I am getting paper jam error message after I try to print on photo paper
  • edvakh Sep 07, 2010
    As you could notice in the first message that the printer model is HP Officejet J6480. I did not say it is officejet though, but if you are an expert you should know. I did install special ink cartridge for printing photos. Ther are no any jams. The printer does print on regular paper - it does not on photo paper.
    Do not bother. I resolved the problem myself.
    Top Expert:
  • Office Equip... Master
  • 76,846 Answers
Try using another brand of paper some papers are thicker than others and can fool the printer into thinking the printer has a paper jam.
Posted on Sep 07, 2010
  • 1,183 Answers
I may be incorrect on the same. But i personally had a problem with my printer where i used an incorrect paper type for photo printing. Check the link what all paper types are supported for photo printing
Photo paper 102 x 152 mm; (4 x 6 inches) Photo paper 127 x 178 mm; (5 x 7 inches) Photo paper 203 x 254 mm; (8 x 10 inches) Photo paper 254 x 381 mm; (10 x 15 cm) Photo L 89 x 127 mm; (3.5 x 5 inches) 2L 178 x 127 mm; (7.0 x 5.0 inches) Borderless photo paper 102 x 152 mm; (4 x 6 inches) Borderless photo paper 127 x 178 mm; (5 x 7 inches) Borderless photo paper 203 x 254 mm; (8 x 10 inches) Borderless photo paper 216 x 279 mm; (8.5 x 11 inches) Borderless photo paper 254 x 381 mm; (10 x 15 cm) Borderless Photo L 89 x 127 mm; (3.5 x 5 inches) Borderless 2L 178 x 127 mm; (7.0 x 5.0 inches) Borderless B5 182 x 257 mm; (7.2 x 10.1 inches) Borderless B7 88 x 125mm; (3.5 x 4.9 inches) Borderless 4 x 6 tab 102 x 152 mm; (4 x 6 inches) Borderless 10 x 15 cm tab 100 x 150 mm; (3.9 x 5.9 inches) Borderless 4 x 8 tab 100 x 200 mm; (3.9 x 7.9 inches) Borderless HV 101 x 180 mm; (4.0 x 7.1 inches) Borderless double A4 210 x 594 mm; (8.3 x 23.4 inches)
Thanks
Proton
  • Mandeep  Singh
    Mandeep Singh Sep 12, 2010
    HI,
    Its nice know that the problem was resolved with the printer. If you could share, what you did to resolve the problem. It would definitely help us with knowing one more resolution to a problem.
    Thanks
    proton
  • 3,083 Answers
Some printers detect the type of paper you are using, and print accordingly. Do you have photo cartridges installed? If not, that will trigger an error message. Try putting a smaller amount of sheets in the paper feed- that can sometimes trigger an error message, I've read in reviews. Double check the printer to make sure there, indeed, isn't a paper jam. The type of paper one uses with certain printers can be an issue, so google your printer make and model number and then type something like suggested paper type, or things similar, and you will get some sites that discuss problems with different printers and paper types, and also suggestions of which paper will work well with which printer.
I couldn't find any specific information since I didn't have a make and model number, but hope this general information helps.
Good luck, and thanks for using FixYa.
4 Suggested Answers
SOURCE: Duplex Path, paper late jam
Can you save that one document as a pdf and print it?
Posted on Mar 31, 2008
pineworks
  • 4041 Answers
SOURCE: paper jam on Dell Photo 926
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 18, 2010
SOURCE: Epson Stylus Photo R350 giving a paper jam error message
An Epson service man (he was VERY kind to suggest this) told me to use a weak detergent solution on the rollers, NOT alcohol as that will dry out the material the rollers are made of. Although the problem has recurred a couple of times, it's worth repeating when necessary. I actually activate the 'print' command so it tries to feed in paper, while I FIRMLY hold a piece of fine cotton cloth stretched over a thin plastic ruler, which I hold down where the paper feed grabs its paper. The printer has a couple of tries to feed paper, reports an error message (because there was no paper) and I activate it again, thus exposing the WHOLE of the feed wheel to the cleansing cloth! WORTH A TRY!
Posted on Feb 20, 2010
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Pixma iP2600 Photo Printer InkJet: Canon iP2600 error codes...
my printer will not print out anything. it starts to but the paper never enters into the printer, it is almost like it is jamed but it isn't.
The message says there is an error, push resume and try again.. same thing, it starts to push paper thru.. acts like a jam.. same message.. but paper is not jammed
May 16, 2010 | Canon Pixma iP2600 Photo InkJet Printer
Jan 30, 2010 | Epson STYLUS R350 Photo Printer
Message shows "Paper jam" but there is no paper jam
try turning off the printer for about 10 sec. to clear its memory and turn it back on.. then print again
Oct 19, 2009 | HP Photosmart C4250 Multifunction Photo...
Epson cx4800 - will print in text mode but gives me a paper jam message in photo mode pape ris not jammed
It sounds like a driver issue. Have you tried to uninstall and reinstall the software on your computer?
Nov 02, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Epson Photo RX600 error messages
Hi.
Check for a paper jam inside the paper feeder... There's something blocking the path that is why the 3-beep is activated. Also put lubricant to the head's round-bar, gears and levers.
Goodluck... Fixya me...
Feb 10, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Paper jam error message
I had the same problem, and found that the sheet feeder mechanism was intermittent. The problem seems to be that the lubricating grease inside the mechanism.(white nylon round thing with gears on it) becomes too slippery with age, and stops picking up the activating arm which allows the cam unit to move to kick the top sheet of paper into the rubber feed wheel.
The repair was extremely difficult because it involved taking most of the printer apart to get to the ink pump/sheet feeder mechanism.(white nylon round thing with gears on it). And then I tried quite a few lubricants (including no lubricant at all) but none of these worked reliably. Finally I tried a dab of automotive wheel bearing grease (it feels like glue), and this worked perfectly. I have had no more paper jam errors and no miss-feeds in about 7months of everyday use.
Dec 28, 2007 | Canon PIXMA iP1600 Printer
266 people viewed this question
jasbo
jasbo
