Question about Canon ImageClass D861 Printer
How do you change the toner cartridge in a canon d861 printer?
SOURCE: no toner cartridge
same problem!
Posted on Oct 23, 2008
  • 2692 Answers
SOURCE: HP Laserjet 3005DN toner cartridge change
You don't. HP printers seem to be very particular about this.  Take it back and get the exact replacment, including the brand.
Posted on Jan 24, 2009
  • 2678 Answers
SOURCE: Canon ImageClass D861 Need Vista 64 bit drivers
I don't think Vista is supported for this printer and if not doubt that it will be as Microsoft are bringing out a new OS to replace it.
Posted on Jul 28, 2009
canontech
  • 1219 Answers
SOURCE: paper jam in canon Imageclass D861 copy machine
Where inside in fixing unit, drum unit,...
It is problem if its fixing unit jam.Best take it to service
Posted on Jan 12, 2010
canontech
  • 1219 Answers
SOURCE: canon LBP 3000 tells me it needs a new toner cartridge
Hello!
Remove the toner cartridge out, on the right side of the toner cartrige slot inside the printer you will see an round bushing with metal pin.That pin goes in and out when you open or close cover.So you need to take an contact spray or WD40 and apply it on pin.After each spraying open and close the door so that liquid can do its own in the inner mechanism of toner recognition.
Aplly wery small ammount each time.
hope thath helped
Posted on Feb 25, 2010
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Canon Imageclass D861 Has lines going from side to side does not do it all the time but once it starts gets more lines sometimes fills the whole page up. Only does it on printing from the computer don
There is a clean function on this machine that cleans the rollers. Go to additional function section on menu. Then use arrow keys to go to adjust/clean.Then press set and then use arrows to go to roller cleaning. Then press set again.
Mar 26, 2014 | Canon ImageClass D861 Printer
Price of canon Image Class D861...
This type of printer has been discontinued and is no longer available for general sale. You may be able to pick it up second hand, although this is not advisable as the price of the toner cartridges (the ink) is very expensive as they are probably not made any more either. It may be a better idea to go for a newer model of printer that hasn't been discontinued. I personally recommend the Samsung CLX 3175FN.
Good Luck! John
Mar 13, 2011 | Canon ImageClass D861 Printer
I have an ImageCass D861 copier. I have loved it until recently and it's getting worse. If I make only one copy when the machine isn't warmed up, it will be clean. But if I make multiple copies, or more...
This is coming from 1 of 2 places. The first and most common is the toner cartridge itself. If you have a spare go ahead and replace it. If not you will need to get another cartridge and swap it with your current cartridge. This will correct the copy quality 9 times out of 10 on these machines. If a new cartridge does not resolve the issue then the only other cause is the fusing unit. The fusing unit is located right where the paper exits the machine. It heats up and uses heat and pressure to "fuse" the toner onto the paper. When the fuser film in the fuser starts to go bad they will start to run dirty and also "double image" where a part of the printing from the top of the page gets reprinted lighter at the middle/bottom of the page. Sometimes you may also hear a crackling sound coming from this area which can be a sign of the fuser film going bad. The fuser replacement is much more expensive to have done so let hope that the cartridge will resolve your issue.
Good Luck and Thank You for using Fixya.
Sep 04, 2010 | Canon ImageClass D861 Printer
Replace Cartridge continues to flash after I replaced it
Are you using a factory new Canon cartridge?
Most companies build protection into their printer's logic to prevent the use of refilled cartridges and third party cartridges.
Don
Oct 21, 2009 | Canon ImageClass D861 Printer
Replacing toner unit
i have a lot of quantity cartridge . open your copier front door and out the cartridge.Have your side any hp 1200 printer cartridge part no 15 change drum shatter put your old d320 cartridge then solve your problem
please send me success result
Jun 25, 2009 | Canon imageCLASS D320 All-In-One Laser...
Printer making a crackling noise while printing, causes a crease down center with toner smeared, any ideas what wrong? do these need to have drums changed?
hi
there may be problem with your roller
and u can also take our technician help by calling at toll free no 18884276640
Jun 23, 2009 | Canon ImageClass D861 Printer
Cant find where to change toner on canon dr 3060
Scanner is just an 'input' device and no toner is required. You need toner/cartridge only for printers/plotter (output devices).
S. Mohan
Apr 09, 2009 | Canon DR 3060 Path-Through Scanner
Paper jam from bottom tray.
You might have a piece of paper out of sight. It usually is before the toner and after the pick up area. BEst to call 800-ok canon to find a local service center. This unit comes with a 3 year warranty, and you might still be covered.
Jul 09, 2008 | Canon ImageClass D861 Printer
Canon ImageClass D861 Printer Logo
91 people viewed this question
old marine
old marine
