Question about Sony DAV-DX250 System
Protect unplug? sony dav-dz10 - Sony DAV-DX250 System
techman
  • 3130 Answers
SOURCE: sony dav-dz100
That means you have a bad speaker, speaker wire, or a componet in the output stage of the amp blew out. First thing to try is to disconnect all the speaker, Turn on the unit. If it still reads the same, you have a problem with the amp. these are solid state units and have no user replacable parts inside of them.. You will need to have it serviced or get a new unit, as to have these repaired or even estimated these days is very costly. Good Luck Please dont forget to rate this thread.
Posted on Nov 25, 2006
SOURCE: PROTECT UNPLUG
This is a common problem with sony it means unplug me or i will explode, it is a protection of the heat sync and usually means that a cooling fan has shorted out. If under gurentee return to Sony for repair if not under guranebntee as is generally the case check on the net for a replacement fan motor - as far as i know sony were sourcing thier fanns from Sunon there is a German based headquarters - just google sunon europe
Posted on Aug 12, 2007
SOURCE: dav-dz10 hacks
just type region free and your model on google, you'll find the file
Posted on Nov 11, 2007
  • 4234 Answers
SOURCE: protect
The protect message indicates a problem was found inside the amplifier. The output transistors are most likely shorted and need to be replaced. This is a fairly simple repair and should cost about $40 in parts plus your local labor charge.
Dan
Posted on Mar 18, 2008
SOURCE: sony dav dz 100........ protect unplug
unplug it from the wall.
Posted on Aug 09, 2009
My Sony Home thatre system DAV-DZ10 give a message : No Disk. How to solve that problem? Any help?
All DVD players will say no disc if there is no disc in the drive when closed. If however it does so when there is a disc in the drive, plus the disc is clean and undamaged, then you have a problem. It could be caused by dirt on the lens, but since it was doing funny things before there might be an electronics issue. I would still clean the lens first.
Jul 05, 2015 | Sony Dav-dz100 Home Theatre System
I want to update my Sony DVD Player DAV-DZ10 Divx Drivers to run recent divx movies, can anyone help?
Nov 14, 2010 | Sony DAV-DZ100 System
Sony HCD-BC150 As soon as I turn it on, it shuts
Change the audio amplifier IC are on short circuit and that´s the cause your device goes to protect mode
Aug 11, 2009 | Sony DAV-BC150 System
Protect Unplug
I know that almost all new equipment since 99 or so on up has these. They are too sensitive. This is a system program that will put stereo in protect mode when turned up loud or have a lot of bass on to stop from blowing audio outputs.
Aug 07, 2009 | Sony DAV-DX250 System
Need help
I think, your Home theater gives you error message " protect unplug", means home theater has problem in Amplifier section and will not be power up to function.
You should check Amp section aspacialy Amp Output stage.
Jun 04, 2008 | Sony DAV-DZ100 System
Protect
Dan
Mar 18, 2008 | Sony DAV-S500 System
Protect unplug
Dear ecuabling,
Sony Home Theater system gives such message at that time when it gets problem in Amplifier section. You should contact nearest Sony repair center for better solution.
Jan 11, 2008 | Sony DAV-DX250 System
PROTECT UNPLUG
Aug 09, 2007 | Sony DAV-DZ100 System
Dav-dz10 hacks
Feb 23, 2007 | Sony DAV-DZ100 System
Sony DAV-DX250 System Logo
194 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
