Question about Brother MFC-7820N Printer
Brother MFC 7820N Toner life end with new toner
I found the following post on another site. It appears to work. If you want to reset your Brother MFC 7820N machine so you no longer have the error message: Toner End of Life, do the following:
1. Open the front cover of the 7820N, that is, the cover that allows you to pull out the toner and drum, but don't pull out the drum/toner.
2. Push the button: Options (located on the left of the control pad).
3. Type: *00 on the keypad.
The Brother MFC 7820N should be reset and the Toner End of Life message should disappear. WARNING: This may void your warranty and ultimately damage your machine if you are reusing or refilling your cartridges, but you should already know that. Hope this helps.
Posted on Sep 08, 2010
  • willpons Jul 24, 2011
    First off I changed out my toner cartridge with a new one, and still get the Tone Life End error message.
    I tried the Options button as stated above, but only got a question, "Replace Drum? 1. Yes or 2. No"
    Thanks Will
4 Suggested Answers
SOURCE: Brother MFC-7820N Toner Problem
Open the cover, press Options and then *00.
Posted on May 22, 2009
the kowalski
  • 86 Answers
SOURCE: BROTHER MFC 7820N MACHINE PUT IN NEW DRUM, CHANGE
To manually reset the counters, do the following:
  • Open front cover, press "option".
  • Answer Yes (by pressing 1) to the question in the display.
  • Your drum counter is now reseted. Press "option" again.
  • This time, press *, 0, 0.
  • Your toner counter is now reseted too.
(If nothing happens when pressing option, try using the back/clear button instead.)
Posted on Jun 15, 2009
F Victor man
  • 817 Answers
SOURCE: Brother MFC 7820N, I am getting "Toner End Life"
I fail to see why you are covering up the toner sensor led's when you have a new cartridge fitted?
Also if you are using a recycled toner from a very well known uk shop that refills toners and ink then you may well have broken the drive gear that stirs the toner. i have seen this six times and their toners do this.
It could well be one of the pitfuls of recycled toners.
Posted on Jul 24, 2011
For the brother mfc 7820N the toner life end pops up and i have tried the *00 to reset and it doesnt work. What do I do?
When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint.You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer.This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter.A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Feb 09, 2012 | Brother MFC 7420 All-In-One Laser Printer
Jul 24, 2011 | Brother MFC-7820N All-In-One Laser Printer
Brother MFC-9440CN Laser Printer is saying toner life end and I just put a new cartridge in.
If you want to reset your Brother MFC 9440N machine so you no longer have the error message: Toner End of Life, do the following:
The Brother MFC 9440N should be reset and the Toner End of Life message should disappear. Warning, this may void your warranty and ultimately damage your machine if you are reusing or refilling your cartridges, but you should already know that. Hope this helps.
Nov 11, 2010 | Brother MFC-9440CN Laser Printer
The toner life ended and then we got a refill. Earlier on refill, It was working fine, But this time it still says , TONER life end, replace toner. We tried loading 2 different refilled toners and cleaned...
we can refil toner many times but we should reset cartage, while we refiling toner to open cartage we should sides white rings middle plastick flate white plate make adownof cartage it is first methode. when we put reffiling cartage put on printer and do on at that time we push cartage right side pointo re set. look on www.brother.com
Nov 05, 2009 | Brother MFC-7820N Printer
I am facing problem in brother printer DCP 7010 is showing toner life end.
nvr mind, i guess the toner is exhausting or is exhausted..
mind for a refill or head change or both..it may solve ur problem..!!
do contact ur system admin!!
Oct 25, 2009 | Brother MFC-7820N Laser Printer
BROTHER MFC 7820N MACHINE PUT IN NEW DRUM, CHANGE DRUM MESSAGE COMES ON. PUT IN NEW TONER, TONER END OF LIFE MESSAGE COMES ON.
Jun 15, 2009 | Brother DCP-7020 All-In-One Laser Printer
My printer is telling me 'Toner Life End' after I've replaced it.
I was having the same problem with my MFC7820N.  To be honest, I think I got a little lucky poking around with a screwdriver, because the problem seemingly dissapeared.  However, I don't recommend it unless you know what your doing.
I did come across this solution on the internet afterwards though:
Open the front cover of the machine (open the compartment where you insert the toner cartridge)  Wait for "front cover open" to show on the screen.  Press the "Options" button, then press *00 and wait a few seconds, then close the front cover.
This resets something or other, I imagine it will work for you.  Hopefully it does, and if so you're welcome :)
Now, if you can just tell me exactly what is causing my MFC7820N to only have a tiny amount of toner stick to the top right of the page, we'll call it even.
Feb 03, 2009 | Brother MFC-7820N Printer
TONER LIFE ENDED
While you have the door open, you have to press some buttons on the menu which will reset the counter. Sorry, I forget what they are right now (it's been a while since I've done it), but you can google and I'm sure you will find it.
Dec 10, 2008 | Brother MFC-7820N Laser Printer
Toner life end
Try removing the new toner cartridge from the machine, and shake it up and down and sideways, over a newspaper. Then, put it back in the machine and see if that helps. Sometimes, especially if the new cartridge was exposed to high temperatures or humidity before you got it, the toner SETTLES inside. Shaking it up can usually help.
Jul 06, 2008 | Brother MFC-7820N Printer
Toner life end message flashes
did you reset the toner life?
open the front cover, press the option button, on the screen will display ''reset toner life 1 yes 2 no ''
press 1 and close the cover.
toner life reseted
May 06, 2008 | Brother MFC-7820N Laser Printer
Brother MFC-7820N Printer Logo
4,739 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
