Need wiring diagram for the internal switch of a Singer Electromode 3k heater, model # WA-30, Catalog # 4990-N
Natemane
SOURCE: ROCKER SWITCH DIAGRAM
On the top of the switch (inside the heater) there is a common connection.....even though it looks as if it is connected (electrically), it isn't electrically affected by the switch; it's just used as a post. It's just the place where the striped wire connects to the "common" point for the heater coils (they are in a parallel). Also, while you're in there you might want to put some electrical grease on the exposed conductors.....mine had quite a bit of corrosion (which was the reason for the failure). I had to replace 3 of the female connectors.
Posted on Jan 01, 2010
Buffalo12980
  • 625 Answers
SOURCE: connecting 240 volt singer baseboard heater
Power from your panelbox goes to the wall mounted thermostat. From there a two wire goes to the heater. In the heater one overload wire goes to the heater. the other overload wire goes to one side of your LINE. the other wire goes to the heater wire.[LINE]
Posted on Nov 29, 2007
SOURCE: wiring diagram for Dimplex wall heater Model 6100770000
installing a wall mount heater not sure on the wiring .heater has 3 wire black red and blue sources has white and black what wires go together
Posted on Dec 11, 2010
  • 3289 Answers
SOURCE: twin star international fireplace model cfs s505
The company has a web site that can assist with manuals, parts, etc. here.
In order to find info on their site, the year of manufacture is needed (but I couldn't find your model number). If your's is older than a 2004 model - you need to contact customer service directly.
Call or fax directly:
Phone: 1-866-661-1218
Fax: 1-561-665-8111
Hopefully, this will get you what you need. Good luck!
Posted on Dec 27, 2010
  • 4736 Answers
SOURCE: I HAVE 2400 WATT DIMPLEX
20 years old! I serious doubt that there is an Owners Manual or schematic still in existence, However, if you want to give it a shot call DImplex Customer Support to see if they can help you.
If you live in the UK call 0845 600 5111
If you live in the US call Dimplex Technical Service 888-346-7539
Hope this helps you find what you need.
Posted on May 24, 2011
How can I connect to replace an old Electromode thermostat that has 2 black and 2 white wires?
The packaging for the most recent Honeywell thermostat I installed has a "Consumer Helpline" telephone number of 1-800-468-1502. You also might try a Google search using the model number.
Mar 14, 2016 | Honeywell Programmable Thermostat Heater
Wiring diagram
In cavity 1, the 30 amp fuse has no power with key on? A wiring diagram shows that fuse gets power right from a wire from the ignition switch, with key on.
Wiring diagrams here: http://www.bbbind.com/tech_database.html
You just have to agree to license agreement, go to "technical information". To TSB's and wiring diagrams: enter year, make, and model-make sure you are on wiring diagrams, not tsb's, then pick the diagram you want to look at. Every wiring diagram on your vehicle is available.
Rate if this helps you. Always appreciate a reply.
Dec 20, 2013 | 1990 Dodge Ramcharger
I have a Rheem 82vs50-2. Can this heater's elements be wired continuous for 9.0kw and is there any mfr documention that allows continuous wiring of this heater
You have dual element 240Volt tank-type electric water heater.
You want to change wiring from non-simultaneous to simultaneous.
Copy following link for exact internal wiring diagram, and external wiring change: Remember the wire from breaker box will not support both elements without tripping breaker, so you will need additional 30 amp breaker and 10 gauge wire, or single 50 amp breaker and 6 gauge wire.
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html#simultaneous
http://waterheatertimer.org/Color-codewire2.html
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
Sep 23, 2012 | Rheem Water Heaters
201-2 singer sewing machine plug wireing diagram
Any of the older Singer manuals will give you this info...here's a PDF for your machine...
http://www.ismacs.net/singer_sewing_machine_company/manuals/singer-model-201-sewing-machine-manual.pdf
If that doesn't help scroll down on this page there's a simple diagram on there.
http://blog.sew-classic.com/2009/11/30/replacing-the-wires-on-a-singer-button-foot-motor-control.aspx
Aug 31, 2012 | Singer Sewing Machines
I bought this wall mount heater because I was told it was 120 volt. I opened it up to look at the wiring and found a small wiring diagram that indicates 240 vold input. Which is it? Intertherm WA-1000-4...
In general, if it has a heater element, examine it carefully. It has to have a voltage and wattage or amperage rating on it somewhere. I would start there. I would also have to lean towards the wiring diagram. It should show 2 lines of power, usually L1 and L2, and a ground and possible an neutral. Hope this is of some help. Let me know if you need more and I will dig a little deeper for you.
Jan 29, 2011 | Heating & Cooling
Heating & Cooling Logo
355 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
