Question about ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
New cpu not loading...
Got amd2600 upgrade from 2500 comp loads no display, using dual displays
  • 48 Answers
So you are saying it boots to a black screen? do you have a cmos jumper on ur motherbaord? resetting the cmos may help but its possible you have a bad processor. also rarely the bios may need updated to run a different processor
Posted on Jun 21, 2008
The comp. is very slow what is a cpu. when u turn it on it takes hours to load
The central processing unit (CPU) is the portion of a computer system that carries out the instruction of a computer program, to perform the basic arithmetical, logical, and input/output operations of the system. The CPU plays a role somewhat analogous to the brain in the computer.
The faster the CPU, the faster the computer.
You might want to look in to upgrading the CPU or RAM.
Sep 01, 2011 | Toshiba Satellite A135-S4467 Notebook
Can you upgrade to a faster cpu than a 1.73ghz in a vgc-ls30e? If so how much can it be upgraded?
Hi, laptop chip upgrades are limited by what the bios setup of your computer will accept but I`ve had a bit of success by looking what different versions of the same model laptop are available, the manufacturers generally use the same motherboard in a variety to keep costs down so if there is a model the same as yours that is available with say a pentium 1.86 dual core then it will most likely fit yours too. Download a program called cpu-z (free on the internet) which will tell you what socket type your cpu is which is essential as there are so many now!
Hope this helps
John
Dec 02, 2010 | Sony VAIO VGC-LS30E 1.73GHz Pentium Dual...
Cpu to support sse2
Highest model cpu your board can support is the AMD Athlon XP model 3200. This is not a dual core cpu. You would need to upgrade to a newer motherboard in order to use a dual or quad core cpu. Hope this helps.
Feb 03, 2009 | Asrock K7S41GX Motherboard
Flatscreen goes blank and displays the message
Out of range indicates that the refresh rate or resolution is set too high for the monitor to display. I would suggest re booting into safe mode by pressing F8 during boot, before windows begins to load. Select safe mode with networking if you can, and once in safe mode, uninstall the ati display driver from the control panel. Then go to ATI's site and download the latest driver for your card. Save that file to your desktop. Reboot normally, as Windows should load default vga drivers for your card. Once in Windows, install the latest driver you just downloaded. That should reset the resoultion to one that your monitor can display. Good luck:)
Jan 02, 2009 | ATI RADEON X1650 Graphic Card
Upgrade from Pentium 3 to Pentium 4
what socket is the Pentium 3? Socket A. The sockets have to be compatible for example you can't upgrade a Dual Core for a Core 2 Duo because although the chipsets look the same the motherboard may not support the new instruction set. I had this problem recently as i wanted to upgrade my Intel Celeron D 3.02ghz to the Pentium Dual Core 1.8ghz and although the chips were identical and fitted perfectly in my mobo, the actual mobo i was using (foxconn) wouldnt work with it forcing me to buy an ASRock mobo and replace the entire system.
May 27, 2008 | Dell 2.8 GHz Second Processor for...
Dell Poweredge 1800 server
Hi the Power Supply also needs to be upgraded for the additional RAM and new CPU . Please look into this aspect. My opinion a slightly Overrated PS would be better .
May 07, 2008 | Dell PowerEdge 1800 Server
Intel cpu ucode loading eroor
You can upgrade your bios, you just need to visit the motherboard manufacturer site where you can download the latest bios.
http://www.asus.com/products.aspx?l1=3&l2=11&l3=0&model=1276&modelmenu=1
You can also try to reset the bios first, you can reset it to default settings and if that will not work then you can upgrade the bios.
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5PE-VM
and you can also check this site regarding bios upgrade
http://support.asus.com/technicaldocuments/technicaldocuments.aspx?root=198&SLanguage=en-us
Mar 21, 2008 | ASUS P5PE-VM Motherboard
Windows xp wont reload
This happens so much with upgrades! We think we are making our pc's better, and then find it doesn't like it. I am assuming you completely uninstalled millenium, then tried to load xp? If you did not, the registry still has parts of millenium on it, and is asking for this. You need to completely uninstall millenium first. You need to obtain mill copy, and select uninstall, then when done, put in your new xp disk and try again. Lilacgerry xxx
Nov 30, 2007 | Compaq Presario 900 /1500 Series EVO...
ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
