Question about GPX MW3837 MP3 Player
MP3 BIKE I was riding my bike and it dropped then I ran over it. Then when I try to turn it on it doesn't work. But when I charge it it works HELP
  • 8,596 Answers
Replace - sorry
Posted on Jun 20, 2008
What to do when motorcycle will not start tipped over tries to start but wont fire up
How old is the battery? You need to check if the alternator is putting out a charge, is the regulator working. A dead cell in the battery will often show a full charge state if you try to charge it. When you try to start the bike the battery is required to give a high charge to the starter. The buzzing you hear is probably the starter solenoid trying to work. I would suggest fit a new battery and if the bike starts OK check out the charging system. 14.4 volts is the normal reading across the battery with the engine running at 5K.
Jul 18, 2014 | Yamaha YZF-R1 Motorcycles
2000 vulcan 1500 ignition light not working
Take the cables loose from the battery. Clean the cables. Might need a wire brush. Reconnect.
Jan 30, 2014 | Motorcycles
Start no electrical, bike died like the key was shut off. No electrical what so ever
battery flat if voltage regulater faulty it wont charge the battery
Jul 20, 2013 | 2000 Yamaha YZF-R1
Zx6r 2004. Bike ran great for two months. Went out to dinner last night and came out to my bike not starting. Trailered it home, started when taking off trailer. Went for a 15 minute ride and parked it....
Hi, Matt it saddens me to inform you that you have to put on your Battery Priest Robe and prepare yourself for the Ceremonial "LOAD TEST" but before you begin, maintenance type batteries must be topped off with distilled Holy Water and all batteries must present their terminals to the battery charging altar to receive the electrical infusion of Holy Ions until they have reached a 100% full charge of 12.5 volts or better.
Below is a quick and easy test to see if your battery is in good condition or needs Last Rites and must be replaced.
1. Start by disconnecting the spark plug cables.
2. Adjust voltmeter to DC volts 20-volt range
3. Place the voltmeter leads to the battery terminals.
4. Turn the run/off switch to run.
5. Turn the ignition switch on and press the starter button.
6. Watch the voltmeter as your engine turns over for 15 seconds.
7. If the voltage drops below 9.5 volts, the battery is faulty and must be replaced.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
ZX6R 636 Bike won start
Kawasaki NINJA ZX6R My bike won start Starter problem or discharged battery
Kawasaki Ninja ZX6R Service Manual
OEM Parts for Kawasaki
Kawasaki Ninja ZX 6R Owner Manual
How to Tell if Your Battery is Bad in 3 Easy Steps
May 18, 2017 | 2007 kawasaki Ninja ZX6R
I bought a new battery, the bike road fine for a while the in the middle of my ride it started slowing down to a complete stop. I couldn't start it again, waited for 20mins, started it and it ran...
One explanation for this would be that your charging system is faulty. It is possible that the OLD battery was ok, but was not getting charged by the faulty charge system. You put in a new battery, that is part charged before sale and ran the battery flat because it wasn't charging. If you leave a discharged lead acid bettery for 20 minutes or so, it will pick up a little again and possibly let the bike start and run, but by the time you got home you had killed the battery completely.
All the facts fit, though I'm not promising that it is the problem.
Take the battery off and charge it with a charger. Now, put it back on the bike and run the bike (It should start) While the battery is on the bike, get a volt meter on it. It should read slightly over voltage (doesn't matter if its a 12 or 6 volt system, it will read a little over when the bike is running) when you turn the engine off, you should see the volt meter drop down to the stated battery voltage. If you get no hike with the engine running and drop as you power off, its a good sign the charging system is faulty. A similar test, start the bike, meter the battery and turn on the indicators, stop light and head light to pull as much power as you can, the battery voltage shouldn't dip, because the charge system should compensate. If it does dip, consider this a confirmation that the charging system is faulty.
Jun 29, 2011 | Suzuki GZ 250 Marauder Motorcycles
Hyosung avitar 650 wont stay running
Maybe this will help. This is a common problem that I have had with my GV250. Almost the same bike mechanically by Hyosung.
If the battery is low on charge and you are lucky enough for the bike to start. As per normal when first started it revs higher because the bike is cold, this turns the alternator fast to give you the electricity you need to keep the bikes computer working properly. Bike will warm up and revs drop down, alternater not turning as fast, not as much electricity being made. Bike will either stall or rev up and down irradically to try to produce its own electricity. This will occur when the battery charge is low and bike is at low revs, for example when you slow down for traffic or you stop.
If this is your problem. To resolve it when you are out on the road, keep the revs up, twisting your throttle gently when you are going slow or stopped. Give the bike a good long run on the open road to give the battery some charge from the alternator.
Make sure your battery is maintained. If you dont use your bike for a while it will lose charge just sitting there doing nothing. Give the battery a good deep cycle charge or take the bike for a good long open road ride.
Jun 02, 2011 | 2011 Hyosung GV 650 Avitar
Dropping cylinder at 10rpm and possible generator /stater problem
It seems the charging system of your bike is not working
Recharge the battery and thn fit it in the bike and start it and check the charging rate.
Remember with lights 'on' it drains power from the battery butthe charging system of theengine takes over i.e. if its working alright, with your explanation, its for sure the charging system is not functioning.
Chekc the altenator and the rectifier.
Sep 08, 2009 | 1994 Suzuki GSF 400 Bandit
Bike Died - No Power
i would check if you have a short somewhere.....but first make sure your battery connections are tight....gauges turning off and on while riding is usually a sign of a loose connection meaning you hit a bump or something and it briefly clips out...did the bike actually turn off??? i dunno....but that seems to be a very odd problem....take out the battery, put it on a trickle and let it charge to full cap....then reconnect making sure the terminal connections are secure and see what happens.... if that works, we''ll have to start diagnosing further, but like they always say, check the obvious first !
Nov 20, 2008 | 2006 Honda CBF 600 S ABS
Blue opal 2 GB M4002 not working
I have the same **** problem! Except I never dropped it or anything! I just hooked it up and it wont frikken recognize it. WILL SOMEONE PLEASE HELP! DDD: email me at ;_; This is soo agrivating.
Jan 23, 2008 | RCA OPAL M4001 MP3 Player
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
