Question about Ruud UAKA037 Air Conditioner
What is your cooling wire (Y) coming out of the air handler when all the wires you have available is R,G,C,W1,W2
  • 455 Answers
Hello Just connect Y to Y from the thermostat to the condenser at the blower.That will bring on the out side unit.R & G will bring on the blower as needed.If you have a variable speed or modulating blower motor Y will be at the curcit board and MUST be connected.
Posted on Sep 07, 2010
Wiring honeywell th8320u1008
Be sure you are looking at the letters set up for heat pump. Orange should be "O". Remove jumper between w2 and e. Then be sure you have the settings correct in the tstat for a heat pump with back up heat. Good Luck!!
Mar 28, 2017 | Heating & Cooling
Hello -york electric furnace- no emergency heat- with heat pump
You may try looking at your thermostat first. Most Heat pump thermostats need a jumper wire from the E terminal on the subase of the stat to the aux or W1, or W terminals.Only jumper W to E or W to aux or W1 to E. If it has a jumper wire on the stat subase then check on the terminal board on the electric air handler. You will find a W and W2 terminals. Try jumping these with a thermostat wire also.
Jan 23, 2011 | Heating & Cooling
My service technitian put a jumper on my tappan air handler (model B5BMT60KC) in which W1 and W2 are jumpered all the time. He cut out the black wire entirely. Does this mean everytime the unit is powered...
No it means when you make a call for heat both stages of heat are going to come on. They wont come on if your just running the fan or if its in ac. Thanks please leave feedback
Dec 16, 2010 | Heating & Cooling
New heat pump system freezing, questioning wiring.
W1 and E on stat need tied together. When W1 comes on wire where all heat elements come on. On the outside unit defrost board set the 45-60-90 to 45 and see if that takes care of the frost problem.
Jan 03, 2010 | Heating & Cooling
I am trying to wire a Honeywell Vision pro Th8000 series thermostat onto a Weather king heat pump and air handler. The thermostat wiring has r,rc,y,c,o/b, g aux,e,y2andl terminals I understand these but...
RC & RH JUMP WITH R FROM AH & CU
C/U - A/H - T
R - R - R = 24V
C - C - C = COMMON
Y - - - Y = COOLING
G - G = FAN
B O\B = REVERSING VALVE - HEAT
make sure the stat is set up for heat pump
Not sure what b or d are. i would double check the schematic on the condenser for the reversing valve wire.
Dec 16, 2009 | Heating & Cooling
No heat, got great a/c....
W1 and W2 are the differences from the single stage to the two stage. Im thinking its your thermostat is not programed for 1 heat / 1 cool. You probably had 2 heat / 1 cool before.
Oct 17, 2009 | Goodman Heating & Cooling
Thermostat wiring
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Thermostat wire color codes explained.
Please note. Not all installers use the proper color codes when they install or replace equipment. It may be necessary go go to the furnace or outdoor unit to verify what wires are for what purpose. Also be sure there are no splices in the wire that could change the wire colors between components.
  • R (red) or Rh (Red heat) 24 volts from equipment.
  • Rc (Red cooling) 24 volts from transformer in cooling equipment.
Note: If only furnace has a transformer and cooling equipment does not jumper Rc and Rh.
  • W (White) sends 24 volts to furnace control to start the heating cycle.
  • W2 (no standardized wire color, usually whatever wire color is available) controls second stage heat.
Note: W2 is most often used for heat pumps to control what is called emegency heat or Auxillary heat, and most often will use the white wire.
  • Y (yellow) often (blue) is used, controls cooling unit (outdoor condensing unit) also is used for heat pump heat.
  • Y2 (no standardized wire color, usually whatever wire color is available) controls second stage cooling.
  • G (Green) controls the fan "on" operation of the furnace/air handler. Also often is used to start the blower for many electric furnaces.
  • C (common) most often brown but can also be black or other color available to installer.
  • O (orange) Energizes heat pump reversing valve for cooling (Trane and most other brands).
  • B (Blue) Energizes heat pump reversing valve for heating (Rheem, Ruud and Weatherking).
Jun 02, 2009 | Carrier Heating & Cooling
Wiring diagam for goodman heatpump and air handler to thermostate
On your t-stat you have Y, W1, W2, R, O, G, B or C or X. Y is your cooling circuit and will be the same in the air handler and heat pump unit, use the yellow wire for this circuit. W1 and W2 are your back up elec. or gas heat. Depending on how many kws or heat strips you have and t-stat wires you will put the white wire to W1 in both the t-stat and air handler. W2 is for your second stage back up heat if air handler calls for it, this will be a tan or brown or black t-stat wire and goes to W2 on t-stat and air handler. R is half of your 24v control power from the transformer and is the red wire and goes to the t-stat, air handler, and heat pump. O is for the reversing valve in the heat pump that switches it from heating and cooling. You guessed it the orange wire connect to t-stat and heat pump. G is for the blower and is the green wire to the t-stat and air handler. B or C or X is known as the common which is the other half of control circuit from 24v transform it is the blue wire and goes to the t-stat, air handler, and heat pump.
Oct 09, 2008 | Goodman Heating & Cooling
Thermostat wiring
W is normally for heating and Y is normally for cooling. You must be misreading the literature. If Y and W are jumpered you would have heat and cool at the same time. R terminal is normally the power to the thermostat, Y is to the cooling at the heat pump A/C terminal board. G is for the indoor fan operation at the air handler or furnace. W is for heating and with a heat pump you may have a w2 terminal. W1 would be for the first stage or primary heat. W2 would be for the secondary or backup heat be it furnace or electric.
Jun 16, 2008 | Heating & Cooling
Ruud UAKA037 Air Conditioner Logo
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
