Question about Zebra LP 2844 Thermal Printer
LP2844 will not print tags - just memory dump. And when it was working it skipped every other tag.
5 Suggested Answers
dugiehowsa
  • 114 Answers
SOURCE: Letra Tag QX50 Error 1 message
The user guide lists all the error codes and possible solutions. http://download.dymo.com/media/UserGuides/QX50US.pdf Error 1 indicates a tape jam or low battery. To resolve, try removing the cassette and clearing the tape or replacing the battery.
Posted on Sep 21, 2006
SOURCE: Zebra TLP2844 Prints Centered and Half the Width
create a word template document with the page size the same size as the label. Set the margins to 0 and fill the label up with text. This should make the printer print right the way over the bale.
Posted on Jan 27, 2008
PABLOCSA
  • 1124 Answers
SOURCE: LP2844 printer only prints after reboot
Probably you have some conflict on your printer ports. Go to your installed printer (Printer folder) and select one of them, >> righ click >> go to properties >> Ports
and see which port is taking the first printer, which is taking the second one and which the third one. It is problably than 2 of them are using the same port. (Virtual USB)
Posted on Oct 03, 2008
  • 31 Answers
SOURCE: My Zebra LP 2844 printer is not aligned and the
Calibrate the media that is in the printer. Power the printer on while holding the feed key. When it flashed red, let go. It will calibrate, print a config label, then go into dump. Press the feed key again to exit dump. Once this is complete, your printer should advance only one label at a time when you press the feed key. If this is working as expected, but the labels are not printing right when you print from you application, there is a problem with your format or driver settings.
Posted on Jan 31, 2010
Printer giving supply memory error
Try this:
10.XX.YY SUPPLY MEMORY ERROR
For help press
The device cannot read or write to the print cartridge
memory tag, or the memory tag is
missing.
1. Open the cartridge door.
2. Remove the print cartridge, and then
reinstall it.
3. Close the cartridge door.
4. Turn the device off and then on.
5. Verify that a genuine HP print cartridge
is installed in the device.
6. Install another print cartridge.
7. Verify that the memory tag PCA is
8. Verify that the memory tag connector is
firmly seated in connector J510 on the
ECU. You might have to remove the
main cooling fan to see this connection.
9. If the error persists, contact HP Support.
Jun 28, 2011 | HP LaserJet P3005 Printer
Colors are wrong. Cartridges say I have plenty of toner in each of the 4 ...but when i print the colors are not right. I did a color test and the yellow is barely visible. How accurate are the sensors that...
Each cartridge has a "memory tag" that keeps track of the cartridge use. It is highly unlikely that all 4 memory tags are bad. Are you using HP cartridges?
Have you calibrated the printer? Do a full calibration.
It is possible that the DC Controller is bad. Each of the "memory tags" reads and writes to the DC Controller. The DC Controller also determines which colors get printed. Have you changed the ITB (Intermediate Transfer Belt)?
Mar 31, 2011 | HP CP3525N Color LaserJet Printer
My Zebra LP 2844 printer is not aligned and the info on the tag prints onto the next tag, how do I fix this?
Jan 07, 2010 | Zebra S4M Thermal Label Printer
Zebra LP2844 printer prints garbage
Sounds like you might be using a bad driver, or the printer is in dump mode.
Try hitting the green button and see if it says exiting dump.
If still having trouble, inside the printer it tells you that if you are having printing trouble:
  1. turn off the printer
  2. Hold down the feed button
  3. turn on the printer and at the third red flash release the feed button
  4. it will then feed some pagessome info and ask you to hit feed again to exit dump
  5. hit feed again and it will say exiting dump
This process re-reads the label length (so only do it with the labels you want to use in, or it will waste labels until you do it again with those in it) - but I'm suggesting it only because it enters and exits dump mode (which I have read can cause the garbage when you try to print).
Mar 06, 2009 | Zebra LP 2844 Thermal Printer
Zebra TLP 2742 printer only prints out left side of the tag ???
Ok
First Properly connect all cables to new PC.
download new latest printer driver form given link blow
http://ftp.nicelabel.com/software/drivers/zebra.exe
download and install the new driver and try to print.....
if any problem persist please tell me ..what the OS you use in ur new Business pc.
well dear you POST ur this Question on "YahooAnswer" and "http://boston.craigslist.org" that great
may be it is helpfull to you.
happy to help u..
Nov 21, 2008 | Office Equipment & Supplies
TLP 2742 printer only prints out left side of the tag??
either your ink level is low or empty , or you might be having a problem with the wire strip that goes to the printer head, or even a faulty ink cartridge ( you can only get so many prints on each ink cartridge) how lomg have you been printing on the cartridge? have you tried to clean the cartridge?
electech
Flashing red light
Hi Quadralady,
I found these possibilities listed in the manual:
1. Perform media length sensing.
2. Possible problem with label stock. Use only approved
labels and tags.
3. Possible label jam.
4. Insufficient memory for label size. Check the printer
memory configuration.
5. Possible software problem. Refer to the programming
manual.
Apr 16, 2008 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 Thermal Printer Logo
96 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
