Question about Kenwood VR615 Receiver
Only the radio output works but no sound if connected to TV or DVD player ?
  • 158 Answers
You will probably have to set the correct input on the reciever, those two inputs will be able to recieve a digital input i,e coax or optical or the traditional analog (red and white ) jack.. the reciever might not know which type of cable your using for the tv and the video input..
Posted on Sep 07, 2010
Testimonial: "Superb. Fixed it in 2 minutes. Enjoying the surround sound once again. Thanks. "
DVD model #mwd7006 sound but no picture
  • To reset the DVD player unplug the DVD player for 10 seconds.
  • Confirm that the TV has been set to the corresponding video connection of the DVD player.
  • DVD player has three video outputs.Video, S-video and RGB-component.
  • If current connection to TV is not working and the TV has an alternative video consistent with the DVD player try the second.
  • Try DVD player on another TV
Nov 24, 2015 | Televison & Video
RCA DRC247N DVD Player No Audio
The separate DVD player has three output cables: video (yellow), right audio (red) and left audio (white?). These connect to the corresponding inputs on the TV. If your cable box also has three similar output cables, you probably do not have a second set of inputs on the TV so what to do? You can purchase three Y adapters that combine two female RCA connectors into one RCA plug and plug everything into your one set of connectors on the TV. However, if your cable box output connects directly to the TV antenna input, the solution is simpler. Post a comment if this approach is not going to work
Oct 13, 2012 | RCA DRC247N DVD Player
Samsung ps wx30 surround sound system. speakers are plugged in to dvd player. dvd player is connected to tv via hdmi cable. speakers only work when using dvd player and not tv/sky etc.. am i missing some...
Hi,here is my simple solution...
To listen your TV on your
samsung ps wx30 surround sound system ,
** you need to connect "Audio Output " RCA jacks or "Optic cable output" or "HDMI out " of your TV unit
** to "AUX input " or "TV" OR "Any input" of your
dvd player or "Optic Cable input" or "HDMI input"
** than just switch to respective mode on
dvd player corresponding your RCA or Optic connection or HDMI ..
There you go..Your TV sound is on the
dvd player By this means whatever you watch on the
TV (
tuner, satellite , Xbox , etc..) ,it's sound will come thru your
dvd player.
Hope this helps!..if more he?p requires pls let me know..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 25, 2011 | Audio Players & Recorders
Model no. dtq2605fc how do we hook up a dvd player to this?
There are several ways to hook up a DVD player to a TV.
The simplest method, which works with any TV, is to use the DVD player's RF (radio frequency) output on channel 3 or 4, connect the output cable to the TV's antenna jack, and put the TV on the appropriate channel. There are two problems with this method, though. First, I'm not aware of any new players that have RF output these days. The manufacturers don't include it, figuring you'll be using the direct audio and video outputs. So if you're trying to connect a new player, you likely don't have this option. Second, if the player does have RF out, it's usually not stereo sound and the picture quality can suffer.
If the set has AV input jacks available, you would use those and select the AV input from the remote control or front panel. There are some possible problems with this method too. The biggest one is that if you've lost or thrown away the original remote, you might not be able to select the AV input. (Don't laugh, many people don't realize they should keep the original remote even if they never use it.) And on TV sets with only mono sound, you need a Y-adapter cable to combine the right and left audio outputs into one channel, so you lose any stereo effects.
The last way is for TVs without an AV input and DVD players without RF output. You use an RF converter (also called an RF modulator), which takes the audio and video signals from the player and makes a channel 3 or 4 signal you can tune in as I described earlier. RF converters are available at Radio Shack stores, most TV retailers and from many sources online. They're easy to connect, but you'll need an AC outlet nearby since they need power.
One of these methods will work for you, and you'll be watching DVDs soon. Thanks for using Fixya!
Apr 05, 2011 | Daewoo DTQ-13V1FC TV
Dish Network connection and surround sound
HI, connect audio output from tv to system,you may have to turn this on or turn up in tv menu for some sharp tvs,this should get sound for tv and dvd and anything else you hook up to tv.
Hope this helps.
CABLE GUY.
Mar 29, 2009 | Audio Players & Recorders
How do i hook up my rca dvd to my samsung tv its hooked up right but i can'y figure out how to get the tv on the right channel for it to work
This DVD player only has audio and video outputs. You'll need to connect it through one of your TV's A/V inputs, then switch to that input to see the DVD signal.
If your TV doesn't have A/V inputs available, you'll need to connect the DVD player using an RF converter. This takes the audio and video signals from the DVD and produces a channel 3 or 4 output you tune in on your TV. Converters cost around $10 to $20 and are available at Radio Shack or retailers who sell TV's.
Feb 23, 2009 | RCA DRC277 DVD Player
My DVD player quit working. It was plugged into my Yamaha amp. I hooked up another dvd player, I get sound and no picture. When the dvd player is connected directly into the TV there is picture & sound. I...
Try using the composite video or SVHS video outputs on the original DVD player with the Yamaha amp. The other DVD player might have a switch on the back to select composite or component video outputs.
Dec 13, 2008 | Audio Players & Recorders
No sound output
Sounds like you sorta know what your doing but the most obvious answer is the source and output (selection) dont match. Double check your mute button and all the obvious things first, make sure your connections are to Zone1 inputs as well. None of those are it? Do you get sound from the Radio? Try unhooking all inputs (video also) and hooking up just one at a time till you get it right.
Mar 18, 2008 | Audio Players & Recorders
Unable to get sound when connecting DVD player to TV
connect one end of white cable to dvd/vcr audio output and the other end of white cable to tv audio input L .
connect one end of yellow cable to video output on dvd/vcr and the other end of yellow cable to video input jack on tv
If you connect like this after checking you connections this should fix problem.
Jan 02, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Can't get my DVD player to work...
Your GE TV most likely doesn't have anything but a antenna input on it? If that the case to connect a DVD player you must purchase a RF modulator to convert the video and audio output of a DVD player to a channel 3 or 4 output. Here is a link for one at Radio Shack.
http://www.radioshack.com/product/index.jsp?productId=2103095&cp=&sr=1&origkw=rf+modulator&kw=rf+modulator&parentPage=search
Nov 30, 2007 | GE 27GT271 TV
Kenwood VR615 Receiver Logo
151 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
