Question about Kenmore Dryers
I have a kenmore gas dryer Model# C1109450290 and it quit totaly nothing works on it. could it be the timer ?
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 10, 2010
Kenmore 400 series gas dryer doesnt dry clothes
Replace timer, if you are sure that it is not working.
Do an internet search for kenmore driver parts and get dozens of hits.
Aug 03, 2014 | Kenmore Dryers
I cant get my kenmore gas dryer to quit locking the controls. model 110.97572601
Sounds like the door lock is faulty...have it replaced.
Dec 12, 2017 | Dryers
Timer has quit working and not getting heat in a Kenmore Extra Large Cap. electric dryer?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 25, 2011 | Dryers
When i push the start button i can hear and feel the timer working yet nothing else happens. when i release the start button the timer quits working.door switch is working. i've checked all the connectors...
heatman101
Sep 06, 2010 | Kenmore Dryers
Kenmore Dryer 70 series electric-quit heating and timer wont shut
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
This link will help you in diagnosis/disassembly/parts.
Possibly a faulty heat element is most common failure. Fix the no heat problem and the dryer should shut off ok.
Make sure you have correct voltage to the unit before tearing apart. Again visit the link above
Nov 24, 2017 | Kenmore Dryers
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
Kenmore mod 110 87870110 gas dryer- at first push
the vent could be plugged and unit is going into thermal overheat if it works in timed dry properly then the moistier sensor is faulty.
Dec 01, 2009 | Kenmore Dryers
Kenmore 600 timer no longer works
This is not an easy task. you will need to disassemble the entire control panel to extract the bad or faulty timer. Extraction can be tough on some model. this will cause an inexperienced do it yourselfer to break off fragile retaining clips and screw anchors as well. you will also need to make sure that the wiring harness is re attached to the new replacement timer correctly. this is important. We recommend calling for service on all electrical repairs if you have minimal experience in this field of repair. Unfortunately , when these timers are damaged, you cannot repair them. you will need to replace the bad timer with a entirely new timer.
Jun 10, 2009 | Kenmore 600 6963 Electric Dryer
Kenmore 70 gas dryer will heat for 7 minutes then nothing
Change these:3d37aa7.jpgthey get hot and quit, then cool off and work some more.
Dec 31, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
122 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
