Question about Compaq 2710p Tablet PC
Wifi fails to resume
After returning from sleep or hybernate, wifi fails to reconnect. It's very annoying, since the only solution sofar is a FULL shut down /restart= 9 minutes, Vista....
  • 42 Answers
Go to Start/Control Panel/Network and Sharing/
then click on View Status, then Diagnose. That usually restarts your wifi so you can be back online without restarting Vista.
Posted on Sep 12, 2009
,won't stay connected to wifi have to power off and restart to reconnect to wifi
How stable is the Wifi? Ours goes fast and slow here due to old wires in the yard and stuff like that. I sometimes lose my wifi and have to reconnect. It can be also an issue with the wifi in the unit itself.
Jun 05, 2016 | Tablets & eReaders
How do I stop continually trying to connect to wifi and failing
Unable to Connect to wifi problem - Solved for me ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Jun 7, 2012 - I tried the "forget the connection" workaround but it always came back. ... recognizing and joining the wireless network, but are not connecting ... Ipad won't connect to wifi after update iOS 7.0.6
Mar 1, 2014
New iPhone 5s - constant "Incorrect WiFi" password
Nov 25, 2013
Wifi ISP keeps failing
Sep 10, 2013
New Macbook Air - wifi connectivity problems
Jun 13, 2013
More results from discussions.apple.com
How to fix limited or no connectivity Wi-Fi issues in Windows 8
www.fixedbyvonnie.com/.../how-to-fix-limited-or-no-connectivity-wi-fi...
The connection is limited ... He couldn't connect to Wi-fi on battery power. ..... Will this work if we have limited connectivity when trying to connect through a LAN cable? .... I found another solution, If you are running Windows 8 and your laptop keepsdropping the WiFi .... Investigate router or access point issues Failed
Dec 28, 2015 | Tablets & eReaders
How do I get wifi authentication?
If you are at home trying to get on your own WiFi connection, try unplugging everything involved with the WiFi signal. This could be a router and a modem, but if you're not sure, just unplug it all. Wait 20 seconds and plug everything back into the wall.
Next turn off your tablet. Not just putting it to sleep, but actually turning it off. Then turn it back on and try again.
If it still doesn't work, try using the WiFi with another device and if it doesn't work, let us know.
Nov 02, 2015 | Tablets & eReaders
Why does my wifi disconnects when i turn off my tablet?
You probably have the setting for WiFi set up to where it shuts off while in sleep mode. You can probably fix it by going to your settings and changing the WiFi setting to always on. Not sure which setting its under but just select and check out each setting category until you see something that relates to changing wifi setting. I could be more detailed but would have to go there to be sure which exact setting.
Mar 15, 2015 | Android Tablet
I could not turn on my the wifi on my chromo tablet
When you selected forget it erases the SSID and password you entered to connect initially so you will have to re- enter the info to reconnect!
Feb 15, 2015 | Chromo Inc Chromo AAAAAAAA Pink 4gb 7"...
How to fix wifi
sometimes it helps to just make a restart of the iPad to get things sorted....
Restart iPad: Press and hold the Sleep/Wake button until the red slider appears.
Slide your finger across the slider to turn off iPad. To turn iPad back on, press and hold the Sleep/Wake until the Apple logo appears.
Feb 13, 2015 | Apple iPad (16 GB) WiFi Tablet PC
How do i get my wifi internet back
It sounds as if you simply need to reconnect to your wifi network. If you have already connected to it, but still have no access, then disconnect from your network, remove the network from your settings (Forget The Network) and then try reconnecting to it.
Aug 27, 2014 | Irulu 7" 4gb Mid Google Android 2.3...
Wifi Being disabled while in sleep/screen time out mode.
don't know if it works the same for your tablet as it does my droid phone, but i had to go into my settings/battery and data management/data delivery/social applications/data delivery frequency and select automatic(push). I'm sure its in a different location and probably named something else on your but i would start by going through your setting and seeing if there is something in there you can change.
Feb 06, 2014 | Samsung Galaxy Tab Tablet PC
I have a Kocaso M1052 and I am unable to sign on to facebook, yahoo.
JUST SIMPLY RESTART YOUR COMPUTER THEN CHECK YOUR INTERNET AND WIFI SETTINGS ,RECONNECT TO YOUR WIFI THEN RESTART YOUR INTERNET OPEN SITED YOU FAILED TO LOG ON TO AND CLICK REFRESH THEN SIMPLY JUST SIGNIN AGAIN
Oct 12, 2013 | Kocaso 1016A 10" Android 4.0 1.2GHz...
It aint workin
Go to settings and turn on wifi. If you cant do that and see networks somethings wrong with it. Try returning it or going through the manufacturer because its defective.
If there are no networks you need wifi. Find that and retry.
If you can't get wifi to work and cant return it then try putting the updated firmware from support part of the cruz website on your sd card and follow the instructions to reflash.
If you can't even do that the thing is broken, find papers that have a tendency to blow off of where they are supposed to be and use it to hold them down.
Remember you bought something with a resistive touch screen and a 1/2 ghz processor. It's slow and occasionally annoying to use. That is what you bought though. If it's just that you think it sucks then the problem is with research you did.
Nov 26, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
Compaq 2710p Tablet PC Logo
62 people viewed this question
Top Compaq Tablets & eReaders Experts
Jerry Umali
Ann
Level 1 Expert
ray gallant
Are you a Compaq Tablet and eReader Expert? Answer questions, earn points and help others
