Hisense tc2130e I change the flyback transformer and the tv only work for about 5 minutes then gos blank all i am seening now are color bars running vertical , i also change the vertical ic and i am still getting these lines
SOURCE: HISENSE TA42P-HDRA
I am from Tunisia & ibought a tv plasma HISENSE from CHINA 2 years ago;i have a vertical white line(10cm) in the midle of my plasma(Hisense 42"),after 10 mn the tv is on.What can i do?
Posted on Nov 20, 2007
SOURCE: HISENSE TL2020
is it in demo mode
Posted on Dec 29, 2007
  • 6 Answers
SOURCE: Vertical bar on Daewoo Plasma screen
YES YOU HAVE DRY JOINTS UNPLUG FROM POWER SUPPLY REMOVE THE BACK/ INSIDE YOU SHOULD SEE AT THE BOTTOM SEVERAL RIBENED CONECTORS FROM THE SCREEN ITSELF? UNDERNEATH YOU SHOULD BE ABLE TO SEE 2 OR 4 COMPONENTS CAREFULLY APPLY A HOT SOLDERING IRON AN SOLDER THE ONE THAT YOU ARE HAVEING PROBLEMS YOU SHOULD NOW HAVE FULL PICKTURE AGAINE ANY PROBS email me andymay2@msn.com
Posted on Mar 23, 2008
tvtek
  • 1284 Answers
SOURCE: sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
Posted on Dec 02, 2009
welcomejee
  • 10594 Answers
SOURCE: I have a 42JC2D TV. Vertical color bar lines
It is hardware issue related to LCD Panel (screen).
Regarding fixing it, it depends if you are handy with electronics stuff repair and can replace circuit boards in tv etc then please check T-Con (lcd controller board) on top center position at rear of lcd panel, this board would be covered with metal shield. Need to take off back cover of tv to get access to T-Con board. If T-Con board does not solve lines problem of screen then LCD Panel is bad and will be replaced.
If you fee uncomfortable doing so then repairman option is better choice.
Hope this info will help you.
Thanks.
Posted on Feb 27, 2010
My tv keeps switching off after about 20 minutes after initial starting. if tv is switched on immediately, then it works for less than 5 minutes before switching off. model: power vision.
I do not knowtis make , but this type of fault is sometimes due to dry joints in the flyback circuit or power supply try resoldering all pins on flyback transformer and chopper transformer, also cheek that the ht voltage is as the makers state. Waring unplug from mains before removing back and discharge ht resiour capacitor before starting repair
Mar 04, 2010 | Televison & Video
Screen going blank but sound is fine
check around the flyback transformer for component failure. change the flyback transformer if you don't see anything wrong .
Don't forget to vote me
Sep 15, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Hyundai 14" colored tv no power
if the final flyback is ok ,then check the driver transistor and the voltage in his collector .Probably the flyback transformer is ok.please reply.
Oct 17, 2008 | Sharp 25R-S100 25" TV
Replaced Flyback Transformer and Horizontal Output Transistor
how miuch was the repair can you do it yourself
Aug 13, 2008 | RCA F36650 36" TV
Could I possibly have a bad flyback transformer
I would try resoldering the flyback connections on the Circuit board. if the flyback was defective it would operate and you usually get 3 blinks on the LED indicator. Sounds more like a solder issue.
Jun 15, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA CTC203
with your new flyback transformer ther should have had a resistor and cap in the kit.if you look at the fly back from the rear ,on the right side very close to the transformer.and on the other side 3 resistors one has changed value about 38k-ohm.
Mar 28, 2008 | RCA F36669 36" TV
It won't turn on
The smell of something burning is not a good sign. The clicking sound you are hearing could be a relay or breaker kicking in and out as a result of whatever is wrong.
This could be cause by:
1. A problem in the power supply.
2. A problem with the Horizontal Output Stage.
3. The Flyback transformer.
Someone gave me a TV once that had the same problem. I determined that it had a bad flyback transformer. I replaced the transformer and the TV worked about 5 secs before I saw some black smoke come out of the new flyback. I turned it off right away and realized that something else was bad that caused the original flyback to burn up. The same thing was causing the new flyback to go as well. It turned out to be a shorted, 50 cent hi-speed switching diode. Fortunately, because I had turned the set off quickly when the 2nd flyback started to smoke, once I replaced the diode, the TV was fixed.
If you want to get it working again, you'll need to have it serviced.
Good luck,
- Jim
Jan 26, 2008 | Zenith B27A11Z 27" TV
Rca r52wh74 - no auto convergance
you need to replace chemical type fuse marked FL231 part number 259213, it`s located next to the flyback transformer, theres 3 of them there but 231 is the only one I`ve seen cause your problem, replace it and you`ll be all set.Happy Holidays !
Nov 29, 2007 | Televison & Video
Blurry Images
Hello paulaspec,
You have a problem with the three factors, and they are screen voltage, focus voltage, and control (focus 2) voltage. Basically these voltages have to be adjusted since the components in this section have aged some. These controls are usually located in the television on the IHVT (Integrated High Voltage Transformer) or as it is also called the flyback transformer. these controls must be adjusted together, along with the color controls. Here is how the adjustment is done (You will need a schematic diagram, a DC volt meter, and a color bar generator to do these measurments):
1) turn color and tint fully counter clockwise until you have a black and white picture.
2) connect the color bar generator to the TV (ch 3) and turn it on, you should see bars in various shades of gray
3) adjust as best as possible the color and tint controls to obtain the color bars on the screen Red Green Blue.
4) measure the voltages on the focus, screen and control grids of the CRT and match them to the schematic digram measurements.
5) adjust the focus screen and control grids to match the ones on the schematic diagram
6) once this is done then you adjust the color controls once again to obtain the red green and blue bars on the TV screen.
This should help if the CRT (picture tube) electron guns are still good and if the flyback transformer voltage supply is working.
However if you do not have a background in electronics please take the TV to a shop for repairs.
I hope this helps,
Thank you,
Shuttle83
Oct 16, 2007 | Sony KV-20M20 20" TV
Sony KV-40XBR800
You have the famous regulator problem, or the bad regulator problem, or the cold solder connectioin is on or around the flyback transformer.
Sep 09, 2006 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
