Question about Nakajima AE-740 Typewriter
When the typewriter is turned on, it continually beeps after going through the initialization. What is causing this?
  • Nakajima Master
  • 3,594 Answers
If the printwheel is properly installed and there isn't any debris in the carrier area there are probably broken wires in the wiring to the carrier.
DickyO
Posted on Sep 07, 2010
When i turn on typewriter I get a continuous beep
Look for debris in the carrier area and spray a little WD40 on the carrier shaft.
DickyO
Apr 14, 2014 | Swintec 2640 Electronic Typewriter
Turn on and it has a continuous beep
Most typewriters have a "power on system test" or POST routine. Beeping means that it fails the test. With the power off, try moving the carriage all the way to the left and turn it on. Some typewriters, if the carriage is not right over the left sensor, will fail the POST. Most typewriters will check things like, "Is there a ribbon installed?" "Does the Daisy Wheel home?" and will move the carriage left to right to make sure that the sensors recognize the left and right limits. There are other checks of course, but those are the ones that are easily fixable.
Beeping sound
Usually beeps indicate an error either in operation or that the typewriter cannot complete a request or operation due to a malfunction. If the beep is continuous, you probably have a malfunction and should have it serviced.
Oct 05, 2013 | Brother GX-6750 Typewriter
How to solve a problem with an IBM Wheelwriter 10 Series ll Model 6783
It is most likely a bad keyboard. You can try my fix under WW1000 or contact Geo. Beyers Co. for a rebuild.
DickyO
Feb 28, 2013 | Swintec Ibm Wheelwriter 10 Series Ii...
Typewriter beeps continually and first and third lights from the bottom right blink when I turn machine on. Beeping stops after 30 seconds or so, but lights continue to blink and no keys work. I changed...
Be sure the printwheel id properly installed, remove P/W & check for dirt and debris in that area. If you have air in a can try blowin out that area.
DickyO
Jan 05, 2011 | IBM Wheelwriter 6 Typewriter
WHEN I TURN THE TYPEWRITER ON , IT STARTS BEEPING CONTINUOUSLY AND DOES'NT STOP TILL YOU TURN IT OFF AND ON A COUPLE OF TIMES
First thing to try is a little shot of WD40 on the 2 silver shafts that the carrier slides on.
DickyO
Nov 20, 2010 | Nakajima AE-830 Typewriter
Lights blink and machine beeps
Check the flat connector that goes to the indicator lights the edge of the keyboard sometimes wears into itand causes a reset sequence.
DickyO
Oct 06, 2008 | Lexmark Wheelwriter 1000 Typewriter
Beeping and keys don't work
When you power up what happens? What lights are lit, are thy flashing, are there beebs and how many? These are error codes and are important.
DickyO
Sep 25, 2008 | Lexmark Wheelwriter 1000 Typewriter
Beeping
It most likely beeping because it cannot make its resetting movement. That is,it cannot "find-out" where its left margin is. There may be something hindering the actual movement of the print carrier. Check inside the typewriter by lifting up the top cover and move the print unit by hand. It should be able to move from the left to right-hand side of the typewriter unhindered. The shaft that the print unit moves on should be clean and it may have gathered dust etc,so give it a wipe with a clean cloth (lint free) with a small drop of light oil on it.. Replace the top cover and switch on the machine
Nov 05, 2007 | Nakajima AE-740 Typewriter
Nakajima AE-740 Typewriter Logo
212 people viewed this question
Top Nakajima Office Equipment & Supplies Experts
James Cagle
James Cagle
Daniel Thibodeau
Level 1 Expert
Adorjani Laszlo
Are you a Nakajima Office Equipment and Supply Expert? Answer questions, earn points and help others
