Question about Avanti Hot and Cold Water Cooler
My Avanti water dispenser gives me a bad tasting water, a chemical taste. I keep rinsing it out, added baking powder , and nothing helps. We can`t drink the water.
murdozzz2
  • 75 Answers
SOURCE: Dishwasher leaves taste on glasses
hi there sounds like your rince aid level is set to high, the adjustment for this is located under the rince aid filler cap, try setting to position 2
Posted on Dec 15, 2007
  • 531 Answers
SOURCE: Taste of water from water dispenser has "plastic taste"
you have to flush dispense water on till taste gone
Posted on Apr 02, 2009
  • 9 Answers
SOURCE: ice maker water taste like chlorine but tap tastes fine
Put a in-line water filter on the water line if you want. The taste is from the food and items you have in the refrigerator. Clean it out and keep your items in proper storage. Ice collects the smells in the line and the fridge. Change your ice that is sitting in the bin, wask out the bin with water and baking soda. Hope this helps.
Posted on May 01, 2009
  • 2187 Answers
SOURCE: Drinking water has a bad taste and smell.
You will have to trace where the foul smell comes from by tracing the water line and testing the source. Check if it is before or after the filter you get the smell, if it is before the filter, you need to check if it is on the line which comes from the source or it is from the source. Most likely cleaning or probably a replacement of the part if cleaning does not help.
Posted on Sep 21, 2009
  • 180 Answers
SOURCE: The ice cubes coming from my GE profile
Check the condition of the teflon on the ice maker.  You will probably need to replace the ice maker if the teflon is cracking and getting into your ice.
Posted on Oct 25, 2009
Ice tastes bad
If It were me I would change the filter in the fridge, that always worked on mine.
Dec 03, 2013 | LG LRFD22850 Bottom Freezer Refrigerator...
The ice from my ice maker has a chemical taste...how do I get rid of it?
Run about 3 cycles of vinegar; then rinse with water. Run regular water through and then the ice should lose the chemical smell and taste.
Mar 30, 2013 | Igloo Cooler Igloo Portable Countertop Ice...
I installed a new PureSource2 filter a month ago. The taste of my water improved and all was fine. Last week a chemical taste began to build and then it became undrinkable. I bought a new filter and...
Search for "how to remove ammonia from tap water" and also for "ammonia added to drinking water". You''l find information, about Chlorine, Chloramines, and Ammonia as different ways to treat water. There is suggestion for ammonia which was to let some water sit for a while to try to off-gas the ammonia. I'd use a glass pan to avoid any metal contamination/confusion for the before/after smell tests. There are kits to test the water.
But first line some facts up
1. Get a water report from the water company to see what naturally occurring minerals are in the source of water and how much of that is removed and what is used to remove it, and, how it compares with local and national standards.
2. Use the water kits, if need be, to confirm these reports.
3. Look at the water filter labels or go to the product's website. There are different levels of purification some these water filters provide. Prices go up correspondingly. I would be surprised if a filter "added" taste. Removing some contaminates might reveal other masked tastes. These filters also recommend the number of hours to be used; the ones with higher removal capability have shorter hours. I'd expect 1-2 years of use.
4. Other solutions:
- use the bypass cap that came with your frig in place of a filter for a before and after taste test.
- use a Brita pitcher.
- look into using a whole house cartridge based system (not water softeners) to get good smelling water everywhere. Replace cartridge(s) annually. Note: I would bypass the outside water bibs for lawn and pool; why use pure water to water the lawn?
Hope this helps.
Ultimately your water source is the problem source.
Mar 14, 2017 | Frigidaire Refrigerators
The water and ice taste bad. The filter is new
put a box or two arm in hammer baking soda in freezer water and ice tends to absorb different orders give it a few days should be ok good luck zap
Apr 12, 2010 | GE Profile PSW26P Stainless Steel Side by...
There is a bad order coming from ice and water dispenser. I changed the filter but it didn't help. Smells like ''dirt''. Thanks, Linda
Replace water supply line with the plastic tubing ice maker line. It fixed mine that had a metal braided line on it that made the water taste kie rubber and dirt,, after that I tried a vinyl braided line.and it made the water taste like garden hose water.. The plastic tubing was the cure. Reply and tell me what you have.
Mar 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice from dispenser tastes bad...almost a chemical taste...any suggestions? Thanks...
Do not use a steel or plastic braided supply line. They make the ice taste bad.
Feb 27, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Our refrigerator was in storage for about 5mo. It's been a year since it was hooked up and still tastes bad,like a mold taste.Can you tell me wht I can do to get rid of this. Thanks, Cathy
Have you tried washing it out with Vinegar? Also put OPENED boxes of baking soda in there. You can KEEP always in your frig and Freezer at all times. helps asborb bad smells and bad tastes.
Sep 27, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker water taste like chlorine but tap tastes fine
Apr 26, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice from ice maker does not taste right
Hi
Ice storage bin needs to be emptied and washed. Unsealed packages in the refrigerator and/or freezer compartments may be transmitting odors/tastes to the ice cubes.
Interior of the refrigerator may need cleaning.
Water chemicals. Installing an in-line filter can help with many odor/taste complaints.
An open box of baking soda in the refrigerator section can help with preventing the transmitting of food odors.
This is a common in-line water filter, they are fairly easy to install and usually come with instructions.
Even when your well or municipal water supply provides healthy, potable water to your ice maker, some impurities may remain. These can affect the smell or taste of the ice cubes, and therefore the beverages in which you serve them. A taste and odor water filter on the incoming water-supply line--such as our charcoal "Universal Replacement Water Filter"--can help a lot.
Also, over time, the ice cube bin can absorb difficult-to-remove odors from the freezer. Some manufactures recommend that you replace the bin every 2 to 3 years, whenever it seems to be retaining objectionable odors and transferring them to the ice cubes.
A Fixya Rating would be appreciated.
Thanks
Rylee
Feb 11, 2009 | Whirlpool ED2GHEXN Side by Side...
Avanti Hot and Cold Water Cooler Logo
183 people viewed this question
Top Avanti Water Filters & Coolers Experts
John Tripp
John Tripp
john h
Are you an Avanti Water Filter and Cooler Expert? Answer questions, earn points and help others
