Question about Samsung SyncMaster 740N 17" LCD Monitor
Low resolution - Samsung SyncMaster 740N 17" LCD Monitor
  • 1,179 Answers
You will be able to increase the resolution of your desktop by going through my published guide entitled How to set your Desktop Screen Resolution?
All the best!
damnor01
Posted on Dec 16, 2010
How fix computer monitor stuck in low resolution
If your resolution is too low, you can change that by clicking on the Start button and then clicking on Control Panel. From the Control Panel window, click on Adjust screen resolution from beneath the Appearance and Personalization section. From the Resolution drop-down, select the highest resolution by moving the slider to the top. Your resolution should be just fine now.
To change your font size, go back to Control Panel, search for "window color" in the search box, and then click on Change window colors and metrics". You can adjust font sizes from here.
Jun 08, 2014 | Microsoft Windows 7 Ultimate for PC
Screen flashes colors
The issue (flashes" colored screens) you're facing could be related to drivers and could be resolved by updating the display drivers. Without the correct driver, the hardware or device that you want to use won't work properly.
Also refer to:
http://windows.microsoft.com/en-us/windows7/update-a-driver-for-hardware-that-isnt-working-properly
Let's try to boot the computer in low resolution mode and check the issue status.
Low resolution starts Windows using your current video driver and using low resolution and refresh rate settings. You can use this mode to reset your display settings.
Refer the section:
Enable low-resolution video (640×480)
Apr 24, 2014 | Microsoft Inspiron Notebook
Why low resolution?
Uploading them via the SD card will have no effect on the resolution.
There is a difference between image grain and image pixelation.
If the resolution is too low for the size you are printing the image will pixelated, meaning that it will be made up of lots of little squares.
If the image is grainy it may be that you are shooting images in low light at a high ISO setting on the camera. Typically with the lower end Canon cameras anything above 800ISO will start to look grainy.
Jun 19, 2012 | Canon EOS 500D / Digital Rebel T1i Digital...
I have very low resolution.
Hi betty2293,
Low resolution on your desktop can be for two reasons ,
  1. You have chosen a low resolution from your desktop properties, you need to check this up , by right clicking anywhere in a free area of your desktop , then selecting properties --> settings tab and then you find an option to change the resolution.
  2. If you don't find multiple options to select that means, it's because of no video drivers installed.
  3. Therefore you need to use your motherboard supplied CD to install the VGA/Video drivers and things should work fine for you and you will be able to find multiple resolutions in your settings tab which I described above.
Hope this helps...:)
Aug 23, 2011 | Computers & Internet
Windows 7 screen goes to large resolution and needs reset on startup.
Turn on the PC. Press F8 at booting into windows 7. It will display  many options
Select the Enable low resolution video(640x480) then login to system.
then change the resolution as required
Right click on a empty space on the desktop and click on Screen Resolution.
Enable low resolution video (640 × 480)
Jun 08, 2011 | AOC 718Swag-1 LCD Monitor
My system is workin properly but the screen resolution is very dim it seems to be very light ..... even we can't read any thing on that. i checked my monitor with another cpu its working properly can...
IT IS NOT HARDWARE PROBLEM
Change screen resolution
Screen resolution refers to the clarity of the text and images on your screen. At higher resolutions, items appear sharper. They also appear smaller, so more items fit on the screen. At lower resolutions, fewer items fit on the screen, but they are larger and easier to see. At very low resolutions, however, images might have jagged edges.
For example, 640 × 480 is a lower screen resolution, and 1600 × 1200 is a higher one. CRT monitors generally display a resolution of 800 × 600 or 1024 × 768. LCD monitors can better support the higher resolutions. Whether you can increase your screen resolution depends on the size and capability of your monitor and the type of video card you have.
21b7b862-a70d-43aa-a281-e00c38a8078d.pngText and images are sharper and smaller at high screen resolutions
2aca9658-0ee7-4b8d-a582-cac335550f26.pngText is larger and easier to read at low screen resolutions, but images are blocky and fewer items fit on the screen
  1. Open Display Settings by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Display Settings.
  2. Under Resolution, move the slider to the resolution you want, and then click Apply.
Nov 13, 2010 | Intel D945GCCR Motherboard
Screeen Resolution too low
600x800 for printer.
go to control panel display properties settings tab
click on advanced. click on monitor tab and uncheck hide monitors
uncheck hide modes
click ok. change resolution to 800x600.
Nov 25, 2009 | HP Mini 1000 Netbook
The resolution is low
Hi...
Do you know how to change your screen resolution go to "Start / Control Panel, then Switch to view category, then double click display, click settings, change your resolution to 1024x768
Hope it may helpful for you!
Regards
ICmanServer
Jun 30, 2009 | Computers & Internet
Low resolution screen
have u loaded the display drivers?
right click on the screen and go to properties and on the last option settings go and change resolution
May 06, 2009 | Dell Precision 360n PC Desktop
Samsung SyncMaster 740N 17" LCD Monitor Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
