Question about Whirlpool Duet GHW9150P Front Load Washer
The washer runs for about 3 minutes and flashes 06 then F?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F06 in your whirlpool duet indicates that the control is unable to properly detect the motor speed and so the washer shuts down. This usually occurs during high speed spin and the door will be unlocked after 3 minutes. To resolve this issue you’ll have to check the wire harness connections between the Driver motor and the Motor control unit (MCU). If that is fine then check the connection between the MCU & central control unit (CCU), replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 07, 2010
Washer beeped a few times then stopped and is flashing F then 06 i don't know if the 06 is time remaining or part of the code
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Jan 14, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Flashes F 06
f 06 can be a major diagnostics problem, here are the details,
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
• Check the MCU
Replace failed component, usually the CCU
Sep 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F is flashing and 06
Press PAUSE/CANCEL once to clear code. Press START
Aug 12, 2009 | Kenmore Washing Machines
Washer stopping and flashing F 06 fault
F/06 ---- ERROR IS FOR ----------- Drive Motor Tachometer ErrorThe control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.----------
AND TO SOLVE THIS ---------Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU) --
Check the MCU
Apr 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WHIRLPOOL GHW9150PW4 DUET WASHER DOESN'T SPIN AFTER START
F/06 Drive Motor Tachometer Error
  • Check the MCU
Mar 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Help! Mt Kenmore Elite Quietpak2 HE3 keeps
  • Check the MCU
Mar 10, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
WASHER STOPS WORKING AND FLASHES 06 F
F06
Drive motor tachometer error
Potential Causes
• Check the MCU
Replace failed component.
Jan 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Model 110.45962.400 code comes up f 06
The following link explains the "F06" error code on a Kenmore Elite:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
In a nutshell, the error is an indication of a Motor Speed problem. This means there is a communications problem between the Central Control Unit (CCU) and the Drive Motor or Motor Control Unit (MCU).
However, before assuming there is a problem, unplug the washer for at least 30 minutes. In some cases the washer can experience momentary computer glitches. The 30 minute interval is necessary to reset the computer. Sometimes this is all that is required to clear some error codes.
If the error code returns following a reset, follow the advice given in the link to determine the fault.
I hope you find this information helpful. If you require additional assistance, please let me know.
Sep 27, 2008 | Kenmore Elite 45986 Front Load Washer
HE3 Code F032
I remove the pump and found out that the impellor was worn , I have replaced the pump and the machine is working , no more F02 Codes .
Nov 14, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal De
