Question about KitchenAid Dishwashers
Spring on door for soap dispenser jumped out of its home. Now the despenser door won't stay closed. dtalcott180@gmail.com
  • KitchenAid Master
  • 909 Answers
Once the spring is missing, it never really becomes reliable. It isnt a train smash to replace but one has to be fairly mechanical minded. Firstly., remove plug from the wall socket then open the dishwasher door and remove the screws on the sides of the inner stainless steel panel.(about 12.) Once screws are out you can seperate the outer panel from the silver door. You will then see the soap dispenser from the inside.(Either screws are holding it in place or little clips.) Possibly it will have wires connected. Disconnect and take note what goes where. Once dispencer is off, reinstall new one in the same manner. You can but the spare part from the appliance repair dept..(Quote the model of the unit).
Posted on Sep 07, 2010
MY SOAP DOOR WONT STAY CLOSED
Soap dispenser latch problem.
a) Look at the latch whether there is build up of soap. CAREFULLY clean it. It might work.
b) If not just replace the whole dispenser unit. Not worth wasting time on trying to fix the spring problem. Most dispensers are $ 50 ~ $ 100 price range.
Sep 26, 2014 | Dishwashers
Ge nautilus dishwasher 165d5450p004 latch won't close
RoselsRose,
Thanks for the info about your grandson coming bye the dishwasher and messing with the dial! My son (14 month old) did the same thing and the soap dispenser door/latch would not stay closed. It just kept springing back open. I thought for sure the latch was broke until I saw your post and went to the outside dial and brought it back to off. Sure enough, the soap dispenser door stays closed. You just saved me an expensive repair! Thanks!
Sep 26, 2012 | Dishwashers
The soap despenser is broken. looks like the spring is inside the holder and it will not close....stays open at all times. model number for our dish washer is 665.13842k601.Kenmore ultra wash. is this an...
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101 '';
Aug 01, 2011 | Kenmore 24 in. 15932 Built-in Dishwasher
Whirlpool quiet partner I soap dispenser won't close
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these.
Hope this helps...
Daniel
May 18, 2011 | Whirlpool Dishwashers
The ice maker on my Kenmore refrigerator freezes up when it despenses ice. I've defrosted it several times, but within a few days the dispenser is frozen up again. I think the flap that dispenses the ice...
Maybe the "spring" system of the dispenser lever is faulty, try open it and closing with your hand and see if it will stay close on its own.
But yes you are right, it freezes because warmer air is entering though the dispenser
Jan 10, 2018 | Refrigerators
Soap dispenser cover latch will not stay in the hole. So now the soap holder will not stay closed.
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Jan 31, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Soap dispenser unlocks but won't open
unscrewed and opened inside of door panel. Saw that spring was out of place, fixed, and reclosed. Working now.
Oct 26, 2009 | GE Dishwashers
Soap dispenser cover won't close
It sounds like it may be stuck between cycle steps.(this sometimes happens if the washer is open during a cycle)Try and run it through one full wash cycle as it is.Then check to see if the soap door will close.If not,the lack may be broken
Jan 09, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Ice maker dispenser door
you need an ice duct door spring and selenoid call ge at 800-851-6200 about 40 dollars for parts they go in the freezer door despenser area
May 07, 2008 | Hotpoint FFU00 Side by Side Refrigerator
Soap dispenser door not catching properly
THE INNER DOOR PANEL HAS TO BE DISASSEMBLED TO ACESS THE SOAP MECHANISM NO IT DOESNT JUST PULL OUT
Jan 16, 2008 | Hotpoint 24 in. DWF61 Built-in Dishwasher
Dishwashers Logo
41 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
