Question about HP P2360AA Keyboard/Mouse
My F2 Sleep (hybernation) key doesn't work when I hit it on my HP keyboard? The sytem is only one week old. The Sleep key never worked from the get go. Thank you for you rassistance.
Try [Fn]-F2
I had same problem here, then just tried alt-F2, ctrl-F2 etc until I found the right combo. Looks like the [Fn] key is what activates the other built-in Fkeys. In other words, "it's not a bug, it's a feature".
Posted on Jul 15, 2012
2 Suggested Answers
  • 4 Answers
SOURCE: My HP KU-0841 keyboard has
If it is only several weeks old, it should still be covered by warranty, and therefore you should be able to exchange it for a working one.
Posted on May 25, 2011
How to enter bios setup
The method to enter the bios menu on acomputer varies by make. it can only be done when the computer first starts and is achieved with a particular key press. it must be done before the operating sytem starts to load, usually within the first few seconds after turning on. this also can ony be done from a cold boot, not returning from hybernation for example. try tapping the F2 key or delete key, these are the most commonly used.
Dec 07, 2013 | Avanquest System Suite 8: Windows
How can i disable the sleep button on the acer SK-962(B) wired keyboard? im using the keyboard for a makeshift MiDi controller right now and i keep hitting the sleep button on the keyboard. very ann
Unless you find a program to remap the keys.
There maybe software you can get from Acer to adjust the keys so that pushing sleep does nothing.
Oct 23, 2012 | Computers & Internet
My function keys of hp probook 4420s is not working
You have to Press and Hold the FN function key at the lower left portion of your keyboard then hit the volume or brightness keys. Notice that the volume and brightness keys are the same color as the FN function key. That means you have to press and hold the FN key while you hit the volume or brightness key.
May 27, 2012 | HEWLETT-PACKARD HP ProBook 4420s Notebook...
The f2 doesnt work on dell inspiron9300
do you mean the keyboard F2 key does not work? Change keyboard and test? Otherwise, it may be a two function keyboard where you need to hit a special colour key to get the function keys working. This special key is usually off to the side and may have some graphic indicating toggel between the first and second level of definitions of that physical key. This is true if you see more than F2 on that key.
Jun 13, 2011 | Computers & Internet
My HP KU-0841 keyboard has suddenly stopped working, it is only a couple of weeks old, it was fine up until yesterday. I have tried it with other computers /laptops and it doesn't work with these...
May 25, 2011 | HP DC170B Keyboard
We have a 4 month old Dell Vostro 220 desktop that when it powers-down in "sleep mode", it won't reactivate when move mouse or hit key on keyboard. The only way to turn computer back on is to hold power...
Have you tried just depressing the power button briefly rather than holding it down?
If so, the issue is likely a program that is preventing the computer from coming out of hybernation. Not likely anything to do with hardware.
Nov 23, 2009 | Dell Vostro 220 Desktop Computer
I cannot use my keyboard and mouse. Something is wrong with my devices
Make sure the keyboard is working in bios. When you boot the computer hit f2 or Del. key to make sure the keyboard is working. Also make a note that the keyboards light blink while turning on the pc.
If you are able to go to BIOS that means the keyboard is working fine.
Boot your computer in safe mode by tapping F8 key while the computer is booting. Select safe mode and check if the keyboard and mouse is working in safe mode.
If it is working in safe mode. Do a system restore to a date where everthing was working fine.
Please revert with the result of above .
Sep 01, 2009 | HP Computers & Internet
Keyboard keys not working when you hit them.
Open a notepad using mouse and then check if u can type in notepad.
Shut down and reboot the system and boot in bios by hitting F2 or F10 or Delete key on keyboard. If u are able to boot in bios ,reset bios.If unable then disconnect keyboard and try different port to connect.If issue persist replaced keyboard.
Aug 17, 2009 | HP Computers & Internet
Locks up at the select user screen when booting up.
when did it stop working
look at your keyboard make sure it isnt locked or shutoff
usually needs fn key plus another key to turn it back on
or change anything.These keys would be located usually at the top of keyboard and there symbol will be the same colour as your fn key.
Did you upgrade your system
If you are still unable to get on I would do a recovery
Jan 19, 2009 | Acer Aspire 5100 Notebook
Sleep mode PC continued...
VIA KM400A is the name of the motherboard chipset inside your computer.
I'm fully familure with that board.
1. on boot up hit delete or F2 key to enter the bios setup screen
2. once inside the bios setup screen , look for power management settings.
you'll know what to do at that point
You'll want to
1. turn power nanagement totaly off , which is not a good idea because windows considers
it a device in the system and loads a driver for it , so turning it totaly off MIGHT give windows
a heart attack.
2. set
Display Power Management Controled by Power Management = NA or NO
Turn off display after suspend or hybernate = NO
3. save and reboot
Thank you for choosing FixYa!
Az.
Sep 18, 2008 | HP Pavilion a620n (PC028A) PC Desktop
HP P2360AA Keyboard/Mouse Logo
374 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
