Question about Acer Aspire™ T180 PC Desktop
My Acer T180 wont boot! =.(...
Ok so its been like this for a while now... one day i just said screw it! lol
so when it starts up everything goes smothely... but after it gets past the acer logo it just freezes...
i managed to get into safe mode yesturday and get my stuff out... but... it just turned off and then that was it... havent been able to even get into safe mode any more...
So What Can i Do To Accualy Fix It?!?!
Any Help?... Please?... =.(...
  • Nathaniel W. Parsons
    Nathaniel W. Parsons May 11, 2010
    Have you ever restored a pc using cd roms and completed a clean operating system install
    Scholar:
  • 72 Answers
This sounds potentially like a failing memory stick. From another computer download and burn Memtest to a CD and try booting from it to test your RAM.
Posted on May 14, 2008
Carburetor adjustment
Generally if you will set the screws about 1 1/2 turns an choke it on start it will go if everything else is ok. The set screws to proper idle an high speed run. Those are very cranky saws so take a few aspirins it might help. Lol
Mar 22, 2014 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
How to remove the back cover of a Panasonic CF-W7 laptop in order to to replace the faulty exhaust fan?
LOL, ok, close the lid, remove the power cord, remove the battery, then turn the laptop over and start removing screws. You better write the screws down on a piece of paper or put them in a cup with a piece of paper that identifies where they came from. Sometimes removing the bottom is not all there is to it. You will probably have to remove the lcd screen, keyboard and palmrest to get to the fan. Good Luck!!!
Oh, by the way, there will probably be screws in the hard drive case, the battery case and all along the palmrest as it is secured to the motherboard. So you will also need to remove the hard drive, memory, CD/DvD Drive, wifi card, and most definitely the Heat Sink that most ime houses the fan and is on top of the CPU. You'll need some Thermal Paste to put back on the Heat Sin and CPU once you remove it. Otherwise most times your laptop will not boot if metal touches metal, or it will run hot and shut down if the coat of Thermal Paste is too thin or has dried up.
Mar 30, 2012 | Panasonic Computers & Internet
My pioneer DJM 600 lost master output the other day, it was playing and the master out just died. the lights were still lighting up but no sound came out. I was using the RCA outs not the xlr and haven't...
hi there i have a djm 500 but i have the same screw on the back its like an ATT for master output and if i turn it all the way down i have no sound but if i turn it up it gets alot louder lol
Jun 11, 2010 | Pioneer DJM-600 Silver Professional DJ...
Just had an oil change, two days later, the check
you can always take off your postitive cable, and negative welll just positive, Leave it off for about 3 to 5 hours. Then put the positive back on, this will reset your whole car. The check engine will come off but heres the catch you dont have much time probaby like 5 to 10mins before it comes back on. it work for me. Make sure the place your getting it inspected is close by maybe even do it near the place and then have them take it in from were you park. They will start it up, drive it in, turn it off. hook everything up. start it up again real quick to check if light goes on. It shouldnt. when I did it as soon as i left it went on. it was a close one.lol But give it a try and see if it works. Also dont forget to fix your time after reset, just in case some places get suspcious GOOD LUCK
Oct 18, 2009 | 2008 Chevrolet Impala
Just had my kwikset dead bolt lock rekeyed. i put it back on the door and now you can't pull the key out after you lock the door. please help
Sounds like its binding. Loosen the screws that hold the 2 halfs together. Get the key to work smothly. snug the screws and try again. If ok then tighten the rest of the way.
Sep 24, 2009 | Kwikset Locks & Locksmithing
97 plymouth voyager transmission / dashboard issues
My dashboard kept goin dead on me too, I removed the cluster to get at the harness plugged into the back of it, and found that when I applied pressure upward on the harness everything came back on. when I let go, it slowly fell back into place and it all shut off again. there's 6or7 screws around the circuit board fastening it to the plastic framing. I simply loosened these screws, applied pressure to harness to make everything turn back on and retightened the screws to hold the harness and whole board back where it needs to be. This is not gaurunteed to work, but it saved me havin to pay over $300 for a shop to find and fix the problem. good luck
Apr 11, 2009 | 1997 Plymouth Grand Voyager
99 hyundai accent starts sometimes. not battery
ok when the check engine light comes on that usually indicates a engine malfunction...what you can do is go to your local autozone and they can do an OBDII test for free..my bet says it is the cam or crank sensor.. DO NOT SHUT THE CAR OFF AT AUTOZONE..LOL
Jan 01, 2009 | 1999 Hyundai Accent
My nubira2000 not smoth
needs checking on computer for a diagnostic check
Oct 15, 2008 | 2000 Daewoo Nubira
HP Pavilion Laptop
ya change that heat sink out get new thermal paste on cpu screw down mobo and everting else tight ok newegg.com sells fans for heatsinks just gotta figureout what soket uuse ok
Jan 30, 2008 | HP Pavilion (F2111-60950) CPU Heatsink &...
Acer Aspire™ T180 PC Desktop Logo
90 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
