.
So,
23 Cu.Ft. x 28.316 = 651.218 Liters.
Mar 13, 2015 | Frigidaire Freezers
What is the fridge capacity in liters?
Hello Howard;
So,
Mar 13, 2015 | Freezers
What is the cu ft for frigidaire upright freezer mfu21m3gw1
Thank you for your post, friend!
I see you would like to know the cubic footage of your Frigidaire freezer. Based off the model number you have provided it appears that you have a 21 cubic foot freezer. Hopefully this information is helpful. -Matt
Feb 20, 2015 | Frigidaire Freezers
What size is a frigidare 297080400 upright freezer
Hello friend, thank you for your post!
In order to provide you accurate information could you provide me with your model number please? Normally you can locate the serial tag (which lists your model number) on the inside wall of your freezer. With that information I can provide you with the cubic ft. of your freezer. I look forward to helping you further. -Matt
Oct 04, 2014 | Frigidaire Freezers
MAYTAG FREEZER CAPACITY
I cannot find a MQU8057AEW in the Maytag library. I did find a MQU2056AEW that is 20 cu ft.
May 05, 2010 | Maytag 20 cu. ft. Upright Freezer MQU2056B
I have a Frigidaire commercial freezer model # FFU1464DW2. It was bought brand new, used for a few months, then unplugged and sat. I want to sell it but i don't the resale value. Do you have any...
if the unit still works and looks new i would say knock off about 100 dollars of the price you paid for it and this should be good enough for some who wants it or at least sell it for 200 to 300 dollars
Jan 22, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frigidare Model No. FFU1464DW2 is leaking water on ground floor, can you tell me where to find the drain pan and what is causing this? Many thanks.
Most likely it is leaking because the drain in the back of the freezer is clogged. The most likely source of excessive water drainage is a bad door seal which causes frost to build up.
Nov 19, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Need info on chest freezer serial number 48H2091PSSO-12902566 We don't know the brand or the cubic ft. of it. It is at least 30 yrs. old. Any information you can find on it would be very helpful. Thanks....
A freezer this old will be difficult to find any information on.
There is another number that you might have more success with. Look at the back of the freezer, and there should be a removable plate that will allow access to the compressor. There should be a manufacturer's tag on the compressor with model#, serial#, date of manufacturer, etc for the compressor itself. With the freezer being as aged as it is, the compressor manu. may not have information there either.
Cubic feet can be eyeballed, or measured out. take a tape measure and measure the width of the interior compartment. Then measure the length, and height. For this purpose, ignore the hump or box where compressor sits. Length * Height * Width = cubic feet (if you measured in feet). If you want a more exact number, also measure the compressor hump as well, and subtract that number from the first.
Good Luck!
Nov 02, 2009 | Freezers
Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White Logo
535 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
