Question about Trendware TEW-432BRP Wireless Router (TEW432BRP)
Can't get Trendnet TEW-432 router to connect to internet with motorola modem
Hi. We recently moved and got a new DSL connection through AT&T. Before we moved, we had DSL through Windstream and were using the Trendnet TEW-432BRP router. We never had any problems with it. Currently, we have no problems getting internet with the modem hooked up directly to the computer. However, with the router connected, we cannot get internet access. I tried calling Trendnet tech support and they had me reset the router and then try accessing the internet with my modem connected to the WAN port on the router and then the router connected via port 4 to my tower. When I still had no internet connection, they told me I needed to call my internet provider to put my modem into bridge mode with the router. I'm confused as to why we're having this problem now. Is this bridge mode what is really necessary here?
I had this same problem. I was going to go ahead and call ATT and ask them to put my modem into bridge mode, but I messed around a bit more....
I went ahead and turn on PPPoE...tried to run the set up again. Well it worked. Not the internet connection is working through the modem. For some reason, the setup changed PPPoE back to DHCP Client, but it's working now. Give this a shot before calling ATT if you like. Good luck.
Posted on Jun 18, 2009
Yes, the bridge mode is really necessary!
Posted on Jul 27, 2008
I have dsl modem routeur dhcp enabled with ap wifi ssid = x everything ok ip 192.168.1.1 i have tew 637ap n upgrader wire connected on dsl modem router with static ip 192.168.1.20 ssid = y everythings...
You may be trying to connect through a G or B device to your N router. Verify that there are no serious obstructions or that the pc is not underneath something or enclosed. Metal near the pc can cause the signal to lose strength. Not having a wireless N card or adapter can also cause this.
Also if you are trying to connect through ethernet cable verify that windows is being assigned an automatic ip address, if it is static in windows change it to automatic.
Apr 29, 2011 | Trendnet TEW-638APB 300Mbps Wireless N...
Error 103
This may or may not be of help, but this is easy enough to try....
Power off computer, cable modem, and router.
Connect router to cable modem via WAN port, PC to router via LAN port
Power up cable mode first, wait until for connection light
Power up the router, wait about a minute
Power up the PC
I have Cablevision and have had an issue when you are going to connect a different device directly to the cable modem (eg router instead of PC), you need to reset the cable modem first or it will not work.
The following link shows you how to log directly into the router and run the setup Wizard from the router.
http://www.trendnet.com/kb/kbp_viewquestion.asp?ToDo=view&questId=1442&catId=524
Apr 09, 2011 | Trendware TRENDnet TEW-432BRP Cable/DSL...
How to connect tew-432 brp to MT800 modem for a wireless connection
you can connect your Ethernet cable from tew-432brp to MT800.
if serial ethernet cable not work you can check with cross cable of ehetrnet also.
Mar 30, 2010 | Trendware TRENDnet TEW-432BRP 54Mbps...
I can install my router on my laptop
Please give additional information; Router brand and model, computer OS, Internet Connection provider and Modem connection (cable or DSL). I will be needing this information for me to assist you with this concern.
Mar 28, 2010 | Trendware TRENDnet TEW-431BRP Wireless...
How to change password for Trendnet TEW 432BRD wireless router
First RESET your router to defaults.
for that press RESET button for 10 seconds RESET button is in back side of router.
Then connect your router to computer with ethernet cable.
Then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page of router.
Set WAN settings as your internet service provider settings.
Enable DHCP .
CLick on wireless and enable wi fi.
If you want secure router then enable WEP security then add new code it is your password key for connect wi fi.
Let me know if you need further assistance.
Thanks.
Nov 06, 2009 | Trendware TRENDnet TEW-435BRM 802.11g...
Problem using Wa1003A and Tew 432 brp to share my internet
lan wires are the same. lan wires used to connect your computer to your modem can also be used to connect your Wa1003A adsl router and TEW 432 brp.
you just got some things mixed up.
1. you should set your Wa1003A adsl router to bridge mode. At this point, it will just be "pass through" device and will not be the one who will ask for IP adds from your ISP.
2. configure your TEW 432 brp with your pppoe username and password. Your TEW 432 brp will now ask the network for the IP address to that it can connect to your ISP.
3. leave your lan wires the same.
Apr 24, 2009 | Trendware TRENDnet TEW-432BRP 54Mbps...
11g wireless adsl modem router tew-435brm
virgin media is dsl not adsl which is the router you had
Nov 27, 2008 | Trendware TRENDnet TEW-435BRM 802.11g...
How to solve it???
your trendnet is just a router and it should work with any ISP whether if it's cable or dsl. you just need to connect it to the broadband modem provided by your ISP and configure with the correct settings.
with cable conncetion you just simply connect the ethernet(LAN) port of the modem to the internet(WAN) port of the router. then perform a power cycle by turning all the devices off. after that, turn on the modem first and wait for the lights to lit up before powering on the router and the computers. if this will not work you need to access the router's page and perform a mac address clone.
for dsl connection, you need to get the username and password of your internet account from your ISP then set your router to PPPoE or PPPoA.
you need to also check that your modem and your router has different ip addresses to make them connect to each other properly.
hope this'll help you but if you still have the same problem, just give me the exact model of your modem and who is your ISP
ciao!
Aug 01, 2008 | Trendware TEW-432BRP Wireless Router...
Trendnet TEW-432BRP
What exactly is the problem? Are you using Cable or DSL internet? Did you connect the cable from the modem to the WAN port on the router and the computer to the LAN or 1 port on the router?
Jan 07, 2008 | Trendware TEW-432BRP Wireless Router...
Trendware TEW-432BRP Wireless Router (TEW432BRP) Logo
1,827 people viewed this question
Top Trendware Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
