Air conditioner fan in the outside unit shuts and after a little bit when I hit the reset button and manually push the fan it goes back on for a little bit. 1)Your site is wonderful THANK YOU 2) If it might be the capacitor for the fan where is located so I can take it to grainger Thanks
  • 455 Answers
Hello Open the service panel near where the wire/power goes in.It will look like a large battery with plug in termnials on top.Write down what wires go/went where.C=common,HERM=compressor,F=fan.You need the UF & the volts values off the old one.Good luck.
Posted on Sep 07, 2010
Reset the contactor relay
the contactor does not have a reset button 24 volts will energize a magnet and pull the contactor in you can also manually push in the contactor for testing purposes the airhandler has the transformer which produces 24 volts this power then goes to the tstat then you select a mode which then goes to the contactor you most likely have a blown fuse on the circuit board or simular problem the contactor could have shorted causing this
Jun 27, 2012 | Goodman Heating & Cooling
My outside fan will not run and the inside unit runs constantly. can't push the reset button on unit outside
Your out door unit fan motor not runs due to pressure not build up at Heat mode. If its cool mode only fan runs with compressor when thermostat calls for it.
Without having technical knowledge, don't press any reset button. Hope it's helpful?
Dec 09, 2010 | Ruud Central System Air Conditioner
What is purpose of pull lever on top right of decorative panel
It's an air intake vent damper. If you push it in, the unit won't pull any air from outside, instead it'll recirculate air from the room. If you pull it outward, it allows the unit to pull air from outside. During the day when it's hot outside, the lever should be pushed into the closed position to allow for more efficient cooling. At night, if you want to exchange air from outside when it's cool enough, pull out the lever to allow that to happen. The unit will exhaust hot air no matter if this switch is in or out.
Jul 05, 2010 | Maytag M7Q08F2ACOM Air Conditioner
A/C Stopped Working
outside fuses are blown on condensor unit at dissconect
Jul 13, 2009 | Heating & Cooling
Outside fan not working
Replace the fan motor capacitor and try again.
Jul 05, 2009 | Ruud Central System Air Conditioner
My outside air conditioner fan is not turning, but when I push the reset button it runs for a while and begins cooling? Then it stops turning and gets hot inside again? What could be the deal?? It was 112...
if the button your pushing is in the unit outside it is a manual reset for high head pressure this cuts off the unit to protect the compressor,you need to clean the coil .turn the unit off and gently push water through the coil in an up and down motion till water comes out clean see if that helps
Jun 26, 2009 | Ruud Central System Air Conditioner
Fan running constantly in the house
Check t-stat and make sure fan is set to "Auto", that might be why fan is running all the time, or it could be a fan relay that is stuck closed. It sounds like you A/C is over charged or you have a bad high pressure switch, this was a common problem with this manufacture especially in the heat mode.
Apr 24, 2009 | Ruud Central System Air Conditioner
AC shutting down, not cooling
your landlord needs a service tech !sounds like you have a few issues.possibilities include control issue,plugged evap coil,plugged blower wheel,possible freon issue.This one's a little too big to handle here.
Jul 26, 2008 | Ruud UBHC Air Conditioner
I have a never used air conditioner, I put it in window plugged it in, when you hit reset button the green light power indicator comes on, when you hit test it shuts off, the power will not turn on at...
I'm assuming that you're hitting the buttons on the GFI outlet. The test will test the grounding of the outlet. The reset fixes it. These have nothing to do with the A/C. Hit reset and leave it alone.
There is a control panel with fan and temperature switches in the a/c unit somewhere. Turn on the fan/ a/c switch and set the fan on high. Move the temperature switch to mid-range. The noise on the unit should be a bit louder as the compressor kicks in to do the cooling.
Jun 13, 2008 | Samsung Heating & Cooling
Heat Pump Reset Button
If running in heat check indoor air filter if in cool wash out outside coil with garden hose make sure fan is not overheating and shutting down.
Jan 06, 2008 | LG LSC121PMA Split System Air Conditioner
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
