Question about Whirlpool Duet GHW9150P Front Load Washer
My drainer not working - Whirlpool Duet GHW9150P Front Load Washer
  • 92 Answers
I am sure there is something stucked in it
Posted on Sep 07, 2010
Testimonial: "thanks i checked there was really something stucked thaks once again"
My washer stops and beeps. Flashing "FH" ... Sometimes it won't drain all the way. Thanks for your help!
There is a drain plug underneath your washing machine. open the full face panel under the door, (you will need "star" screwdriver) then unscrew the plastic cover for the drain elbow. BE CAREFUL it will most likely have some water
Posted on Sep 08, 2010
I have a Whirlpool washing machine;model AWM5104.I wanted to know how you empty the drainer. I've heard that for some makes of machine,you turn it clockwise but mine doesn't budge!
exactly what do you mean by emptying the drainer?
If you are in the correct category of washing machines there is only a pump that pumps the water out into a drain pump or sink and the hose is higher than the tub edge
to fully drain the tub then simply place the drain hose at floor level or empty into a bucket or other low container.
make a new comment to clarify what it is that you want an answer for.
May 22, 2015 | Whirlpool Washing Machines
Removal of insink drainer.
The drainer is very easy to remove...
Just use a screw driver or the jamm wrench to un hook the disposer from the drain by turning the ring that connects it to the drain.
Tehn loosen the three screws that hold the drain onto the sink bottom and take off the snap ring and the drain will pop right out...
Here is an exploded view of that...
http://www.plumbingsupply.com/insinkeratorpartsbadger5.html
heatman101
Apr 10, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water buildup under crisper trays with Frigidaire 20.6 cu top mount
please clean the water drainer or the pipe for drainer down side.
Aug 14, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Our asko 6021 washer is spinning at high speed, but not draining. Could the drain hose be plugged? How can we check this? It doesn't appear to just screw off.
hi..If the drainer does not work the problem could be
it may be a worn or loose drive belt or a solenoid switch
that is not working.
check it out..
thank u..
kindly rate my response..
May 09, 2009 | Asko W6021 Front Load Washer
Avanty w789SA
its the drainage problem .so either the drainer is getting blocked or the drainer is cracked and got faulty so needs to be replaced.
This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
Feb 26, 2009 | Avanti W789SA Top Load Washer
Condenser dryer gets hot but cloths not drying and water drainer
Check The Ducting To Make Sure There Is No Obstructions Inside. Find The Outlet Outside Where The Duct Goes And See If Your Getting A lot Of Air. In Some Cases You May Have To Remove The Back Of The Dryer To Remove The Biggest Lint Ball In The World.
This Huge Lint Ball Builds Up Over Time And Quickly For Users Who Do Not Clean The Lint Trap On Every Cycle.
All Of The Above Will Cause The Dryer To Not Be Able To Get Good Air Flow Thus Causing The Machine To Have To Much Back Pressure.
Feb 04, 2009 | Candy DQW150 Front Load Washer / Dryer
The cupboard next to dishwasher becomes full of condensation during drying cycle
Is the machine properly lined up?
Could be a small leak at the top - won't leak water, but steam can escape maybe.
Sep 03, 2008 | AEG 23 in. Favorit 86070Vi Built-In...
Black drainer wont come off
i had similar on an indesit 123 suspect something in drain. remove hose from pump end remove any blockage last time i found 45p in the body of the pump ,good luck
May 19, 2008 | Indesit W 123 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
