Question about LG DLG3788W Gas Dryer
Dryer lights up and makes noise but wont turn drum. tells me check filter. where is filter located. I have had the rear of the machine vacummed out and it still doesnt work
  • LG Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
When I start my sst16 and it is running it makes a horrible clicking noise. Can someone tell me why it is doing this and how to fix it. Thank you in advance.
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
Mar 23, 2016 | Dryers
My dryer WGD96HEAW1 makes vibrating and grinding noise after heats up, not in the beginning when turned on.
DRYER MAKES NOISES.
The blower:
The bearings:
GOD IS GOOD !!!!
Feb 28, 2016 | Dryers
I have a candy condenser gcc58onb it is making a terrible noise when it turns the drum turn s what is this?
DRYER MAKES NOISES.
The blower:
The bearings:
GOD IS GOOD !!!!
Feb 21, 2015 | Candy Dryers
My lg tromm dle5977w dryer check filter light stays on and drum wont turn just makes humming noise
If the drum will not rotate then the drive belt is broken and should be replaced
May 26, 2014 | Dryers
Motor making noise
DRYER MAKES NOISES.
The blower:
The bearings:
Apr 15, 2014 | Frigidaire FGQ1442ES Gas Dryer
When turned on makes a loud vibrating noise
Hi vonwolfebaye...
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like the drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer if you have to.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer by removing two screws located on either side of the top of the dryer housing and unplug the door switch.
This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear they will make a thumping type of noise.
If your drum rollers have too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them and are only squeeling then they probably only need lubrication.
Remove the rollers and clean the shafts that the roller rolls on, remove any hair,dust,etc from roller and shaft.
Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil, or a light lubricant like Vaseline.
Reassemble the dryer.
Plug back into your electrical receptical.
This should solve your noise problem.
Please take time to rate me thumbs up
Sep 19, 2011 | Frigidaire FEQ1442ES Electric Dryer
Turned on dryer & tried to start but it gave a load thud noise & wouldn't go. Stop it then re-started a light came on stating clean filter. Clean filter & look inside that area to see if...
there is a sensor located beneath the lint filter, more the likely the dryer sheet residue is on it, gently brush it off, it has two screws. As far as the loud thud noise is/may be a problem with the drum/rollers/glides/belt/idler arm/motor Here is a website that will assist you, once the filter light goes off and the drum will not turn.Good Luck Tim
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Mar 05, 2011 | LG DLG5988 Gas Dryer
When i press the start button, it wont turn on. But it make a noise like it wants to
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
If you have to check/replace/repair your drum motor or belt and if you have a front loading machine:
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Please rate me
Sep 19, 2010 | Roper REX4634KQ Electric Dryer
Dryer wont run it just makes a humming noise but the drum wont turn
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch.
Remove the lint filter screws and filter.
Good luck,
I hope this helps
Please rate me
Thank you
Aug 13, 2010 | Dryers
Noise from dryer
drum has worn drum bearing dryer top AND rear panel must be removed to acess the rear of drum to replace drum
Sep 24, 2007 | Zanussi TC7102W Electric Dryer
LG DLG3788W Gas Dryer Logo
159 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
