Question about LG DLE2532W Electric Dryer
Where can i get a parts diagram for a LG 14225FD Mike
  • LG Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
This tip also tells you how to find a parts diagram...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 12, 2010
Change rubber boot on lg wm-14225fd clothes getting soiled on boot
If your seal isnt leaking why not try cleaning your machine by putting on a boil wash with a flushing agent such as OUST . Dont put any laundry in and once you have started the programme then increase the water level by carefully pouring about 6 kettlefuls of water thro the dispenser.If your m/c has a variable thermostat make sure this is also set to 90oc.Allow to go thro programme and you will find your machine also smells a lot better.
Dec 17, 2011 | LG Washing Machines
Its a wd(m)-14220fd/14225fd model were is the drain filter
Should be behind the small flap on the front bottom left corner
Aug 29, 2010 | LG Washing Machines
LG WM-14225FD - making bad grinding type noise when in use
it will be your pump that circulates the water. i have had mine replaced four times during its 6 year life! its common, not to be confused with the drain pump.
Aug 06, 2010 | LG Washing Machines
My lg wm 14225fd is making a banging popping
this sonde like the drum needs to be rebalenced this needs to be done once a yr. you well need to call a repair person its covered under your warrenty.
Dec 22, 2009 | Washing Machines
LG WM 14225FD eu code
EU --- error means ---Unbalanced load is sensed three times during a spin operation. to resolve the issue ----Open lid. Rebalance laundry load and close lid.· Check wiring harness
· Check unbalance switch
· Check circuit board
Mar 14, 2009 | LG WD-1280FHD Front Load Washer
Ice guide is broken, need new part for an lg refrigerator grey in color.
go to sears .com click on parts put your model number in(in frig. top right)and you will get any part you need,let me know how you do-mike
Oct 15, 2008 | LG Refrigerators
Lg intellowasher DD 7.5kg WM14225FD error code OE
I think your "OE" is really a "DE" or drain error. Open the access door on the lower left of the front panel on the machine, drain the remaining water with the small drain hose there, and unscrew and remove the larger thing, which is a filter. Clean filter. If filter was not blocked, check for loose impeller on drain pump motor, which requires replacement of drain pump motor. (just sticking it back on will result in it coming off again)
If this helps, a "fixya" rating would be appreciated. Thanks.
Oct 01, 2008 | Washing Machines
LG WD(M)- 16220FD Error LE
the problem lies on the speed sensors on the main direct drive motor (the connection with the thin cables) but the problem is that it is not a seperately replaceable item and comes complete with the main stator coil unit this is very pricey at over £120+vat trade price then an engineer will charge his fitting fee on top of this. maybe worthwile looking at buying a new machine
Jul 19, 2008 | LG WD-16110FD Front Load Washer
LG DLE2532W Electric Dryer Logo
120 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
