Connection between Samsung 46" LCD / Samsung Home Theater System &Tivo
Hi Guys... I want to get HD service from my cable company, and want to buy an S-video cable, or Optical cable or red-green-blue cable (can I get a suggestion from you guys?)... the best one of all... so, I want to know what should I do to correctly connect those three components, meaning what do I have to change (av cable, if needed, going from where to where, if I substitute it for a new cable - mentioned before- going from where to where in between those components, so I can get the best result with my HD cable service...
Thanks in advance for your help...
Ricky :)
'samsung lnt4042hx xaa' my has dark on the rigth hand side of the picture you can see the imagen but dark only about 5 inches
the rest of the picture all clear and very brigth
Posted on Dec 04, 2008
  • 520 Answers
None of the cables you mention are HD. Does your box have a HDMI out? If it does, an HDMI cable is what you need if your tv has an HDMI input jack.
Posted on May 14, 2008
HI Guys. I just upgraded to DirecTV HD-DVR ( I have aHR24-200) installed which is connected via HDMI to my Samsung HD TV. I have a Samsung HT-C550 Digital Home Theater System which is now directly...
You're correct and that is exactly how I always recommend setup (contrary to what the manuals tell you). It makes no sense to me to run any signal through any electronics or interconnections that neither use it nor improve it. Hence, I have NO SOURCE VIDEO going to or through my receiver and NO high end audio going to my TV (which could just as well be a monitor with NO audio capabilities, right)?
Audio electronics should receive the BEST digital audio directly from it's root source.
The TV should receive the BEST video directly from ITS root source.
THAT is why most all high end A/V gear has separate audio and video in/outputs.
If that means you have to make some switching choices when using different sources, oh well. At least you won't have experience potential degradation from multiple hops or have to troubleshoot problems that could be anywhere in that chain.
Jul 16, 2011 | Samsung Ht-c550 5.1 Dvd Home Theater...
I just bought a Samsung HD LCD 32 in TV and want to play it through my Home Theatre System. I set the TV to external speakers, put the HTS in aux mode, but I don't get sound. My old Samsung SDTV would...
If you do not have a manual for the machine down load one at http://www.samsung.com/us/support/downloads/LN32B460B2D
It will show you how to set up a Home Theater Connection
Connecting an Amplifier / DVD Home Theater
TV Rear Panel
1 Audio Cable (Not supplied)
Amplifier/DVD Home Theater
1 Connect Audio Cables between the
AUDIO OUT [R-AUDIO-L] jacks on
the TV and Audio Input jacks on the
Amplifier / DVD Home Theater.
When an audio amplifier is connected
to the AUDIO OUT [R-AUDIO-L]
jacks: Decrease the volume of the TV
and adjust the volume level with the
Amplifier's volume control.
Each Amplifier/DVD Home Theater has
a different back panel configuration.
When connecting an Amplifier/DVD
Home Theater, match the color of the
connection terminal to the cable.
Nov 29, 2010 | Samsung LN32B460 32 in. LCD HDTV
Hd movie format supportet with samsung home theater
well, i think mpeg4 is the format u need. this format can be accepted by hd home theater. And u should use this video tool which can convert any video files to mp4. Besides, it can offer u mp4 hd format as output format. Then u will not worry about quality loss.
Have a try:
http://www.pavtube.com/video_converter/
Jan 31, 2009 | Samsung HT-TZ312 Theater System
My tivo HD is not broadcasting or recording in HD
As far as I know, you need the cable cards to get HD through the Tivo, because they're what does the HD decoding and output.
Jan 18, 2009 | Tivo HD
Can I still use my prologic receiver for my LCD TV ?
optical connection in tv is only input optical connection in receiver is only input will not work.need to connect rca jacks to tv's audio out jacks behind tv to any available input in receiver
Jan 04, 2009 | Samsung HTP-1200 System
Samsung LN37A550P3F shadow image
It seems new TV.
But that kind of problem is related LCD panel.
If you can replace LCD inverter first.
then not working need to replce LCD panel.
Jul 22, 2008 | Samsung HP-P3761 37 in. HD-Ready Plasma...
Tivo HD will not record when Onkyo HT-SR800 is off
Do you want to run all your cables thru the receiver? There really is no benefit for you to do this since that receiver doesn't handle HDMI audio nor do any kind of component to HDMI conversion. Might as well connect your tivo box directly to the TV with HDMI. You'll have to switch inputs on your TV between the cable box, but its not a big deal.
Feb 20, 2008 | Onkyo HT-SR800 System
Digital optical connection is creating any sound
Check to ensure the Home Theater is outputting the digital audio via the optical cable.
Nov 21, 2007 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
HDMI conection
Hi.
Connect the Home cinema and the TV with the HDMI cable. When you turn it on, first turn on the TV and then the home cinema. I hope this works.
Oct 07, 2007 | Samsung HT-HDP40 - 800 Watts 5 Disc HDMI...
Televison & Video Logo
155 people viewed this question
Top Televison & Video Experts
