Question about Toshiba e-Studio 350 Copier
Stapler we have a Toshiba E-Studio 352 copier and it keeps telling me to check the stapler. The stapler has staples in it but won't recognize it.
  • 43 Answers
Please make sure that there are no staples jammed in the unit,
take the staple cartridge out, release the leaver on the staple cartridge and remove the first sheet of staples, close up the leaver, and reinsert in the copier.
then try to staple again
Posted on Jun 01, 2008
My stapler won't wrap staples around the paper. What can I do?
Amazon.com : The Classics Staple-Free Stapler the "Paper ...
www.amazon.com/The...Staple-Free.../B000IGCUZE
Amazon.com, Inc.The Classics Staple-Free Stapler the "Paper Grip" with 5 Sheet Capacity, Kid Safe (TPG-133). by The ... Gift-wrap available. Enter your ..... It is hard to get the correct pressure on the paper--too much and it tears, not enough and won't fasten.
PaperPro Prodigy One-Finger Desktop Stapler, 25 Sheet ...
www.amazon.com/PaperPro...Stapler/.../B000GGY9L...
Amazon.com, Inc.
Rating: 4.4 - ‎399 reviews
Gift-wrap available. ... One-Finger Stapling Technology only needs one finger to stapleup to 25 sheets ... The Paper Pro Prodigy Stapler is the most distinctive, powerful non-elictric stapler available. .... This is such a great, easy to use, and quality stapler that once you use it, you won't want to use a ... A near-great stapler.
Swingline® Full-Strip Stapler, 15 Sheet Capacity ... - Staples
www.staples.com > Office Supplies > Office Basics > Staplers
Staples Inc.Stapler can easily handle up to 15 sheets of paper at a time and has ... refill this Swingline stapler with a full strip of standard office staples, so it won't run out of ...
Staples One-Touch™ Plus Desktop Flat Stack Full Strip ...
Jan 10, 2016 | Swingline 87845 Optima ® 40 Desk Stapler
Replace a staple unit in a di 3510 minolta copier
Sattle stich stapler or the corner stapler.
Corner is inside the machine open the front door turn green knob to bring stapler out then remove the blue/green cart. do not throw a way you will be replace the staple not the whole cart.. Sattle stich is the stapler that make you booklet with to staples in the middle. will be up on top of the finisher but under it same deal do not cast away replace staples only and make sure that you pull out the top section and reseat so the copier knows you replace those staples
May 27, 2014 | Minolta bizhub 250 Black and White Copier
Our staples won't go all the way through . We
You didn't list the make and model of your stapler but if it's not driving the staples flush with the surface here are some possible causes:
1. The wood; If you are driving long staples into hardwood or knotty lumber you may have to use shorter staples to see how they set.
2. Stapler settings; Turning the air pressure up isn't the answer to driving staples deeper, it is only harder on the stapler. Most staplers work in the 90 to 120 psi range. The lower pressure you use the longer your stapler will last. Check/adjust the depth of drive control on the stapler to determine where the top of the staple is driven to.
3. Broke stapler; If it's not driving them to the proper depth but the level they are driven to is consistant, you may have a damaged piston o-ring/seal or the end of the driver is broken off. You'll have to go into the gun or take it to a service center to check these things.
Mar 04, 2012 | Air Tools & Compressors
What part do I need to remove to make a bostich MIIIFS floor stapler to shoot 2 inch staples
You shouldn't have to do anything to the MIIIFS flooring stapler to shoot 2" staples. It is designed to shoot 1 1/2" to 2" staples right out of the box. If your stapler won't feed 2" staples, check the magazine all the way up to the power head for any foreign material that may hold up your staples.
Apr 26, 2011 | Stanley Bostitch STB-MIIIFS Flooring...
I can't seem to reload staples into this stapler. I used the staples that came with it and it worked fine. I try reloading and it doesn't staple.
With the stapler sitting a solid surface, turn it 180 degrees so it is pointed away from you, and you are looking at the back. Press down on the plastic extension that you see (about mid-height on the stapler). This releases the staple-holding compartment (it shoots out the front of the stapler). Reload it with standard staples, push the compartment back in place until you hear a click. Voila!
Apr 15, 2011 | Staples One-Touch DX-3 Desktop Flat Stack...
Our Canon NP6035 copier won't staple. It had a jam in the stapler, which I removed. We installed a new staple cartridge. The stapler makes indentions in the paper, but it won't advance any staples.
Do you have a 10 or 20 bin finisher? I'm guessing you have a 10 bin. Did you install the stapler cartridge in correctly? There is a small black plastic gear that cracks and the stapler will not work. The two way's to solve the problem is to replace the gear or the stapler unit. Both may be had to find. Good Luck
Aug 24, 2010 | Canon NP 6035 Copier
I have a Ricoh Aficio 1035 stapler problem.
if you press the finishing button on the display does it so stapler function there ? or try taking the staple cartridge out and then close the door on the finisher and see if it says out of staples. if it does it knows it has a stapler unit.
Jan 20, 2010 | Ricoh Aficio 1035 Copier
Stapler constantly shoots out staples even when there is nothing to staple.
There is a contact switch / lever on the staplers that engages the stapler when it is pressed. It must be stuck. locate the lever and see if that's the case, and release it if you can. just my 2 cents, because I'm a copier/fax tech -not a stapler expert :)
May 04, 2009 | Office Equipment & Supplies
Toshiba e-Studio 350 Copier Logo
254 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
